AMP/SUB Installation problem with BOSE Audio Pilot
Rating: Thread Rating: 4 votes, 4.00 average.
Old May 6, 2003 | 12:45 PM
wimpytron's Avatar
mercedes c sportcoupe
This means that further research is required ! i cannot imagine that there is NOBODY who knows exactly where the microphone is situated... And Bose stays "deaf" for this issue. No support at all ;-((
allthough, the pin 1,2,3 "theory" seems reasonable.... but i cannot do this myself (I not that handy ;-)) .... if someone , with coupé and bose system, feels free to try this, please let me know and post the results.
in the meantime, my search for the bose microphone continues !
Old May 6, 2003 | 05:43 PM
wimpytron's Avatar
i just read on the German bose page that the microphone is in the "innerspiegl", in english it is "inside mirror" or somewhat around there
http://www.bose.de/product/auto/audio_pilot_tech_2.asp
i also mailed at the german bose division for more info where exactly to find that "hidden" microphone. if i receive feedback, i will post it immediately
Old May 6, 2003 | 06:08 PM
radical's Avatar
03 E500
Thanks wimpytron. I don't even switch on my HU anymore 'cos I'm afraid it might bust my woofers.
By the way, how does ur volume increase like? Is it a sudden increase or gradual one?
Old May 6, 2003 | 06:18 PM
wimpytron's Avatar
it is a sudden, very loud increase, and then immediately after it the bass is gone and volume drops down heavily. it continues untill i turn off the sub/amp (it is a pioneer amplified bassbox). it can be turned off only by the ignition. for now, i put the gain of the bassbox on 5 (max=10) and then it will not flipp ;-) but on gain 5 the bass is there , but it is not that "heavy bass" that thrills my throat, as i like it normally ;-)
so until there is a decent solution, i use the bassbox on gain 5 with 'normal" bass volume, because, i must admit, the overall sound quality of the bose system is very good in my opinion.
but after reading the german bose automotive page, i'm again convinced that the microphone MUST be around the rearview mirror . help me search please ;-)))))))
i have the european C sportcoupe CDI 220. i'm from belgium.
Old May 6, 2003 | 06:31 PM
radical's Avatar
03 E500
Yea, that's exactly what happens to mine too. I have 2 X 12" subs so I had to turn the bass way down not to cause that.
Haha.. sure go ahead and look for it. Let me know when you find it. We tried almost everywhere, even in the a/c ducts still no luck.
Btw below is an email that I received from BOSE.
I believe this information was requested from the after market installer
yesterday. I have a voice mail in to our System Engineer I will reply with
the information as soon as possible.
I realize you have already adding after market components but I wanted to
let you know that Bose Corporation does not recommend adding any after
market components to the factory installed systems they are not compatible
and typically will give you some type of interference with the system
performance.
Patty Bolack
Consumer Relations Division
Bose Corporation
US Telephone: (800)231-2673
International Tel: (508)766-6699
Fax Number: (508)879-2043
Email: http://www.bose.com/contact_us/
Office Hours: Monday - Friday 9:00 AM - 5:00 PM (EST)
Visit our Website: www.bose.com
They did call back to my Audio Installer and told him that they do not support aftermarket equipments attaching to BOSE systems and that the feature cannot be turned off.
Old May 6, 2003 | 06:47 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
You guys are working in VAIN,,Get rid of the BOSE head unit, It is a humungus POS..
Old May 7, 2003 | 02:55 AM
  #32
wimpytron's Avatar
vadder13 : Not correct! if microphone will be found AND disabled, i'm 100% sure that the problem will be gone. It's as simple as that. I'm not gonna spend another $1500 or so for new speakers, head unit and stuff. I now have the audio 10 cassette-radio, the cd changer and the bose system, it costed already more then enough !
And... I'm convinced that a microphone is somewhere... outthere, I only have to find it AND I WILL !!!!
Old May 7, 2003 | 07:44 AM
  #33
wimpytron's Avatar
i received this email from Bose - Germany in german)
Sehr geehrter Herr Pytron,
schönen Dank für Ihre Nachricht. Es tut uns leid, daß Sie
Audiopilot(R)
Funktion nicht zufrieden sind,
und diese deaktivieren wollen. Allerdings müssen wir Ihnen dringed
davon
abraten, einfach das Mikrofon
abzuziehen. In diesem Fall würde der Verstärker die Schwankungen
der
Bordspannung als Eingangs-
signal nehmen, und das System würde ziemlich unkontrolliert hin- und
her
regeln.
Idealerweise lassen Sie das Mikrofon an seinem Platz (in der
Dachbedieneinheit beim Innenspiegel),
und überziehen die Mikrofonkapsel mit einem Dämpfungsmaterial -
Heisskleber
-hot glue- bietet sich
dafür an.
Sollten Sie weitere Fragen haben, lassen Sie es uns bitte wissen.
So, in short, it meams that i'm correct, in my european cdi220 C sportcoupe, the microphone is in the road map light area, and it shuold be tempered with foam or tape.
That is what i did, and therefore , wen tape was on the grill, the bass did not have a mind of it's own. (Or at least, the problem was less occurant)
Now, i'm going to seek for a more permanent solution, without disconnecting the microphone, because that is not good according to the german bose technician !
So , after all, it seems not to be a airconditioning sensor (at least for the european C sportcoupe) ;-)
if it works, i let you know
Old May 10, 2003 | 01:43 PM
  #34
wimpytron's Avatar
it is indeed true, radical, that the microphone is nowhere to find in the overhead light console. Me and my audio installer took it out and finds nothing, unless it is on the print itself ;-) Although the german Bose technician said it is located there.
i will email again to that technician as he said that, if further questions, i could mail him directly.
>the audio installer said that he could follow all the wires from the bose amp until he finds the microphone, but that , of course would cost me a fortune ha ha ha.
if a get feedback I'll post it again
Old May 10, 2003 | 11:09 PM
  #35
R4ND0M_AX3's Avatar
C230
If you happen to be looking at the BOSE amp could you take a picture of it or describe how to get to it? I've heard that it's in the right rear passenger panel but didn't want to break anything (especialy airbag related) gettting the panel off. Anybody know how to get this panel out without any damage?
Old May 12, 2003 | 09:15 AM
  #36
wimpytron's Avatar
I received this mail from the german bose technician.
Dear Mr. Pytron,
Thank you for your note.
I am sorry that you have not found the mic yet.
We have checked in our demo car and realized that there is another
possible
position for the mic. You have to dismount the lamp unit and there are
a
brown and a white cable leading to the location of the mic. You could
use
a finger and feel a 1cm diameter 'hole' under the fabric about 2
centimeters
to the right of the lamp unit toward the wind screen. That's where the
mic
is hidden. You should be able to reach it tracing the mentioned wires
at
the front right corner of the lamp unit.
so, i hope i'll find it now. I will let you all know if i found it, and if covered with dampening foam, if it will give the desired result, that is, no more "Crazy BASS" increases and decreases.
if others feel free to try this, please give also feedback on the result
Old May 12, 2003 | 05:25 PM
  #37
R4ND0M_AX3's Avatar
C230
Well, well. I just went out to the car and found the 'hole'. It's just above the mirror to the right of the light housing as stated. I'm gonna put my test sub back in and play with some stuff. Thanks for the leg work.
Old May 12, 2003 | 05:35 PM
  #38
wimpytron's Avatar
could you post a picture, please , than i can see WHERE IT IS EXACTLY ???
and... most of all : could you tell me if, when the mic is "treated" with "sound blocking" foam, if the desired effect is there : that the bass can be VERY loud and stay normal ;-)
thanx in advance ;-)
Old May 12, 2003 | 06:22 PM
  #39
radical's Avatar
03 E500
GOT IT!!
Thanks so much for wimpytron, I unplugged the hidden mic. Took several pics along the way and will post it tonight. I'm still crossing my fingers and testing if it indeed works or not though.
Thanks again wimpytron for the location of the mic.
Old May 14, 2003 | 11:42 PM
  #40
radical's Avatar
03 E500
here we go...
I've tested for awhile now without occurring any sudden volume increase after disconnecting the mic. Here are some of the pictures that I took along the way. I hope it helps everyone out there who's having problem with this crap.
First, remove the head lamp assembly.
Old May 14, 2003 | 11:45 PM
  #41
radical's Avatar
03 E500
Location of the mic
You won't be able to see the mic, Just use a flash light to follow the white and brown wire that goes to the front of the assembly. I yanked the wire and mic came out.
Old May 14, 2003 | 11:47 PM
  #42
radical's Avatar
03 E500
Here is the mic 'assembly'
Notice the shiny little mic that does all the magic of capturing the ambient noise.
Old May 14, 2003 | 11:48 PM
  #43
radical's Avatar
03 E500
Another pic of microphone
  #44
radical's Avatar
03 E500
close up
Old May 14, 2003 | 11:53 PM
  #45
radical's Avatar
03 E500
Unglugged!
unplug the connector. It's kind of hard to do with hand (i tried) but with proper tool, it's easy.
Old May 14, 2003 | 11:54 PM
  #46
radical's Avatar
03 E500
Last one.
After this, just put everything back together and no more volume increase!
Thanks wimpytron again for the location of the mic.
Old May 15, 2003 | 01:34 PM
  #47
wimpytron's Avatar
ok! INDEED after i disconnect the microphone as described in the pictures it all was ok ! there was a bit glue at the microphone, so if you do this, handle with care ;-)
So, Finally this problem is solved, ONCE AND FOR ALL !!
a short summary of the facts :
IF YOU ADD AN AMP / SUBWOOFER TO THE BOSE SOUND SYSTEM THEN YOU RISK EAR DAMAGE DUE TO SUDDEN HEAVILY DECREASE OF VOLUME AND BASS. THEN THE VOLUME FLUCTUATES UNTILL YOU TURN OFF THE AMP OR SUB :
this is caused by the ambient noise that is measured inside the cabin by a bose microphone.
if you have this problem then you have to check the following :
1. The standard Volume Speed Control of Mercedez stock unit NEEDS to be disabled (otherwise it gives problems in combination with the Bose audio pilot) But, with a bose sound system it is already disabled. so, all the "so called solutions" to set SVC to db0 is CRAP !!
2. the ambient noise microphone of bose NEEDS to be DISCONNECTED as described on the pictures
3. then you can pump the volume up, with as much as bass as you like and you can connect 100's of watts or woofers/amps as many as you like to the bose system, no matter what is described on the bose site !!
Keep in mind that this is only a solution if your C class has a bose sound system.
Radical, thanks again for posting the pictures as "A Picture is better than a 1000 words"
Old May 15, 2003 | 11:41 PM
  #48
baldo99's Avatar
2003 C230 Coupe
Radical,
What was your technique on removing the head lamp assembly?
Old May 16, 2003 | 01:22 AM
  #49
radical's Avatar
03 E500
I used a flat head screw driver to ply out the plastic cover. There are two clips that you need to push near the light bulb. When you pushed those clips, the light assembly should just fall out.
Old May 16, 2003 | 01:21 PM
  #50
tomz_racing's Avatar
c320 (w203)
hi,
is this problem only occur on c230k ? or can it occur to c320 ?
because i am planning to install 2 12" subs, 1000 zapco amp with a factory bose system.
any suggestions ?
You have already rated this thread Rating: Thread Rating: 4 votes, 4.00 average.
