EGR hose on m271
Old Jun 8, 2010 | 06:50 PM
hieracity's Avatar
C230 K Coupe (05)
EGR hose on m271
Is that the EGR hose? (red outline) What is it's function? I have googled it already but if some of you guys could help explain it laymen terms and what's its role/importance is in the engine, it would be much appreciated.
TIA
Old Jun 8, 2010 | 08:06 PM
TEAMREDLINE's Avatar
C
EGR stands for exhaust gas recirculation. It is used for smog purposes to recirculate bad gas back to engine instead of atmosphere. It is suppose to only go on at idle, and deceleration. If you disconect it would be better, but check engine light will come on.
Old Jun 9, 2010 | 02:46 AM
hieracity's Avatar
C230 K Coupe (05)
Thanks for your response. Could you clarify what you mean by better? Like performance wise?
I am asking about this because like you, I am planning on deleting my SC resonator. Everything seems simple enough (i think) except for accounting for the EGR hose (since it will requiring some drilling in the aluminum pipe).
TIA
Old Jun 9, 2010 | 03:14 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Many here are tempted to trot out all the performance for which they’ve already paid.
$0 modifications are fine, so long as their strategy is sound.
The hose you’ve highlighted is supplying filtered ambient air for the secondary air injection (AIR) system. It’s injected into the exhaust manifold -during cold starts and other selected drive cycles- to reduce unburned hydrocarbon tailpipe emissions and aid catalytic converter efficiency. Its effect is akin to fanning the dying embers in a fireplace with bellows. Save for a potentially costly pump replacement, there is absolutely no performance downside.
Your EGR valve is an integral, although independently commanded part (on many RoW M271’s), of the AIR system’s distribution casting. It’s contained within its lower half, below the hose you’ve highlighted. EGR meters a modest portion of inert gases (up to ten percent total volume, although typically far less) during light load cruise operation back into the intake tract in order to reduce peak combustion temperatures and the formation of oxides of nitrogen (NOx). It’s inoperative at closed throttle and WOT.
EGR enables the manufactures’ engineers to specify more aggressive cam timing, compression ratios, and spark advance parameters -while complying with various regulatory edicts- thereby minimizing fuel consumption and reasonably exploiting available performance. Certainly not claiming that they can’t be improved upon, but MB has proven pretty smart about those things as delivered. There is nothing to be gained from circumventing or defeating the EGR system.
It is suppose to only go on at idle, and deceleration. If you disconect it would be better.
Source?
Old Jun 9, 2010 | 12:26 PM
hieracity's Avatar
C230 K Coupe (05)
Source?
Thanks for you great info!
So if I do decide to remove the SC muffler, you are suggesting I make sure that that hose is still connected, right?
Old Jun 10, 2010 | 10:45 PM
splinter's Avatar
Super Moderator
Yes, the hose must remain connected in order to avoid triggering a P0140 CEL.
It supplies pressurized air (not “ambient”) to the secondary air system.
Must be noted the M271 has no separate AIR pump as do the C’s other M111, 112, and 272 engines; its supercharger pulls double duty.
I regret the error.
Doesn’t require AN fittings and braided hose –the OE setup certainly didn’t need it when pumping ~ten pounds of boost-
but here’s a functional example of another member having ditched his supercharger's resonator:
photo credit TEAMREDLINE
Old Jun 11, 2010 | 05:32 PM
hieracity's Avatar
C230 K Coupe (05)
Any reason why the stock hose couldn't be reused?
Thanks.
Old Jun 11, 2010 | 11:35 PM
splinter's Avatar
Super Moderator
None of which I'm aware.
Have you decided with what you’re replacing its OE resonator/muffler and junctions?
Perhaps you’ll consider using a similar bulkhead fitting (properly sealed and pressure tested) to reconnect the AIR tube:
Old Sep 3, 2020 | 10:28 PM
bamacowboy1's Avatar
03 MB c230 Kompressor sport coupe
I think you mean P0410?
I regret the error.
Attachment 408373
P0140 is caused by a bad after cat O2 sensor.
