Enkei Rpf1's; does anyone have them?
Old Jun 10, 2010 | 02:06 PM
05c230rpf1's Avatar
2006 C230 Sport
Hi guys,
I'd like to get a set of enkei rpf1's however I'm not sure if they're going to work, and would really like to see what they might look like on the car.
I'm going to be buying an '05 c55amg and whichever wheels i buyt, I would like to have them here to put on the day I pick up the car.
I know they make the rpf1's in 18x8 et35 and 18x9 et35. The front I would need hubcentric rings but the rear is already the right size center bore.
Im concerned they might not fit over the brake calipers.
Does anyone know if they will or wont work? If anyone has any pics that would also be amazing.
Thanks in advance
James
Old Jun 10, 2010 | 03:10 PM
phister's Avatar
06 C230 SS 6spd
usually the rpf1 will fit over bbk because they are designed to be racing wheels. Since you'll be having to put wheel spacers on I pretty sure you'll have enough clearance for the brakes. What you can do is call enkei and see if they can make custom ones for your fronts.
Old Jun 10, 2010 | 10:49 PM
Hokie1200's Avatar
2004 C230 Kompressor Sport sedan 6 speed manual, 2013 S550 Sport 20" AMG
I was in the market for those wheels and spoke with King at Enkei. The 18x9 was special order from Japan, but they did not have them. Would be August or so before they could produce them. He turned me onto the new PF01. They have them (front and rear) in the U.S. and should have the hub rings in the country by now. Definitely give Enkei a call.
Old Jun 14, 2010 | 09:13 AM
05c230rpf1's Avatar
2006 C230 Sport
Why would I have to use wheel spacers? Just as a refrence I looked on tire rack and pretty much every 8" wide wheel has a +35 offset
Old Jun 14, 2010 | 12:08 PM
phister's Avatar
06 C230 SS 6spd
Because if you're buying an AMG you're gonna have a bbk on it so most likely a 35 offset is going to be high and it might hit the calipers. I have cls500 18x8.5 wheels on my front of my c230 and the offset are +28 et I believe and I had to get 3mm spacers cause I had less than 2mm of clearance from my wheels and my calipers. But to make sure you should see what the normal offset is for the car so you know if you need spacers or not.
Old Jun 16, 2010 | 07:39 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
RPf1's are time attack wheels or just racing wheels due to their lightweight strong characteristics they create less rotating weight at each corner therefore less rotating inertia. The wheels themselves are great, rather get a set of VOLKS for street use, but they are for everything, steering response with lighter wheels is by far more responsive. These aren't made to see potholes, but if you are from the Japanese scene they aren't like Rota's either. If you know what im talking about.
If your into this style of wheels, you should look into the ADVAN RS
Old Jun 17, 2010 | 04:10 AM
quadoptix's Avatar
2007 C230 sport
rpf1s should clear any brake upgrade fine. great wheel i have them on my non benz. as light as it gets for a non forged wheel =)
Old Jun 17, 2010 | 10:51 AM
05c230rpf1's Avatar
2006 C230 Sport
Yeah I have an s2000 and have enkeis on there and love them... Never really been a fan of advans unless they're the super concave rs'
Old Jun 17, 2010 | 11:41 AM
05c230rpf1's Avatar
2006 C230 Sport
I had them on my s2k and loved them. Just as many say though I don't know how they're
going to look on a Benz... I still have a lot to figure out considering I just learnt the amg doesn't have a LSD may not be the biggest ordeal though as I am trying to get away from the boy racer look and more into the classy look
Old Jun 17, 2010 | 06:50 PM
Mu9enx's Avatar
01' C32o
Someone recently got 17'' RPF1's on the forum. I forgot the user, but it didn't look bad. I'd get them in a lower offset and concaved though
Old Jun 17, 2010 | 08:14 PM
05c230rpf1's Avatar
2006 C230 Sport
Only problem is enkei only make a 8" and 9" rim in the 5 x 112 bolt patern both with +35mm offsets. if I wanted a lower offset I would have to redrill a 5x114.3 wheel
Old Jun 17, 2010 | 08:20 PM
Nike Turbo Shox
Im trying to break away from the classy look, but at the same time attempt to keep it.
Old Jun 17, 2010 | 08:28 PM
Mu9enx's Avatar
01' C32o
LE37's for the classy, yet sporty look imo
Old Jun 17, 2010 | 08:30 PM
Mu9enx's Avatar
01' C32o
Have you thought about the new Advan RG-D? It's bad ***
Old Jun 17, 2010 | 09:06 PM
05c230rpf1's Avatar
2006 C230 Sport
I really haven't honestly I'm still looking at cars; i'm torn between the c55, the new c300 since it's manual, 545i again for manual, or even just keeping my 04 accord and just saving money
Old Jun 17, 2010 | 10:05 PM
NegroC230's Avatar
08 ML CDI
I got 17" RPF1 :P with mad spacers, lol...12mm upfront and 27mm in rear...Nitto INVO 225/45-17 all around
Old Jun 19, 2010 | 01:02 PM
NegroC230's Avatar
08 ML CDI
latest pics....
