Down shift, check engine light, V8 grumble, power loss, and a burning smell. (20 sec)
Old Jun 13, 2010 | 09:56 PM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Top!!! Sorry. Karo's getting his post count up, so I figured I would too!
Old Jun 14, 2010 | 01:24 AM
fookoo303's Avatar
2003 c240
haha karo has turned this into a soccer forum. every thread i go to is soccer now haha
Old Jun 14, 2010 | 02:09 AM
W203E35's Avatar
2006 C350 Sport 6MT
First it way turning every thread into gay jokes and now it's turn every thread into soccer
Hopefully the OP has tried the mentioned and he fixed his car
Old Jun 14, 2010 | 02:14 AM
DanielFD's Avatar
2007 BMW 550i
sorry extremely off subject, but i have to comment.. i was reading through the thread and i just could help but watch bdgdl08's gif (in his signature) about 30 times haha i wish i could do that..
Old Jun 14, 2010 | 02:41 AM
W203E35's Avatar
2006 C350 Sport 6MT
Ohh what now I get it. That's a cop chasing him . Amazing
Old Jun 14, 2010 | 07:07 AM
W203E35's Avatar
2006 C350 Sport 6MT
Don't blame this on Karo. Karo doesn't care about post count. What matters is name my friend..how well people recognize you by name
Old Jun 14, 2010 | 07:10 AM
  #32
Glyn M Ruck's Avatar
Super Moderator
Oh good, I'm glad I'm not the only one.. but you have 4 years on me. Then again, I'll probably still be here in 4 years.
It's a world wide phenomenon these days - nothing unusual.
Old Jun 14, 2010 | 07:17 AM
  #33
W203E35's Avatar
2006 C350 Sport 6MT
If I ever get married then I will move out, until then I'll stay here. I have no problem with my parents. I get along with them extremely well and like I said I help them with the mortgage and bills and stuff. I can just abandon them and I can't afford to live on my own and help them at the same time.
Edit:
Just saw Glyn's post. +1
Old Jun 14, 2010 | 05:57 PM
  #34
bdgdl08's Avatar
I'd kill somebody if I tried.
Is that what it is? Makes more sense now.
Old Jun 14, 2010 | 06:48 PM
  #35
laneshift's Avatar
C240
Cover came off. The misfires are more and more common now. Before I touch anything, is this a good sign? It seems oil is creeping out of the seals. Isn't that general area where cyl. 4 is?!
Old Jun 14, 2010 | 07:00 PM
  #36
samaritrey's Avatar
Super Moderator
THE C350
mine looks like that but mine was because i had the cover leaking can't remember the technical name. i do remember it does not have a gasket you can buy you have to make one mine was covered under warranty so whatever. maybe it was valve cover. Mine didn't really do anything bad to my engine just lost some oil and made it filthy.
Old Jun 14, 2010 | 07:06 PM
  #37
laneshift's Avatar
C240
Great. I should just carmax this heap of trouble.
Old Jun 14, 2010 | 07:13 PM
  #38
fookoo303's Avatar
2003 c240
check your spark plug to see if its filled with oil. If it is then i believe you got a bad gasket or if samaritrey is right then maybe just needs silicon or whatever mercedes uses to seal the valve cover. Hopefully its not anything internal like piston rings. Keep in mind im no expert on this so dont trust my word completely but for sure check to the plug. Good thing it's number 4 so its easy to get to. You just gotta pry that wire off gently to get to the plug.
Old Jun 14, 2010 | 07:18 PM
  #39
samaritrey's Avatar
Super Moderator
THE C350
well it is actually cheap i think i was told it was 84.95 per side so its not like it was outrageously expensive. But you are having a bad time with your car how many miles are on it and how long have you had it?
Old Jun 14, 2010 | 07:23 PM
  #40
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
#4 cylinder is the front one on the driver side.
that pic is of 1-2-3. seal leak is common issue on m112 and m113. just have the recirculating cover seal replaced, not that big of a deal.
Old Jun 14, 2010 | 10:10 PM
  #41
laneshift's Avatar
C240
Oh good. Not the most expensive part!
I've had the car 11 months. 63k miles. Wouldn't get but 7k or so for it.
Old Jun 14, 2010 | 10:22 PM
  #42
laneshift's Avatar
C240
Also, tech who inspected car briefly mentioned that my car needs an oil change every 3k or every three months... sounds like he just wants business. He told me to go to his shop to get my oil changed so he can further diagnose my problems. So far:
Spark plug
Plug wires
Head gasket seal
"I don't know how much that'll cost. But bring 50-70 bucks for the oil change."
Fishy.
Old Jun 15, 2010 | 12:02 AM
  #43
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Don't fall for that 3mo/3000mi oil change BS!
Old Jun 15, 2010 | 01:01 AM
  #44
LawRens's Avatar
43
I dont know if you solved this problem already, but my 98 c230 had the same problem last winter.
The mechanic (family trustworthy) said it was bad coil packs, which in turn screwed up the spark plugs. I suggest taking a look into those first and foremost. In the meantime if you must drive it, be easy on the throttle off a dig or when rolling at low speeds in a high gear. That can cause the problem easy.
Old Jun 15, 2010 | 01:38 AM
  #45
fookoo303's Avatar
2003 c240
Spark plug
Plug wires
Head gasket seal
Fishy.
dont do it every 3k and if he's saying 50-70 bucks then hes not putting in full synthetic with proper filter. doesn't sound trustworthy at all or he just doesn't know much about mercedes. The 8 quarts of mobil 1 alone is 60-80 dollars.
Old Jun 15, 2010 | 07:04 AM
  #46
Super Moderator
Lane,
No need for short oil drain. That captive crankcase ventilation seal is a common leak & a cheap fix. Tru Taing did a good writeup on it's repair.
Old Jun 15, 2010 | 02:00 PM
  #47
laneshift's Avatar
C240
I thank this forum from the bottom of my heart. You guys save me money and keep me hopeful of a, one day, perfectly well running c240!
Old Jun 15, 2010 | 02:30 PM
  #48
fookoo303's Avatar
2003 c240
It will never be haha. One small thing after another.
Old Jun 15, 2010 | 07:47 PM
  #49
samaritrey's Avatar
Super Moderator
THE C350
lol my 320 is trouble free
  #50
laneshift's Avatar
C240
To remove the recirculating valve, I need a 14 torx, and I've check three auto shops and a lowes. No where to be found. Is it just uncommon? I'm headed for harbor freight..
