Down shift, check engine light, V8 grumble, power loss, and a burning smell. (20 sec)
Old Jun 15, 2010 | 07:49 PM
  #51
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Originally Posted by samaritrey
lol my 320 is trouble free
Except for the driver.. you should look into getting that replaced.
Old Jun 16, 2010 | 07:00 AM
  #52
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by laneshift
To remove the recirculating valve, I need a 14 torx, and I've check three auto shops and a lowes. No where to be found. Is it just uncommon? I'm headed for harbor freight..
Sears have them under the Craftsman brand if you need & there are some good reasonably priced sets on the internet. I bought a set there on my recent 2 month holiday to Dallas & San Diego. Look for EXTERNAL torx!
I bought this set for light work. They also have a 34 piece set for the serious.
Set Includes:
# Deep E4 Torx Socket Square Drive 2 long
# Deep E5 Torx Socket Square Drive 2 long
# Deep E6 Torx Socket Square Drive 2 long
# Deep E7 Torx Socket Square Drive 2 long
# Deep E8 Torx Socket Square Drive 2 long
# Deep E10 Torx Socket Square Drive 2 long
# Deep E11 Torx Socket 3/8 Square Drive 2.5 long
# Deep E12 Torx Socket 3/8 Square Drive 2.5 long
# Deep E14 Torx Socket 3/8 Square Drive 2.5 long
# Deep E16 Torx Socket 3/8 Square Drive 2.5 long
# Deep E18 Torx Socket 3/8 Square Drive 2.5 long
Model: VMVDE418
Old Jun 16, 2010 | 09:03 AM
  #53
W203E35's Avatar
2006 C350 Sport 6MT
Came to San Diego and didn't let us know??? We would have drove down to SD and took you out to a high end restaurant as a gratitude of our appreciation for all your help. Maybe next time you can also bring your laptop so I can finally install WIS
Old Jun 16, 2010 | 01:22 PM
  #54
laneshift's Avatar
C240
Is my car drivable after two or three hours after I reseal the recirculating cover?
Old Jun 16, 2010 | 01:41 PM
  #55
laneshift's Avatar
C240
Also, I just broke a screw off inside the cover while I went back to tighten the bolts one last time.
What's there to do? Unscrew the bolts, remove the gasket maker, replace the bolt, and redo the job?
Old Jun 16, 2010 | 01:58 PM
  #56
laneshift's Avatar
C240
More trouble than I asked for. I hope they make extractors this small!
Old Jun 16, 2010 | 06:52 PM
  #57
samaritrey's Avatar
Super Moderator
THE C350
well you have the worst luck i have ever seen oh my god. Just be careful not to damage it anymore and get that bolt out safely.
Old Jun 16, 2010 | 06:55 PM
  #58
LILBENZ230's Avatar
I don't think this has anything to do with luck, Trey. I think it has to do with 2002 W203.
Let us know how this all goes, Lane.
Old Jun 16, 2010 | 07:18 PM
  #59
laneshift's Avatar
C240
I got the broken screw extracted, sealed up the recirculating cover for the second time, and got new plugs and plug wires for cylinder four. Hopefully this stops the oil leak along with the misfires. The seals below the cover, which seem to seal up a large area, look to be leaking. I'm in no mood to attend to this today, maybe tomorrow. Haha.
Old Jun 16, 2010 | 08:57 PM
  #60
Super Moderator
I only spent 6 days in Alpine, San Diego with my old boss & his family. Flew over from Dallas specially. George Barnett was the finest manager I ever worked for & got me into my international job. Had not seen him since 1998. He's been retired for a while.
Old Jun 16, 2010 | 09:00 PM
  #61
Super Moderator
Good news! - You might have a weep from the cam cover gaskets - easy job to replace. My engine is bone dry & clean after 6.5 years.
Old Jun 16, 2010 | 09:11 PM
  #62
W203E35's Avatar
2006 C350 Sport 6MT
Great progress man. Just take your time and good luck.
Old Jun 16, 2010 | 09:19 PM
  #63
laneshift's Avatar
C240
Thanks guys. I can't wait for the gasket maker to set so I can take it out for a spin.
Old Jun 16, 2010 | 09:40 PM
  #64
LILBENZ230's Avatar
Is it raining in your part of FL? Careful.. I hear Drew took his car out for a spin earlier.
Old Jun 16, 2010 | 09:41 PM
  #65
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Very punny, Matt!
Old Jun 16, 2010 | 10:00 PM
  #66
samaritrey's Avatar
Super Moderator
THE C350
i hate you matt you are making me splatter vanilla coke everywhere
Old Jun 16, 2010 | 10:03 PM
  #67
LILBENZ230's Avatar
No, you can't hate me! You, Drew, and Karo are family. Well, and Lane since this is his thread. Back to topic.. we're all being bad lately.
Lane, don't take it out for a spin like Drew. BTW, I admire your ability to do such work on your own. I'm intimidated by checking the oil.. and it's electronic!
Old Jun 16, 2010 | 11:16 PM
  #68
laneshift's Avatar
C240
Well, with the local stealerships chargin' ten bucks for regular yellow city lights and ten bucks for a single spark plug, you can only imagine the labor tagged onto the parts. The DIY's in this forum REALLY help. Even though each DIY has a disclaimer , I still follow them with faith. Worked for them, why not for me?
Old Jun 17, 2010 | 10:41 AM
  #69
laneshift's Avatar
C240
Update:
Since battery was disconnected, I had to resync the windows. ESP malfunction is popping up on the screen, though!
Idle is WORSE than before, my car sounds like a muscle car , and almost choked when it first started up.
Does this have anything to do with how tight the spark plugs are? I was afraid to give the new plugs too much torque because I was told not to use a torque wrench on them so they don't break off inside the block.
Please tell me this is something that needs to be "broken in" and I just need to drive a few miles.
Old Jun 17, 2010 | 11:04 AM
  #70
Super Moderator
Lane - The ESP is likely as a result of disconnecting battery & will go away with a few reboots & driving the car. Please get an OBDII scanner back onto the car & let us know what codes it's throwing. This is sounding MAF like in trouble. Is your MAF clean? Please also check everything you have recently disturbed. Make absolutely sure that you have no leaks in the vacuum pipes or the captive breather pipes. After reading faults you need to move coilpacks & leads around to see if misfires change cylinder. You might just have poor leads. See Kris420 thread in this regard. We talked him through it and it was just leads.
Sparkplug torque will effect plug cooling/heat transfer. It will not cause a misfire with new plugs & no mileage. Also remember you have twinspark heads. The chances of both new plugs misfiring on one cylinder are slim.
Old Jun 17, 2010 | 11:13 AM
  #71
laneshift's Avatar
C240
Thanks Glyn! I'll follow your advice! Now to locate the MAF..
Old Jun 17, 2010 | 11:34 AM
  #72
Super Moderator
I would do plug leads first. MAF is at the back of the V against the firewall will airbox off. That round hole with a grating over it.
Old Jun 17, 2010 | 11:50 AM
  #73
laneshift's Avatar
C240
I'm having trouble finding a MAF remove and clean thread..
I'll look harder though.
Old Jun 17, 2010 | 12:00 PM
  #74
Super Moderator
Read splinter's post
https://mbworld.org/forums/c-class-w...t=MAF+cleaning
Old Jun 17, 2010 | 12:10 PM
  #75
laneshift's Avatar
C240
Thanks a million! Off to Auto-Zone!
