REAR tires wearing in Center
06 C350 sport 6MT
have 06 c350 sport 6 spd, coilover, star spec tires, car calls for 32 psi on rear, i ran 33-35 psi and the center strip wore out way b4 shoulders, i reduced psi to 30 psi, but hwy mpg went down from 32 to 30. any suggs?? thanx, mike
Super Moderator
Car runs most of it's mileage lightly loaded.
2006 C230 Sedan
Isn't it suppose to be 245? Any advantage of going smaller?
Super Moderator
No - standard was 205/55/16 on 7" X 16 ET37 wheels
On 8" X 17 X ET32 wheels (AMG split rim replicas) 235/45/17 is max tyre size to clear front standard Sachs strut. Remember I'm not staggered by choice so I can rotate.
My car wears shoulders on front tires first and center of rear tires first. Always has and I suppose it always will. I've experimented with lots of different PSI configurations.
2004 S55 (SOLD, miss it every day), 2009 GL550
another factor that can cause the center to wear too fast is using too wide a tire for the rim. it makes the tire tread bow out and wear prematurely. make sure your tires are within spec for your rims
