DIY: Hid Convert Kit Install - VVME product
Old Oct 14, 2010 | 11:15 AM
  #101
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
i get it eventually for both...sometimes just one...and they dont always turn off and sometimes they will turn right back on...its hard to tell sometimes but i try and watch in the rear bumper of cars im following...like today it is raining so i had them on and after like 2 minutes the left one said it was off and i think it switched off for a split second and then back on which is why the error code came up.
Old Oct 14, 2010 | 02:59 PM
  #102
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
it's possible that you've got a bad set of lights.
It would be nice if you could swap with other set of working lights.
Old Oct 14, 2010 | 03:06 PM
  #103
maverik259's Avatar
ya...i may contact vvme and be like look i want my money back you dungaroos!
Old Oct 14, 2010 | 03:19 PM
  #104
maverik259's Avatar
and i just bought some of those error elimnators from ddm to see if those will fix this. Although I dont see why they should. I have xenon set to present and other people with this issue haven't had these issues with there vvme. If it still persists I will send back to vvme.
Old Oct 14, 2010 | 03:31 PM
  #105
pcy's Avatar
pcy
maverik, if the headlights you got are bad to start with, no matter what you do, they will not work properly. New parts can go bad... even new parts from MB also go bad or don't fit properly... it's rare but it happens.
If I were you, I would contact the seller and ask them for replacement after explaining what the problem is. They may just ship a replacement set.
Old Oct 14, 2010 | 04:26 PM
  #106
maverik259's Avatar
ya i konw it wont fix it if the ballasts are bad...just figured I'd try them out...
Old Oct 14, 2010 | 09:43 PM
  #107
crazyfunny's Avatar
e350 09
it is not a smart way to ship back the defective one and ask them for a replacement cos you need to afford the shipping ( it is not cheap for the shipping from china , man)
dude, i suggest you switch the bulbs to check whether it is the problems of ballast or the bulbs....
Check your wiring first before cursing seller. Have to triple check, because i see so so many people just going with a stock wiring harness or using skinny wires or using crappy bulbs or not soldering connections and then complaining about bad HID. There are steps to take before you know exactly whats wrong with them.
whether you reverse the wires, whether you fix the ballast by relay to make sure the ballast work well when starting up.....
only my personal ideas....
Old Oct 14, 2010 | 10:05 PM
  #108
fookoo303's Avatar
2003 c240
Are they flickering constantly with a constant frequency or just turning off and on randomly?
Old Oct 14, 2010 | 11:17 PM
  #109
04mbc230's Avatar
2006 C230 Sedan
Actually, VVME is own by VISIONARI LLC and they are located in Monterey Park CA. So, if you are in southern california, why not just drop it off and get an exchange at their door.
Here's their address:
2570 corporate place E103
Monterey Park, CA
phone: 213-908-1217
So now, no worries about shipping if they are in the neck of your woods.
Also, I had a problem with my set as you can see where I had documented here on this forum.
Well, I got my new set and gave up fighting as it looks pretty much the same as the first one (USED).
It works, so I guess I give up complaining for a new set.
Old Oct 15, 2010 | 12:19 AM
  #110
maverik259's Avatar
ya well im not soldering anything cuz nothing needs to be soldered...all my connections are good and completely taped up with electrical tape and the polorization is fine otherwise it wouldn't work at all...thanks for the input but i know what im doing. Idk what the problem is first of all and havent said squat aboutit necessarily being their fault or my cars fault, hence why i said i bought some error cancellors from ddm just to see if that fixes the problem. its not the bulbs either or again they wouldnt come on or would sho some sort of age or failing...
also they dont cont ficker but after about 3-5 min of being on they trigger a bulb out code and then they may turn off. Then they may turn right back on or i have to shut them off and back on real quick at which point they come right back on. Its both of them and never the at the same time or in the same order. Again they DO NOT FLICKER.
Old Oct 15, 2010 | 12:48 AM
  #111
fookoo303's Avatar
2003 c240
If they are both doing it, then its doubtful that it's the ballast and its definitely not the bulbs. If you want to be sure it's not the ballast, take it out and hardwire it to a car battery or a jumper box and leave it on and see what it does. If it works fine then its not the ballast.
Old Oct 15, 2010 | 11:19 AM
  #112
maverik259's Avatar
ya i'll take that step after i get the error cancellors in and see what they do...
Old Oct 19, 2010 | 10:20 PM
  #113
crazyfunny's Avatar
e350 09
ummm, waiting for ur update for the error cancellors...the ballasts problems or the bulbs'
Old Oct 19, 2010 | 11:59 PM
  #114
maverik259's Avatar
lol they actually just got delivered and isntalled today...it seems to have worked too...took it for a test drive at least and they didnt go off...tomorrow night will be the for sure tell!
Old Oct 20, 2010 | 12:00 AM
  #115
maverik259's Avatar
anyone know how hot these ballasts run? i didnt realize how effing hot the get...im kinda worried about if i should wrap them in something...the one I have resting against the plastic wheel well on the driverside and I dont want it to melt etc.
Old Oct 20, 2010 | 02:20 AM
  #116
crazyfunny's Avatar
e350 09
what if you hook up the ballast tightly ???? will the ballaste melt ????
Old Oct 20, 2010 | 06:43 PM
  #117
maverik259's Avatar
what do you mean hook it up tightly? and im not worried about the ballasts melting but it melting whats around it...
Old Oct 20, 2010 | 09:31 PM
  #118
crazyfunny's Avatar
e350 09
that is exactly what i mean ????? how about your test drive result ?????? does your ballasts melt something around it ?????? i guss not....
Old Dec 20, 2010 | 10:38 PM
  #119
anglerun's Avatar
CLS 09
Monterey Park, CA
phone: 213-908-1217
is that address available for me to place an order from their US service center directly without paying for shipping ????
i am planning to order a set of H7 HID kit 6K for my CLK 09 from vvme.com...
Old Dec 21, 2010 | 01:08 AM
  #120
crazyfunny's Avatar
e350 09
u can contact them by email or calling to check it......
Old Jan 6, 2011 | 10:36 PM
  #121
anglerun's Avatar
CLS 09
it seems that you can only get replacement from their california service center....
Old Aug 10, 2011 | 06:12 PM
  #122
cjennjr's Avatar
2005 SL500
I just recieved my kit and trying to install, but the bulb won't fit in the slot properly due to its length!!! What do I do???? Do I force it or what????? Pls reply earliest!!!!
Old Aug 10, 2011 | 08:10 PM
  #123
cjennjr's Avatar
2005 SL500
I STAND CORRECTED!!!! Just finished installing the HID's and man, are they bright!!!! I purchased the 8000k headlights since I have led parking lights that matches them. Easy installation, plug and play, and I am totally satisfied with VVME!!! Will post pics soon!!!
Old Sep 11, 2011 | 06:12 PM
  #124
04mbc230's Avatar
2006 C230 Sedan
Length?? I had no problems with mine since day one. Installed as it should be.
Do you have a non bi-xenon headlight? This is for a non bi-xenon, if you had bi-xenon, then you need something else.
It should fit.
Old Sep 12, 2011 | 02:37 PM
  #125
cjennjr's Avatar
2005 SL500
It should fit.
They fit!! I just had to set them correctly in the slots. I also purchased and installed my 8000k HID fog lights. Very easy, and all my lights match!!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
