Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
- Mercedes-Benz C-Class AMG: Common Problems
Important information to help you understand your Mercedes-Benz
Common suspension noises and solutions
'13 F10 535i / '05 W211 E55
Great post and I'm glad someone posted this. My front suspension is going to **** it seems with the squeaking. Car is always handled with extreme care but the morons at my off-campus apartment thought it's a good idea to put dual metal speed bumps.
![action](https://mbworld.org/forums/images/smilies/action1.gif)
2002 Mercedes Benz C230 Coupe
Hi guys...have a quick suspension question related question for ya.
When I go over a speed bump at a moderately high speed, and when the front wheels "land" after the bump and the cars weight presses the front suspension down, I hear a loud click from the front left wheel area. Its only a single click...
I figured it might be a loose end link, but tightening both ends hasnt resolved the problem. Any suggestions on what to check next?
2006 ML350 back from dealer after 4 weeks,now back for oil consumption test!,2003 C230 Sport
Anyone know were squeaks can come from when turning steering wheel? It only happens when temp is low. I just had $1000 worth work done to the front end.It seem like an on going battle with the suspension on these cars.
They were replaced only about 2 months ago...there is no lateral or vertical play in the wheels. That is supposed to be a test of all suspension components...which is why im lost for ideas.
I completely agree...Ive just learnt to live with some minor squeaks, etc for now. Seeking perfection like when the car was new can get very $$
#34
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
My car has always been crawled over speed bumps. My suspension is holding up fine.. I had a very thorough inspection done on it a couple of months ago and they could find no problems even at 98,000 - said even the end links were fine.
#35
06 C230 SS 6spd
I would also suggest going over the speed bumps at a lower speed. I have to do it the lowered car way and at an angle or fine another way around. I do not like hearing the sound of my cf lip scrapping.
#37
Thats an anomaly! Pretty much everybody local who owns a W203 has had all control arms/bushings/end links replaced at least once. Some up to 3 times within the first 100,000 miles.
Maybe its the driving in the crazy snow with wheels constantly spinning out of control that causes pre-mature failure, or maybe the extreme cold kills rubber bushings faster...
#38
Agreed! I just want to make sure I catch major issues before they become major...but for now this is a non-issue. The only time I go over bumps at anything more than a crawl is when I dont see the bump till the last minute lol.
#39
If its a rubbing/scraping noise, check the dust cover just inside the wheel.
If its a vibrating kinda noise (which you can also feel), check the inner end of the upper and lower control arm (the spindle joint). The busings are probably worn.
#41
LOL nice description!
Yeah I dont think suspension noises are worth fixing until it becomes a major issue, because they will never go away fully...from my experience!
I recently had the upper and lower (front L & r) control arms, l & r endlinks and rear bushings replaced. Suspension still knocks and ticks randomly :S
#42
Nothing replaced. The thorough inspection of every single part by my indy mechanic didn't come up with anything that needs to be replaced. Everything is fine. I don't have any noises, vibrations, uneven tire wear, alignment issues etc.
#43
I am now having a problem with my 03 coupe's front suspension. The front left wheel at times feels like it's hopping. When making left turns or applying the brakes. Going straight down the road, it feels fine. My front end has had no problems until this. The car has 134,000 miles. Any thoughts?
#45
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
There is another good reason to take it easy over speed bumps - to preserve your Cats.
The biggest single cause of premature Cat failure is going over speed bumps fast while the catalyst is incandescent.
#46
Super Moderator
#47
Hi Glyn, The tires look ok. This problem just started in the last 2 weeks and the snow tires I have on there now were put on the first week of December, so that might be why there is no cupping.
I jacked up the car to check the suspension. Everything feels solid. The lower control arm bushing has some minor cracking on the edges but no sign of a leak. You may be onto something with the damper strut.
#48
Super Moderator
Inadequate damping of the wheel allowing it to bounce instead of remaining in contact with the road. Do a quick read up on shock absorbers & their function on the internet
#49
Super Moderator
#50
Good to know! People get annoyed with me sometimes in parking lots because I literally crawl my car over speed bumps at <1mph
