Old 06-15-2015, 02:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
Print Wikipost
Replacing Tensioner/Idler pulley on 1.8L C230
Rating: Thread Rating: 3 votes, 5.00 average.
Old 09-17-2010, 08:24 PM
  #51
rsxnut1's Avatar
2005 C230 Sport Sedan
Originally Posted by capt_paul
I just finished the installation of the new (rebuilt) alternator. The one removed was a Valeo (as opposed to the Bosch alternator). It would be interesting if all the alternators removed from the cars with the squealling problems were due to Valeo units.
Anyways, no more squeals!
Do you really need to remove the radiator hose and fan? I'm wondering if I could get away with removing only the air intake hose and silencer... That should provide enough room to work.
Old 09-17-2010, 10:27 PM
  #52
rabney72's Avatar
C230
Probably, but the extra 10 minutes ate well worth it. The more room the better , although supposedly the alternator comes out the bottom so you may not need to remove anything but the bottom cover...
Old 09-18-2010, 01:07 AM
  #53
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You need to remove:
air intake crossover tube
wideband silencer
sepentine belt
lower engine cover
disconnect neg battery cable
disconnect the electrical connector and cable from the back of alternator
remove the two upper alternator bolts from on top
remove the two lower alternator bolts from the bottom
(I removed the foward inner wheel liner for more access)
Remove the alternator through the top
Reverse to install
Old 09-18-2010, 07:40 AM
  #54
rsxnut1's Avatar
Thanks guys, I pray this works!
One interesting note, when I had the car on ramps I could not duplicate the noise, but I could still feel the vibration.
Old 09-18-2010, 11:27 AM
  #55
KillerPancake's Avatar
2005 C230K coupe
For those with alternator and/or pulley issues, what sort of mileage was on your cars when the problems started?
Wondering when my time will come...
Old 09-18-2010, 12:12 PM
  #56
rsxnut1's Avatar
57000 miles is when the noise started.
Old 09-18-2010, 02:13 PM
  #57
seagel1000's Avatar
05 C230 Kompressor
Finally replaced the Idler pulley and the tensioner pulley. I believe the noise went away for when the A/C is on and I have my vehicle on D or R.
I did what rabney did, except I did not remove the fan nor the radiator hose (just because I already did my coolant flush and re-fill almost a year back. Did not want to do it again.
My rough idle is still present lol
Old 09-18-2010, 02:14 PM
  #58
seagel1000's Avatar
05 C230 Kompressor
Mines started at 55-60K mi, little here and little there.
Old 09-18-2010, 02:53 PM
  #59
rsxnut1's Avatar
So you skipped the alternator? If the alternator is bad, do you think the load will wear your new pulley prematurely?
Old 09-18-2010, 05:03 PM
  #60
seagel1000's Avatar
05 C230 Kompressor
I'm not sure if it will cause premature wear on other pulleys. I'm mainly aiming at fixing my rough idle issue. Which I'm beginning to think it has something to do with the Throttle Body. Who knows, it might be the alternator.
Old 09-18-2010, 05:27 PM
  #61
rsxnut1's Avatar
I had a rough idle due to a vacuum leak. Did you have the $12 hose replaced?
Old 09-18-2010, 10:45 PM
  #62
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The throttle body in NLPAMG's 2005 C230 was bad and caused a rough idle. At the same time he had an EECS CEL but I don't think the rough idle ever caused a CEL. You should definitely try the throttle body.
My car is knocking on 90,000 miles with none of these issues.
Old 09-19-2010, 10:57 AM
  #63
rabney72's Avatar
C230
You know, I still get somewhat of a rough idle but again, only when in d or r, ac on and not moving. The motor dips down to 600rpm due to the extra load on the motor, but when in park it idles smooth as can be.... Weird car. That rough idle includes the supercharger area to vibrate pretty good...
And I replaced the alternator and had that service call done on that little hose... I wondering about a dirty mass air meter?
Old 09-21-2010, 12:28 PM
  #64
seagel1000's Avatar
05 C230 Kompressor
Same problem as you bruh. It idles semi rough even on Neutral or Park (worse when on D or R).
I know NLPAMG had the same issue and his fix was replacing the TB. I just don't want to go spending carelessly with out knowing the real cause. I've spent a few hundred dollars doing some of the stuff already. Alternator is another 200 and TB, well who knows.
Old 09-21-2010, 06:57 PM
  #65
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
I know the throttle body is like $1k from the dealer but you can get it rebuilt for $250. Then again i have a c32, it might be cheaper for the other models.
Old 09-21-2010, 07:58 PM
  #66
seagel1000's Avatar
05 C230 Kompressor
No way man! Wow.
Well I got this quote from this site that sells used MB parts from a lot for $115 shipped.
Any one on here willing to do a quick swap for TB's? I'm not sure how much time and labor is involved in doing this...
Old 09-22-2010, 07:58 PM
  #67
rsxnut1's Avatar
Originally Posted by rabney72
well I haven't had much time to do a write up.
Follow the instructions in this post (scroll down), up to step 6. And disregard any a/c related steps.
https://mbworld.org/forums/c-class-w...placement.html
Pretty much the tools you need are:
- 3/8" and 1/4" drive socket wrenches
- 10mm, 7mm, 8mm, 13mm socket
- a 3/8" gear wrench is ideal for the bottom two bolts of the alternator (get from the underside)
- two different torx female sockets (i'll get the size of them later) for bolts like on the idler pulley, wideband silencer bracket, frame support (that goes over the radiator) as well as the alternator bracket
- the special "tamper resistant" t50 male torx with the .15 hole in the center for the tensioner pulley
-t60 torx to release the belt tensioner
- needle nose pliers and a skinny flat head screwdriver to release the rings off of the radiator and intake hoses.
That should be about it. Once you get to step 6 in those instructions, it should be fairly straight forward, just removal of the components...
If you need further detail, I'll try to figure out how to post instructions from the MB manual...
Or just call me...
512-563-5359
Do you have keyed torx sockets for your 3/8" gear wrench? Or did you just use a 3/8" box wrench?
Old 09-24-2010, 07:00 PM
  #68
rsxnut1's Avatar
Just finished the alternator and idler pulley... No more noise, and the alternator was a valeo.
Old 09-24-2010, 08:55 PM
  #69
infected's Avatar
2007 ML500
Congrats!
Old 09-25-2010, 09:20 AM
  #70
rabney72's Avatar
C230
No actually the 3/8" 12 point closed end of a standard ratcheting gear wrench fits that torx bolt perfect... 6 out of the 12 points must be the same as the torx
Old 09-25-2010, 10:19 AM
  #71
Lexani1217's Avatar
E350 4D 4Matic - 2012
infected- your theory seems to be 2 for 2 so far. you dont seem to have gone wrong on changing the alternator.
should we replace the idler pulley at the same time though?
Old 09-28-2010, 11:05 PM
  #72
rabney72's Avatar
C230
Might as well
Old 01-26-2011, 11:18 PM
  #73
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
Valeo & Bosch
Is there a different pulley we have to get if we change from our original Valeo to a Bosch alternator?
Old 01-27-2011, 12:36 PM
  #74
seagel1000's Avatar
05 C230 Kompressor
Does it not come with a Pulley with the Bosch alternator?
Old 01-27-2011, 12:53 PM
  #75
aolsen's Avatar
I think it does, but according to alldatadiy.com it says "Confirm correct length of pulley, long pulley for Valeo and shorter pulley for Bosch and Valeo, refer to EPC (Figure 4). Install new pulley and tighten with the socket counterclockwise to 80 nm . Use a torque wrench that functions in both directions. Install new plastic cover on end of pulley.
It then shows the image I attached.
Also, note it says "long pulley for Valeo, and shorter pulley for Bosch AND Valeo" - would that mean that the shorter pulley would work for either alternator? Lol...confused.
If we get the correct pulley, would the belt fit fine without any further changes besides getting the correct pulley?
Attached Thumbnails Replacing Tensioner/Idler pulley on 1.8L C230-pulleys.jpg
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Replacing Tensioner/Idler pulley on 1.8L C230
