Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
- Mercedes-Benz C-Class: Why are my accessory belts noisy?
Guide to diagnose trouble and recommended solutions
Replacing Tensioner/Idler pulley on 1.8L C230
So I just got around to working on the car.....got the alternator pulled and the idler pulley. I need a special driver to remove the tensioner pulley...and why has everybody been saying to replace the entire tensioner bracket when the pully can just be removed?..See pic
![Replacing Tensioner/Idler pulley on 1.8L C230-tensionerpulley.jpg](https://mbworld.org/forums/attachments/c-class-w203/382749d1542322028t-replacing-tensioner-idler-pulley-1-8l-c230-tensionerpulley.jpg)
![Replacing Tensioner/Idler pulley on 1.8L C230-frontmotor.jpg](https://mbworld.org/forums/attachments/c-class-w203/382750d1542322028t-replacing-tensioner-idler-pulley-1-8l-c230-frontmotor.jpg)
![](http://i649.photobucket.com/albums/uu212/rabney72/alternator.jpg)
I also have to say... the alternator pulley and idler bearings both feel good. I have a bad feeling that the culprit is the compressor (supercharger)...But I hope Infected is right and my car will be squeak free by the end of the week
#32
05 C230 Kompressor
Let me know how it goes bro! I'm anxious to see what's up! It looks like you removed the idler pulley. The bracket belongs to the tensioner pulley (correct me if I'm wrong though)
#34
#35
rabney72, where did you find just the pulley for the belt tensioner? All the parts places I looked-up, they sell the entire tensioner assembly... none of them sell the pulley itself.
#36
05 C230 Kompressor
According to his new response this morning, he bought the whole assembly but only ended up using the pulley. He pulled it off the assembly and installed it alone (avoiding the hassle of removing the SC & anything required to replace it).
#37
My rebuilt alternator that I ordered should be here today. I previously replaced the idler pulley and the tensioner pulley was good, so I am leaning towards the alternator on being the cause of the noise.
I am going to hold on to the alternator once it is pulled off and if we can show MB that it is a common issue on the 2005 C230's, perhaps we can get compensated for the replacement.
I will be so glad once the screech is gone.
#38
Btw the Torque spec for both pulleys is 25N-m.
#40
2005 C230 Sport Sedan
I have the exact same symptoms, but the rattle sounds like it is coming from under the airbox . I'm tempted to just replace the alternator, but it looks like a pain!
![action](https://mbworld.org/forums/images/smilies/action1.gif)
#41
05 C230 Kompressor
Any chance you can post up quick instructions on how you replaced each part (tools, procedures, etc.)? *You also mentioned a T-50Torx with .15" drilled hole in the center of? (what was the purpose of drilling the hole?)*
I'm going to try and tackle the pulleys this weekend.
#42
#43
Hey rabney
Thanks![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
#44
05 C230 Kompressor
Sure but it'll be this afternoon. The purpose of the hole is because the bolt head on the tensioner pulley is a "tamper resistant" that has a cylindrical boss in the center of the torx pattern, so in order to mesh to it I had to drill a hole. Btw they sell these tools but often not in that large of a head size (t50).
I'll have to drop by Harbor Freight to pick up some tools.
#45
well I haven't had much time to do a write up.
Follow the instructions in this post (scroll down), up to step 6. And disregard any a/c related steps.
https://mbworld.org/forums/c-class-w...placement.html
Pretty much the tools you need are:
- 3/8" and 1/4" drive socket wrenches
- 10mm, 7mm, 8mm, 13mm socket
- a 3/8" gear wrench is ideal for the bottom two bolts of the alternator (get from the underside)
- two different torx female sockets (i'll get the size of them later) for bolts like on the idler pulley, wideband silencer bracket, frame support (that goes over the radiator) as well as the alternator bracket
- the special "tamper resistant" t50 male torx with the .15 hole in the center for the tensioner pulley
-t60 torx to release the belt tensioner
- needle nose pliers and a skinny flat head screwdriver to release the rings off of the radiator and intake hoses.
That should be about it. Once you get to step 6 in those instructions, it should be fairly straight forward, just removal of the components...
If you need further detail, I'll try to figure out how to post instructions from the MB manual...
Or just call me...
512-563-5359
Or just call me...
512-563-5359
#46
I just finished the installation of the new (rebuilt) alternator. The one removed was a Valeo (as opposed to the Bosch alternator). It would be interesting if all the alternators removed from the cars with the squealling problems were due to Valeo units.
Anyways, no more squeals!
#47
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Anyways, no more squeals!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
No Valeo radiators or alternators have ever been fitted here because both Behr & Bosch have plants in SA to support our local content program. Noisy alternators are not a common occurrence here.
Pleased the noise is gone.
#48
