- Mercedes-Benz C-Class: Why are my accessory belts noisy?
Guide to diagnose trouble and recommended solutions
Browse all: Engine Diagnostics
Replacing Tensioner/Idler pulley on 1.8L C230
Hey RABNEY thanks for posting your idea about just pulling the tensioner pulley instead of having to take off the whole thing. I had been driving with a horrendous scratching noise for months. I went ahead a bought the idler pulley and the whole tensioner but just replaced the idler pulley and the pulley fron the tensioner. The noise is now gone. When I took off the belt. I was able to spin the alternator pulley and I put tension on it up and down and side to side and it felt pretty smooth. I also spun it and it continued to rotate on its own for a while everything felt smooth with no noise or binding anywhere. The idler pulley felt a little weird when turning it and putting pressure on it. I compared it with the new one and the new one felt very smooth. Once out I rotated the idler pulley while putting pressure on it and I could feel the bearings slightly change friction when compared to the new one. The pulley on the tensioner felt fine but I went ahead and replaced it anyways. For anyone doing this. When taking off the idler pulley and replacing make sure the side that has the little square cutouts in the plastic behind the shaped metal spacer goes towards the front, the smooth plastic goes towards the engine. I replaced it backwards and the belt didn't sit right. So far I'm happy with the results, lets see how long it lasts. I still get the weird noise when cold coming from the suppercharger but its the same sound my other supercharged car has so that sound is probably normal.
I want to fix those idler and tensionner pulleys but dont wanna mess my car up to the point where it's rendered useless.
Any input?
If anyone can provide instruction on doing both pulleys, thatll be great! The idler looks easy. It seems like a simple screw at the center of the pulley is all you need to remove. The tensioner pulley is what's got me scratching my head. Don't even know where to start. Excuse my text if it's not spaced, I'm using my iPhone which fails to space words typed at times.
-Chris
problem was caused by seizur of alternator pulley, then belt tensioner go broken and idler pulley was changed for good measure, fortunately no damage for AC compressor!! thanks guys
Hope this helps take the fear off some people with the "1000" dollar alternator price tag
Any questions at all, PM me. It was just like everyone on this thread is describing. Thanks again.
Dave
Dave
I have that LOW IDLE issue . So you just replaced that bearing on the alternator and it fix the idle issue? I need to fix that .. its annoying when I stop at stop signs.
In my case, the seized ADP bearing on the alternator on cold starts was causing my low idle issue because of the load placed on the the belt. The seizing tensioner pulley and the older idler pulley was also cause excess load contributing to the low idle. I believe there was another thread related to this one where one member said that when the engine heated up the low idle and the screeching went away. That also happened to me. I supposed because once the engine compartment heated, it also heated all of the grime inside of the bearing to allow it to move freely enough to operate at a normal enough level. Let me know how yours turns out.
if/when my car starts chirping, i'll keep that in mind. Thanks for the post.
Do you think I should try changing the entire tensioner? (part #2712000270)
Alternator pulley?
Thanks!
I have a 2005 W203 C230 Kompressor sedan (US).
Alan.
Alan.
Hold the shaft with a Torx bit, use the special spline tool to unscrew the pulley.
BUT, the pulley itself is about $60, plus the tool...
After a while, I bet you will have to replace the voltage regulator due to its age. Another what, $70?
A reman alternator costs about $120-180.
I was also on the fence, and considered replacing only the pulley, but ended up just replacing the whole alt due to age considerations.
UPD. Ok, he doesn't specifically say he did not remove the alt, but he kind of implies:
https://www.youtube.com/watch? v=wIc3g2e5y7E
The new pulley solved the squealing noises.
I did have to pull the alternator out, but not too bad this time, 15 mins out, and 20 mins in.
