Difficulty in prising off the center speaker grille
I have a C230 Kompressor Sport which clearly has a blown center speaker (which I deduced by using the fader and panning everything to the back/far left/far right etc. to get rid of the distortion coming from the center). Once the center/dash grille is off, it should be a fairly simple case of replacing the little speaker underneath. The problem is, the best way to cleanly remove the grille without causing any damage.
I've seen pictures here showing the center/dash grille removed so I know where the clips that hold it on are located. One suggestion was to prise it of using a thin flat screwdriver but the space around the edge is so tiny that I can't imagine doing this without leaving some kind of indentation in the surrounding dash. I have a tiny carbon-steel pulling hook which I've tried using to prise it up via the perforations at the very edge near where I know the clips are. However, while I can pull it up about half an inch (and I'm convinced a little more pulling might pop the clip successfully) each pull leaves a upward bubble in the grille and I'm worried that the little extra force required might actually rip through the perforation and tear the grille.
Has anyone done this and can share the best way to get this grille off?
Many Thanks
Chris
p.s. Congratulations on a fantastic forum!
Excuse the terrible top picture - that is not my car - that's a dirty mess!
Are you sure you have a center speaker? It doesn't say what year C230 you have. Do you have the Bose system (01-04.5) or the HK Logic7 (05-07)?
And for the general forum knowledge - the standard, non-premium systems do not have speakers in the center dash or in the rear shelf. They have 2 tweeters on the front doors and a regular speaker in each of the 4 doors (sedan).
Adding it back in is one of the few mods I've done on my '06. As Glyn says, it's very useful to have. It keeps the center vents from blowing in your face.
That is a SMALL little speaker.. Or is it just the picture?
For now, I've ordered a decent set of thin non-marring tools and I won't proceed any further until they arrive (my nylon bowl scraper just wasn't cutting it and I don't have the nerve to even try a metal knife). The dash is in impeccable shape and I'd really like to keep it that way.
Thanks again. I'll let you all know how it goes.
Chris
The speaker is part# A203 820 72 02 which I now need to order (any suggested good sources in the U.S much appreciated). I can also see the problem described by lkfoster as the speaker is pretty firmly held on with one-way lock-tabs/washers which dig into the plastic pins on either side. Does any have a reliable method for removing these without breaking the pins? Even if there's a safe way to cut them off, I'm pretty certain I could find replacement lock tabs and long as the pins are intact.
For now I've just disconnected the speaker connector underneath and put everything back together. The distortion is completely gone so at least I'm sure that replacing this speaker will solve all my audio problems.
Thanks again for all your great advice.
Chris
Anyway, long story short. The lock washers are cheap base metal, bend them back and forth a few times and they'll snap. That will leave the posts in good condition for the new ones. You should be able to pick up new lock washers at a hardware store (not big box) or a friendly car audio store.
As for the speaker, if the glue dried out you can buy a speaker repair kit and re-glue it. Or you can just buy a new one. I ordered mine from the dealer ($$ mistake), I've been getting pretty decent prices from a different dealer with an online presence. I'll send you the site in a PM since I don't want to upset any mods. I looked up the part number you posted and they have it for around eighty-eight bucks.
BF JC230: What is a PTS screen?
