Tires Alignment question
Will it be the same results going to Firestones's Alignment shops vs going to a Mercedes Benz dealership?
I was planning on buying the lifetime alignment package from Firestone offered around $165 versus paying the dealership about the same for 1 alignment. A note to keep in mind, I have no aftermarket suspension components installed on my vehicle. All stock.
Thanks for any inputs.
Chris
Chris
i would wait awhile for the firestone lifetime alignment... they are always coupons floating around for them for 30-60 off
Hmm, the BMW guys don't seem to think it's a good deal: http://forum.e46fanatics.com/showthread.php?t=549499
My 2nd local shop in Downey, they said they could do it no problem. So I'll see.
An alignment shop that can't set castor & camber is not an alignment shop's a$$
I lived in the US for a long while & every alignment shop I used had a decent alignment machine capable of full 4 wheel alignment.
This is the minimum that an alignment shop should be capable of. My car in humble little Cape Town. Greater Cape Town would have about 50 machines capable of this.
or if you want pretty pictures of a bent car
Any chance you have the specs for the coupe?
https://mbworld.org/forums/c-class-w...ent-specs.html
Can anyone validate?
"Yes, the guide being referenced should do the trick.
Here's what I know:
Front Toe: 0 degrees 11' minimum to 0 degrees 21' max. Best to get both wheels as close to matching as possible.
Rear Toe: 0 degrees 17' min. to 0 degrees 24' max. This is less critical as long as both sides are reasonably close.
Front camber on mine varied from -.12 degrees to +.29 degrees, and it seems fine.
Rear camber varied from -0.92 degrees to -1.00 degrees on either side.
In addition, to cure a persistent pull to the right, we settled on:
Left Front Caster: 9.51 degrees /// Right Front Caster: 9.76 degrees
The small caster difference completely cured the pull. The slight toe-in and camber variances in front seem to have caused no problems - I rotate the tires about every 3000 miles, and they are wearing perfectly evenly and are still balanced and smooth at nearly 18,000 miles.
Hope this helps."
