Radio skips when i hit a bump???
Old Apr 21, 2003 | 09:04 PM
Tai230K's Avatar
2011 E550 Sedan
MY C-coupe's radio has been skipping whenever i hit a bump on the right side... i asked the customer rep what's the deal and he asked a tech.. he said the cd and the radio are connected so they will skip together... sounds like total BS to me... i understand if the CD changer skips but the radio???... any suggestions on what the real problem is?... wires???
Old Apr 21, 2003 | 10:00 PM
Matt230K's Avatar
2010 C300 4matic
No idea what the problem is, but the radio does not skip. Take it in and make them fix it.
Old Apr 22, 2003 | 05:44 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
There is a loose wire somewhere in your system.
It could be that the amp is shutting down (protection) when one of the speaker leads is shorting, or the amp is shutting down when the power line loses connection. It could also be internal in the radio, etc.
Either way, radios don't skip, and the dealer rep blew it on this one. Advice: let him figure it out.
Old Apr 22, 2003 | 11:43 AM
Tai230K's Avatar
2011 E550 Sedan
I brought it in last week for something else and i mentioned it to him that my radio was skipping.... he asked a technician... the technician told him that the radio is connected to the Cd changer so both will skip..... i'm suppose to go back this week to replace a 2nd cd changer... i'll tell him that...
Hey MAtt230K... Do you work in a mb dealership??
Old Apr 22, 2003 | 11:49 AM
KompMan420's Avatar
C230K
Have you tried changing the timing belt in the radio?
Old Apr 22, 2003 | 11:51 AM
Avrex's Avatar
Skip
See my thread "COMAND problem". Having a similar uncommanded audio interupt. Tried the COMAND reset with no luck. Suspect a loose connector. The comment that the CD and Radio will skip together sounds like nonsense--something loose!
Old Apr 22, 2003 | 11:56 AM
Tai230K's Avatar
2011 E550 Sedan
haha hmmm i dunno lemme go change it...
Old Apr 22, 2003 | 12:30 PM
Buellwinkle's Avatar
Try taping pennies to the radio's record player arm. This will help the needle track better and reduce skipping.
There was a TSB a while ago about the radio going on and off by itself while listening to it. The problem was a fiber cable between the radio and cd changer that was too short.
Old Apr 22, 2003 | 12:46 PM
Matt230K's Avatar
2010 C300 4matic
Yeah, you got a question?
Old Apr 22, 2003 | 12:49 PM
Tai230K's Avatar
2011 E550 Sedan
no just wondering i remember you said something about your dealership and stuff..... yeah are you a tech or a customer rep?...
Old Apr 22, 2003 | 12:53 PM
Matt230K's Avatar
2010 C300 4matic
I'm a lot tech, if that counts as a tech.
I'll be graduating college in June, and hopefully they'll offer me something better. Or else I guess I'll leave.
Old Apr 22, 2003 | 01:01 PM
Tai230K's Avatar
2011 E550 Sedan
haha kewls... sounds like a plan!
Old Apr 22, 2003 | 09:46 PM
SynergyC320's Avatar
C320 Sports Coupe
Hehe, I like the suggestions I have read =) Timing belt, pennies, etc! What they told you makes absolutely no sense at all! I work in the autosound business, and believe me, the CD changer has nothing to do with the radio cutting out.
As a couple people have mentioned, a loose connector is usually the cause of the problem. I have personally seen brand new vehicles do this because a connector wasn't "clicked" in all the way during production. Simply finding the connector and pushing it in until it locks usually does the trick.
Couple questions:
1) Has anything been altered? A pair of aftermarket speakers installed incorrectly could short when you hit a bump (improper wiring) and cause the amplifier to shut down momentarily. This is rare, however, with factory installed speakers.
2) Does the radio itself shut off also, or just the sound from the speakers? If the radio shuts off (no display, etc) then you are more than likely losing power to the radio, and that will narrow down your search. If the radio display stays on while the sound is gone, then i would check the speakers and/or amplifier.
Hope this helps some =)
Cris
Old Apr 22, 2003 | 10:06 PM
Tai230K's Avatar
2011 E550 Sedan
nice sig SynergyC320 !.... i'm pretty sure the pennies was a joke... if not WOW... haha.... the timing belt well... yeah
Well i haven't modified anything audio in my car... i'm assuming it's a loose wire somewhere.... the sound just skips for about 2 or 3 seconds.... i'm bringing in the car tomorrow for a cd changer swap and i'll tell my dealer rep again... hopefully he'll give me another prognosis of the situation...
Old Apr 23, 2003 | 01:36 AM
C320 Sports Coupe
Ok if the speaks are all stock, then you can pretty reliably rule out a short in those connections, and if any of them were loose, it would only affect that particular speaker, nbot all of them. Which leaves the head unit or amp. If the lights go out on the radio when the sound cuts out, its the head unit harness. If not, well it could be either =) But more likely the amp connection. Good luck with it! If its under warranty, I would just let them sweat it out anyway!
Cris
Old Apr 23, 2003 | 09:24 AM
mikeedward's Avatar
C230
I had a similiar problem with my radio. It appeared to skip when the radio was on or the cassette or the CD. I found that the fiber optic cable was loose on the radio end. I click it in and the prblem disappeared.
Old Apr 24, 2003 | 11:15 AM
Avrex's Avatar
Mystery Solved
At least in my case! The intermittent audio pause is a design COMAND feature when the intergrated phone is installed. If a voice message has been rcvd, but not cleared, the system will pause the audio every three minutes for five seconds until the msg is cleared. I can't find a clear description of this in the manual, but the dealer knew instantly what was causing the interupt. Skipping of the audio when a bump is hit, is another issue and is probably a loose connector.
