NEED HELP TRANS LEAK FROM PAN AREA!!
Old Oct 13, 2010 | 06:24 AM
mercedescoupe77's Avatar
2002 c230 Mercedes Coupe kompressor
Hello everyone, I bought a 2002 c230 kompressor coupe and it has started with a transmission leak...The seal has been supposedly replaced at dealer along with filter and fluid...I have taken it back once already they said they checked but couldnt find where leak was coming from they cleaned underneath completely now the next day I literally myself get under the car and took pics and this is what I found! I know I should of taken pics originally but I gave the dealer the benefit of the doubt and hadnt done so..So my question is what other possible causes can cause a leak in pan?The service manager had told me that they will go in again and check the seal that had been replaced...my fear is that is is due to something else???Please help me my husbands on deployment in iraq and this really sucks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!: smash:
Old Oct 13, 2010 | 08:06 AM
Glyn M Ruck's Avatar
Super Moderator
It looks like the rear transmission tail shaft seal is leaking. Tell the dealer to fix it properly. Don't pay again.
It could also be the pan gasket but I think not.
Old Oct 13, 2010 | 08:17 AM
Super Moderator
Number 100 in this diagram. If it's not that then it's the pan gasket. Don't panic. It's an easy repair for the dealer. Tell them to wake up & do it properly.
Attached Thumbnails NEED HELP TRANS LEAK FROM PAN AREA!!-722.6-output-shaft.jpg
Old Oct 13, 2010 | 11:48 AM
97W202's Avatar
2006 C230 6speed/14 C63
glyn is the man
Old Oct 13, 2010 | 11:53 AM
Xhale707's Avatar
C320 2002
Ill go with you to the dealer to raise hell... You got a nasty looking leak there.. Looks like a river flowin.. Take those pictures with you to the dealer.. and be like you fixed my leak?? Whats this
Old Oct 13, 2010 | 01:17 PM
97W202's Avatar
dude shes married
jk jk
Old Oct 13, 2010 | 02:16 PM
Thanx Glyn I took it back this morning!
Well, I took the car back this morning, and I showed the pics to the service manger. He then said to leave the car for the whole day and they will redo the pan gasket but hopefully it isnt anything else inside instead. So Glyn you think it is that seal in the diagram?? Well I dont know what all is involved with those internal seals and parts but I hope this doesnt turn into a big old mess! At what point should I tell them no to repairs? If the leak doesnt stop??? What do you think the pricing will be like to have this type of problem fixed?
Old Oct 13, 2010 | 03:25 PM
97W202's Avatar
it shouldnt be too bad, did u payfor the first "fix" ?
if you did, then they have to keep trying till the get it right.
Old Oct 13, 2010 | 05:03 PM
Super Moderator
I can't comment on US job pricing, but the seal requires them to remove one end of the propshaft, undo the center nut, pull off the flange, pop out old seal & put in new seal & reassemble. It's an external job. Not very difficult.
Old Oct 13, 2010 | 05:52 PM
talked to the dealer again while ago!
Ok so he basically said that they replaced the gasket again and they are keepn it overnite to drive for a number of miles and tommorow hopefully it was just the gasket I'm just not familar with the terminology of the parts of the trans so I feel very lost right now any suggestions???
Old Oct 13, 2010 | 05:57 PM
Super Moderator
If it is not the pan gasket just tell them to replace the rear gearbox oil seal. Let them test it tomorrow & see if it still leaks. Don't worry - we will help you through this.
Old Oct 14, 2010 | 08:15 PM
To Glyn: Flourescent dye??
I called another shop that works on mercedes porsche and bmw and they said they would help me if I continiue to get no where with the dealer..They told me to make sure they redo their work though..thats the thing they say they only do the gasket and fluid I hope they didnt create the leak or made it worse... it was them that told me i HAD the leak in the first place..anyway this other place told me they normally put a liquid in the fluid to trace with a light where it is coming from what are your thoughts on that?
Old Oct 14, 2010 | 08:27 PM
Xhale707's Avatar
C320 2002
ahhh I hope they didn't put fluid in it to STOP the leak.. Don't worry the dealer has your car it should be safe..
Old Oct 15, 2010 | 06:14 AM
Super Moderator
We have been on PM. They have done the pan gasket twice & it is still leaking so it must be the seal. I don't know why they don't just replace it.
Flourescent dye and a UV lamp can certainly help trace leaks but I think this one is pretty obvious - i.e. the rear seal.
Old Oct 16, 2010 | 05:47 PM
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
+1 - had a similar issue with my C32 a couple of years back, and the the rear seal was the culprit. Thankfully they tried this straight after the pan seal so i only had one extra trip back to the dealer. They did charge me for both jobs though, tran flush, and rear seal replacement.
Old Oct 16, 2010 | 06:02 PM
Super Moderator
Dealer has admitted it's the rear seal - given the good lady a loaner - Agreed to pick up the cost.
Old Oct 16, 2010 | 06:42 PM
97W202's Avatar
again, glyn your the man.
Old Oct 16, 2010 | 06:49 PM
Super Moderator
The dealer says it would have cost $900 robbers!
Old Oct 16, 2010 | 06:52 PM
97W202's Avatar
for a seal?!
their called stealerships for a reason...
