Sponsored by: Red Tiger
headlights comming on when light out??
Old Oct 13, 2010 | 09:19 PM
contact148's Avatar
2003 c240 4matic wagon
Ok im in Canada and have DRL cannot turn them off by cluster! im talking all my lights not DRL
my switch is set to auto
anways i noticed last night about 6pm est when i started the car the lights all came on. the dash lit up and such it was still very light out I turned the switch to off but everything stayed on was in park e brake was on.
turned engine off set switch to off turned power on via key (engine off) switch worked i could turn lights on and off. started car same as 1st time lights on cant turn them off (dash lights)
put flashlight on light sensor they turned off so it works
this morning 9am started car lights came on right away it was sunny out about 5c after about 2 mins driving lights turned themselves off
NOW I dont recall the lights ever being on when it was light out so wtf???
windshield is clean NO work/changes done to cause this
any ideas??
Old Oct 13, 2010 | 09:38 PM
samaritrey's Avatar
Super Moderator
THE C350
do what i do set lights to be on all the time and ignore it lol
Old Oct 13, 2010 | 11:04 PM
contact148's Avatar
ya we dont have that setting otherwise id do that!
Old Oct 14, 2010 | 02:05 AM
samaritrey's Avatar
Super Moderator
THE C350
really thats strange another guy from Canada said he used it too. God Mercedes had to change everything over the years.
Old Oct 14, 2010 | 07:10 AM
Glyn M Ruck's Avatar
Super Moderator
Light sensor getting a little cranky - Just leave it on Auto & forget about it. Make sure that there is no mineral or silicone deposit build up on your screen in the sensor area. It will usually screw with the rain sensor first if you have one.
Old Oct 14, 2010 | 08:58 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
There is an adjustment that can be made to the light sensor in STAR, but I have found it's range of adjustment seems very limited. Mine comes on when it is light out too. I have had 2 windshield replacements, and this last one the light sensor just doesn't work near as good as the last ones.
Old Oct 14, 2010 | 09:48 AM
Super Moderator
+1 - Does the damn thing make any difference at all? A very pernickety friend of mine used to check his with a Minolta light meter & drove MBSA mad trying to calibrate it to his satisfaction. As far as I'm concerned as long as lights are on well before dark it's OK.
Old Oct 14, 2010 | 03:53 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Take it to the dealer.
Old Oct 14, 2010 | 04:33 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
any ideas??
What youve described is normal on Canadian cars. The headlights cannot be turned off when the engine is on (regardless of the position of the switch or if its night or day).
When your instrument cluster is not lit, but the low beam headlamps are, thats DRL mode (daytime). When the low beam headlights, city lights and instrument cluster are lit up, thats full headlight mode (night time).
When its gloomy (like at 9am est today in Canada ), the car cant decide if it should be in DRL mode or headlight mode, hence it switched on headlights, and then switched them off after it figured out that there was enough ambient lighting to not need headlights.
Old Oct 14, 2010 | 04:44 PM
zerocover's Avatar
2007 C280 4Matic
My lights turn on and off several times during a given drive to or from work. They turn on through tunnels, under cloud cover, and if the sun is at my back, I always thought it was a safety feature so I can be spotted out in a sea of glare.
I'm banking on the light sensor only being sensitive to a certain UV spectrum of light, as I have problems when the lights don't turn on in the rain. (I have to reach over and turn the switch whats up with that )
