help
i knw i have to change the pads and replace the brake sensors.
but what bout the esp and abs nonsense.
For the first problem, replace pads, you will be good to go.
For the second problem, you will need to diagnose further to identify which (out of the four) wheel speed sensor is causing the light to come on. You will need to replace that sensor to resolve the problem.
Thats odd that your other sensors went off..
Did any other errors turn on?
Did did your car lose the ability to shift gears?
Did this problem happen after your lights turned on?
Do the errors reset after restarting?
Do you happen to have any electrical aftermarket equipment installed near your ECM? Maybe a HID kit or something? I know a ballast near the ECM can cause the same problems as "limp-mode" and even throw an additional 6 other errors.
2. Holy allgetout, man! Never mount the ballast on anything electrical on your car! The ballast gives off waves that damage the unit, put simply. ESP failure due to ballast mounting too close has happened to a few around here.. mounting it directly on the unit is asking for trouble. I would move the ballast to as far as possible from anything electrical, and I know you can mount them on the wheel wells, as I did the same. There are even some tabs that were conveniently on the wheel well that helped keep the ballasts further secured.
If the codes don't go away, I would unplug the battery and reconnect in 5 minutes. Your car will be uncalibrated when you reconnect the battery, so recalibrate your windows and sunroof, and your steering sensor will be off. So, as mentioned above, turn your wheel lock to lock several times and restart your car. Codes should be gone for the esp/abs failure, but if they still persist, you may have put damage to the unit.
Good luck!
