Phister's car thread
Old 04-05-2012, 06:38 PM
  #1101
SkankZ's Avatar
2006 C230 SS
Originally Posted by phister
Fronts have 10mm spacers and rears have 5mm spacers so I'm running +15 all around. I never cut coils I'm on BC coilovers with #1 pads in the rear. If your coilovers dont drop low enough for you I'd recommend ordering a set of swift springs or eibach springs to replace them. They offer custom coilover springs to your specs. Going to install my eccentric bolts and it'll give me 2 degrees of adjustment and I plan on going the full -2.
Never knew you could replace the coilover springs with another springs! Good To know.
That's insane (the aggressive fitment). It paid off really well. I should grow a pair and just start pulling my fenders and making my rears flush, instead of trying to get rid of the wheels. I like the way they look but I just didn't like how the front sticked out. Your wheels put me to shamed and made shut up about it poking out
Old 04-05-2012, 08:03 PM
  #1102
RedStripe's Avatar
2010 SLK350
Skankz -
You've sure got some mods planned for a car that I thought you were selling!?
And yes, Phi is the man.
Old 04-05-2012, 08:40 PM
  #1103
SkankZ's Avatar
2006 C230 SS
Haha! It's a bad habit when I have money or offers that interests me.. I can't help it. I blame phil for his car, making me want to go do tuff to my car too! Basically whatever comes up first. I found rear bumper for my car but I need the fronts now.
Old 04-06-2012, 02:09 AM
  #1104
phister's Avatar
06 C230 SS 6spd
So I got a chance to do a quick lowering, did another inch and my fenders are feeling it lol I was wearing down the liner, smelt like burning rubber on the highway. Gonna raise it up about 1/2"to clear. It was painful turning.
Old 04-06-2012, 02:25 AM
  #1105
I_C_Class's Avatar
W204 C350 4matic Coupe, W203 C320 4matic, W212 E550 4matic
Interesting style! I like it!
Old 04-06-2012, 08:40 AM
  #1106
phister's Avatar
06 C230 SS 6spd
So here's some pics of the front dropped another inch. I have to roll the driver side fender now cause when I turn left its basically tire on fender and its pushing it out further. hopefully a little fender rolling and a "slight" rise and it should be ok to roll. I was scraping my lip on every dip and bump.
YES! thats a piece of the liner on the tire lol
Old 04-06-2012, 08:46 AM
  #1107
kluvsbenz's Avatar
2014 E350, 2006 C350 Sport(made it to 280k, loved it!), 1990 300E
Real low!!! It looks soo damn good that sometimes you want to ignore the rubbing
Old 04-06-2012, 08:55 AM
  #1108
phister's Avatar
06 C230 SS 6spd
lol true but I'm gonna "make" it work! just some rolling and a very very slight rise.
Old 04-06-2012, 12:15 PM
  #1109
Moderator Alumni
TruTaing's Avatar
w203 m112
Roll the front, raise the rear to match! Call it a day! SOOO Sexy! I already feel bad for your front lip though! :P Great work my friend. Great work!
Old 04-06-2012, 12:17 PM
  #1110
mskembo's Avatar
2010 Mercedes-Benz E350
I may add your statement "YES! thats a piece of the liner on the tire lol" to my signature! That cracks me up! It looks tough, I just know that I'd destroy my car if I did that. However it is time for shocks, and I think that means it's time for coil-overs...
Old 04-06-2012, 03:29 PM
  #1111
phister's Avatar
06 C230 SS 6spd
ok raised the front just a hair, straightened up the camber just a hair, and rolled the fenders more. Finally got clearance from lock to lock. Had to straighten up the camber some because the inner tire was rubbing against my perch on the coilover. So that was the burning smell driving, made a pretty good groove in the tread. But I got it dialed up now so no more issues, HOPEFULLY, no rubbing sounds or smells on the test drive.
Old 04-06-2012, 03:30 PM
  #1112
phister's Avatar
06 C230 SS 6spd
coilover it up MIKE!!!
Old 04-06-2012, 03:46 PM
  #1113
mskembo's Avatar
If you still have the Tein's we need to talk...
Old 04-06-2012, 04:10 PM
  #1114
phister's Avatar
06 C230 SS 6spd
sorry I dont... theres a member name jerkin selling his teins with only 8k on them
Old 04-06-2012, 04:25 PM
  #1115
mskembo's Avatar
I'll check him out, thanks.
Old 04-06-2012, 05:20 PM
  #1116
I_C_Class's Avatar
Hooooly cow! thats extreme! props to you man
Old 04-06-2012, 06:22 PM
  #1117
RedStripe's Avatar
2010 SLK350
Considering that the rear fender is physically longer that the front, you're actually sitting perfectly flat, if not with a slight rake, in regards to front-back, arent you?
I've never seen a w203 so LOW!! And I usually don't like seeing them that low, but man Phi - you've really got a great combination going here. Looks phi-tastic.
Old 04-06-2012, 09:33 PM
  #1118
phister's Avatar
06 C230 SS 6spd
I actually do have a rake. I measured from the fender to the ground and it has a pretty good rake. If it was flat the front would be quite a bit higher.
Old 04-07-2012, 01:14 AM
  #1119
RedStripe's Avatar
2010 SLK350
Yeah, I figured - I mean, it sure looks like it has a rake if you ignore the wheel/fender gap (or negative gap in your case, lol).
I was just asking out loud about it because Tru kept asking to bring the butt back up in the air, but swore I was still seeing a rake if you ignore the fenders.
Old 04-07-2012, 02:04 AM
  #1120
phister's Avatar
06 C230 SS 6spd
It looks like that because of my camber in the rear. They tuck in the rear some so it looks deceiving. If I adjust my rear camber to the fronts it'll be pretty even and show as much tire as the fronts. But then it'll be full on rubbing in the rear. I gotta cut some liner off in front and rear or let the tires do the work.
So I can go from lock to lock without fender touching. I'll post a pic of my final setup later.
Old 04-07-2012, 03:31 PM
  #1121
StillNDADIRT's Avatar
2002 C230 Coupe
I'd like to see some pics of the BC's mounted up in there
Old 04-07-2012, 04:03 PM
  #1122
phister's Avatar
06 C230 SS 6spd
it probably looks like your bc installed lol... I'll do it when I have time
Old 04-07-2012, 08:46 PM
  #1123
2002 C230 Coupe
I haven't had time to finish installing mine yet because I'm working out of town right now. I just want to make sure i've got them adjusted right.
Old 04-08-2012, 12:28 AM
  #1124
phister's Avatar
06 C230 SS 6spd
They have so much adjustment its just up to you
Old 04-08-2012, 04:52 AM
  #1125
phister's Avatar
06 C230 SS 6spd
Oh forget to tell everyone I'm selling (10) 45mm lugbolts and (20) 50mm lugbolts.
Quick Reply: Phister's car thread
