Transmission sequentronic - WONT SHIFT GEARS!
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jan 16, 2011 | 04:05 PM
  #101
vakity's Avatar
R171, SLK, 200K
Thanks Кaro, I did what I wrote in the instructions, but again the error goes to low pressure, I took a friend of a hydraulic pump that works for sure. in this error STAR wrote to replace the pump, it did, the other component B56 pressure sensor ... Tomorrow I order it and change it ... Unseen what else I can already do almost everything I've disassembled, examined, cleaned or whatever is needed .. .. . .. ..
Old Jan 16, 2011 | 05:02 PM
  #102
Glyn M Ruck's Avatar
Super Moderator
vakity - I think there is little doubt that our problem is hydraulic. Maybe pump wear or just air. From what Karo has posted it is not clear to me how we get all air out of hydraulic system. Maybe the system is designed to automotically get air out by repeated gear changes manually but it is not well explained in pdf's from WIS.
Karo - can you see if there is anything in WIS that explains how to change & replenish the hydraulic fluid.
Old Jan 16, 2011 | 05:37 PM
  #103
vakity's Avatar
R171, SLK, 200K
Glyn, and I do not find in WIS procedure to expel the air. But here I am interested tray see the picture, I guess that makes it ..
Attached Thumbnails Transmission sequentronic - WONT SHIFT GEARS!-detailed-view.gif
Old Jan 16, 2011 | 07:25 PM
  #104
W203E35's Avatar
2006 C350 Sport 6MT
Transmission does not shift
Here you go gentlemen. Check out this PDF.
"Transmission does not shift"
Glyn, these are the only documents that WIS has on the SEQ.
Old Jan 16, 2011 | 07:41 PM
  #105
Super Moderator
Yes - That looks like a bleed nipple
Thanks Karo - I think vakity has found at least one bleed nipple. One should keep the fluid reservior full and you have to get all of the air out of any closed hydraulic system for it to function properly.
I would have expected an air bleed method in "Remove/install hydraulic unit"
Hmm! - from that last pdf. of yours looks like the pump relay is inclined to fail. If it failed the pump would not work. From what vakity explains the pump is working but the pressure is low. This should be air or a worn pump with excessive internal leakage. It might be the pressure sensor sending nonsense to the TCU.
Old Jan 16, 2011 | 08:41 PM
  #106
W203E35's Avatar
2006 C350 Sport 6MT
That makes perfect sense.
Old Jan 18, 2011 | 05:48 PM
  #107
Super Moderator
vakity - how are you doing?
We have another similar problem - I think we should all work together to solve.
https://mbworld.org/forums/c-class-w...-workshop.html
Old Jan 19, 2011 | 04:09 AM
  #108
W203E35's Avatar
2006 C350 Sport 6MT
Any update on this bro?
Old Jan 19, 2011 | 05:22 AM
  #109
vakity's Avatar
R171, SLK, 200K
I ordered the battery and pressure sensor, told me that running kit. Waiting for them to arrive from Germany by the end of the week, otherwise they cost here for me is around 200 Euro. I hope that these problems be solved.
Glyn, I saw the topic seems to be the same problem.
See something interesting on the exit of air:
Vaki
I bled mine prior to installation by sucking oil into the piston chamber by expanding the release bearing assembly and then pushing the remaining air out through the oil line by pushing the assembly back again. I did this procedure several times until no more air was visible. When the gearbox was back in but before the tailshaft was reconnected I then started the engine, put the transmission into 1st gear to make sure hydraulic pressure was applied to the release bearing and cracked the bleed nipple to expel any remaining air. When cracking the bleed nipple, fluid rushed out and the engine immediately stalled due to detecting out of range values so I performed this again being careful not to open the bleed screw too much. Really its just like bleeding your brakes.
Cheers, Iggy66
Old Jan 19, 2011 | 05:49 AM
  #110
Super Moderator
Yes - it is very like bleeding brakes. We will wait for your parts to arrive.
Old Jan 19, 2011 | 06:18 AM
  #111
Super Moderator
See other thread
"Ah! another edit - That hose goes back to the valve body so it's part of the hydraulic pressure system & not an air vent. So the pressure reservoir must have a pressure valve in it that vents hydraulic fluid back into the pump circuit. Failure of that valve would PREVENT PRESSURE BUILDUP! We might have to replace the pressure reservoir!"
Old Jan 19, 2011 | 07:31 AM
  #112
vakity's Avatar
R171, SLK, 200K
Friends see it, there's a lot of useful information. However, it is in Russian language
LINK
Old Jan 19, 2011 | 08:04 AM
  #113
W203E35's Avatar
2006 C350 Sport 6MT
Paruski ni panimayu but it's great info. I'll have my parents translate it to me. Page 52 has great pictures.
Old Jan 19, 2011 | 08:10 AM
  #114
vakity's Avatar
R171, SLK, 200K
Yes! exactly
Old Jan 19, 2011 | 08:20 AM
  #115
Super Moderator
Great - I will try & work my way though that & see what I can understand. Cutaway of pressure accumulator!!! is there.
Old Jan 21, 2011 | 02:35 PM
  #116
vakity's Avatar
R171, SLK, 200K
Friends, thank you very much for your help! Problem is solved! Now go back as you write!
Old Jan 21, 2011 | 03:14 PM
  #117
Super Moderator
What did you do? - change sensor & bleed hydraulics????? Then set up with Star?
Old Jan 22, 2011 | 03:31 AM
  #118
vakity's Avatar
R171, SLK, 200K
Changed the battery and the pressure sensor, which was not very easy to remove without gearbox but it did. Then run STAR and learn them. Everything went absolutely without any problem. Just do not understand the battery or the sensor was the problem. Thanks guys!
Old Jan 22, 2011 | 06:12 AM
  #119
Super Moderator
I'm pleased for you Must be sensor sending bad information to TCU.
How did you make sure that there was no air in the hydraulics?
Anyway - now you know you have a good gearbox.
Old Jan 24, 2011 | 02:58 PM
  #120
vakity's Avatar
R171, SLK, 200K
Yeah right now I've got really a good gearbox. Tomorrow I expect to arrive hydraulic oil / Pentosin CHF 11S /'ll spew and bled the system. And I hope to have no more trouble with it!
Old Jan 24, 2011 | 04:03 PM
  #121
Super Moderator
Good!
Old Jan 24, 2011 | 06:36 PM
  #122
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Excellent. Now you can post a video of the Synchortronic in action.
Wishin' we had that!
Old Jan 24, 2011 | 06:45 PM
  #123
Super Moderator
Todd - have you been into California's fine grape??
Sequentronic
Old Jan 27, 2011 | 09:32 AM
  #124
W203E35's Avatar
2006 C350 Sport 6MT
Vakity, I'm glad you fixed your problem. Now you have a great tool too (STAR).
Old Jan 27, 2011 | 01:08 PM
  #125
Sequentronic
Let's see, you are +10 hours ahead of me, which means it's about 2am where you're at. I think you be hittin' the wine bottle yo-sef son.
By the way, had nice bottle last night with dinner.
2006 Stonestreet Legacy. The restaurant had a special for 20 bucks.
I just had a feeling about it, was pretty sure I'd heard of it, but not sure where.
85% cab + some other stuff, that a good sign...
Turns out it's a $85 bottle. They totally screwed up.
We're not complaining. It was excellent.
I used a restaurant.com coupon, we had lobster and a nice ribeye with
blue cheese and pancetta, and got out the door for $85 including tax and tip.
Not easy to do these days.
http://www.stonestreetwines.com/wine...cy/legacy.aspx
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
