Help Transmission Leak (01 c320)
Old Dec 30, 2010 | 08:16 PM
Ribo89's Avatar
a Tank
Exclamation Help Transmission Leak (01 c320)
Happy New Year EVERYONE!!!
I have a 01 c320 with only 27,000 miles. A week ago i discovered a few drops of unknown fluid on my garage floor. Today i looked under the car and the transmission pan is covered with what appears to be oil. I checked the engine oil plug, but its not leaking.
I think the transmission pan gasket or the o-rings (http://installuniversity.com/mb/w203...on-o-ring.html) are the problem.
1. What do you guys think might be the problem?
2. Where should i take the car to get it fixed? (I live in Chicago)
3. How much will it cost to fix at the dealership?
-Dan
Old Dec 30, 2010 | 09:54 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
clean up the trans pan and the surrounding area and check again few days later. Depending on where the trans fluid is leaking from (pan gasket, drain plug, or the electrical connector), you can order the necessary parts and fix it.
Dealer will probably charge you one hour of labor to identify the source of the leak.
Old Dec 31, 2010 | 06:50 AM
Glyn M Ruck's Avatar
Super Moderator
Identify the leak - Buy the parts from RMeuropean or Parts.com. Take it to an Indy for fitting if you don't want to do it yourself.
Old Jan 1, 2011 | 03:08 PM
Ribo89's Avatar
a Tank
THANKS ALL FOR THE RESPONSE!!! Happy New Year!!!
I found a good Indy shop that will do the inspection for free. http://midwestperformancecars.com/ After the inspection i will see if i want to do the job my self or let them do it.
Old Jan 8, 2011 | 05:45 PM
Ribo89's Avatar
a Tank
They replaced the transmission pan gasket, the adapter plug, filter, fluid. Also motor oil and filter. Final Price was $322. I think i got a REALLY GOOD DEAL!!
Old Jan 8, 2011 | 05:59 PM
Super Moderator
That's a good deal!
Old Jan 8, 2011 | 06:01 PM
Xhale707's Avatar
C320 2002
What ATF Fluid did the put in your car?
What Oil did they use for your car?
Looking at all these bills ppl pay it stuns me!!
If they used the correct stuff they forgot to charge labor lol
Old Jan 8, 2011 | 06:42 PM
Ribo89's Avatar
a Tank
LOL...i forgot to add i got a $100 DISCOUNT for the new CUSTOMER......
$75 for the ATF Fluid-the MBZ bottle one
$17+10+23=50 for the transmission pan gasket, the adapter plug, filter- ALL OEM
$80 for Oil and Filter-5W40 Mobil 1
