is it just me or?? problems with shifter/synchros
at complete stop, when i depressed the clutch, I cannot enage into 1st gear as if it was blocked, I must wait a second or two before I can "easily" slide the shifter into first.
So at the stop light, if I want to start the car immediately I must go to other gears like the 3rd before I can engage 1st gear with ease.
anyone else has this problem?? should I go to the dealer?
So, I always move the shifter toward second before I engage first.
Finally I got sick of it and I mentioned this during the Service B, the teach that checked the car was very thorough and serious. He confirmed the problem and tried a lot of things. He then bled the tranny fluid according to the TSB and this alleviates the shifting problem now. I cannot say it shifts well, but better than before.
If you plan to have your car checked at Smythe I can give you a contact and the tech's name.
Well my c230 is in the service for a new alternator and they are also checking my 1st gear. I will post what they say about it when i get it back on tuesday. There was no problems with 1st gear on my car till i got it back from service after a head gasket replacement. Now no 1st gear. go figure.
they top off the transmission fluid for you?
