1st Mercedes which c-class which one?
Old 01-26-2011, 12:48 PM
  #101
cpbeasley's Avatar
"annoyance" and "self-righteousness", amoung others...
You'll want to reset the throttle adaptations. It'll wake it up.
Turn key to "on" position, don't turn it over. Press accelerator pedal and hold for a full 5 seconds. Keeping foot depressed, switch key to off position and then release your foot. Some do this as often as every week to keep the throttle from adapting at all. However immediately you should feel a difference as the ECU isn't making judgements based on the previous driver's driving style.
91 octane is what is required. Without a tune, 93 is probably a bit of a waste.
Run some techron (MB reqd) fuel injector cleaner through it unless you can fill up at a chevron station regularly.
If ever in a spirited mood and throttle hasn't been reset, you can tilt shifter to the left and it will downshift to the lowest gear possible. It will shift at redline.
With the 2.5L, you really need to rev the crap out of it to harness its full potential. It's geared rather poorly considering the lack of low end umph.
Old 01-26-2011, 01:58 PM
  #102
ravex911's Avatar
bmw 335 2009
Awesome advice. Had no idea you coudl even do that. I'll try this as soon as i finsih work.
I think my fuel stations mainly have 87-89-93. Is 89 not recommended?
Old 01-27-2011, 04:05 AM
  #103
Super Moderator
samaritrey's Avatar
THE C350
91 or 93 only
Old 01-27-2011, 04:15 AM
  #104
henry418's Avatar
2006 C280 4Matic, 2011 E92 335i
Maybe I missed this but..
Why would you replace your 335i with a c-class?
Makes no sense honestly and no offense to the w203 ppl but I think people here would also agree with me
Compared to the 335, any c-class other than the AMG will feel lacking in many aspects. I've tried both the 350 and 280 engines and currently own 335i.
Old 01-27-2011, 04:19 AM
  #105
Super Moderator
samaritrey's Avatar
THE C350
he leased the bmw and wanted to buy a car outright since he has a baby on the way. Go back and read the thread
Old 01-27-2011, 04:21 AM
  #106
henry418's Avatar
Okay makes sense now. Thanks!
Didn't feel like reading the whole thread
Old 01-27-2011, 04:22 AM
  #107
Super Moderator
samaritrey's Avatar
THE C350
Wow
Old 01-27-2011, 04:28 AM
  #108
W203E35's Avatar
2006 C350 Sport 6MT
You can use 89. Use that until you find someone with STAR and have them bump up your timing to 93. Mine is set to 93 and I use 91....no problem at all.
Old 01-27-2011, 04:42 AM
  #109
Super Moderator
samaritrey's Avatar
THE C350
Oh yeah you can use 87 if you have to but if available use 91 or 93 for best restults
Old 01-27-2011, 06:10 AM
  #110
Super Moderator
Glyn M Ruck's Avatar
If you use 87 the ECU will spend it's life retarding the timing when the knock sensor detects the onset of knock - not good for performance or gas mileage - but it won't harm the engine. Better to do as Karo says.
These cars have very moderate ECU tunes to protect the engine.
Old 01-27-2011, 07:30 AM
  #111
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Only 93 is available in my area as premium. So I should have someone bump my timing to 93 octane?
Old 01-27-2011, 07:45 AM
  #112
W203E35's Avatar
2006 C350 Sport 6MT
Ask the member who just got STAR to do it . If you need instruction I can post it.
Quick Reply: 1st Mercedes which c-class which one?
