***Rear Camber Kit Sale***
Old 01-26-2011, 03:30 PM
Xhale707's Avatar
C320 2002
Originally Posted by ncmudbug
I think if you want to compare quality, you need to compare the specs on the rod ends on both kits. The picture isn't clear, but it looks like they could be rubber isolation type rod ends where Ghostrider's are spherical rod ends.
Spherical rod ends are more precise (they are what are used in race cars), but some say they are prone to wear from dust and grit - I hope not because that's what I have on my Lotus! Others say that the compression pre-load fit between the the ball and the race tends to wipe the grit away so it doesn't get to wear it out. Again, rod ends vary quite a bit from brand to brand and applications within the brands. Higher load rating generally translates to higher pre-load and thus tighter fit between the race and ball. Some people who are really worried about grit getting between the ball and the race wrap the joint with tape. I've also seen rubber boots.
The rubber isolation type rod end would absorb shock and vibration a bit better, though I don't notice any adverse effects from them on my Lotus. Like any rubber joint, the rubber can degrade from from use and then the question becomes, can you get more of them? I have seen joints like this from third party vendors, but the spherical rod ends are easier to find (for me, at least - though I've never looked for metric sizes).
I am not saying this is the case here, but sometimes the manufacturer will make their product prettier instead of making it better (it's cheaper to dress it up than make it better). Also, consider that it will be under the car and you'll never see it - and even if you do, it's unlikely that many other people will!
Just to look at the pictures of both kits, I don't see anything to suggest that either of them are made cheaply, they just took a slightly different approach. It all depends on the relative quality of the rod ends.
Thank you!
Old 01-26-2011, 05:42 PM
cpbeasley's Avatar
"annoyance" and "self-righteousness", amoung others...
Originally Posted by Xhale707
Well its true? Im not trying to be mean or flame. But i don't see 180 dollars worth of anything here.
So, do you now?
Old 01-26-2011, 06:03 PM
Ghostrider@P1 Performance's Avatar
CLK430
Originally Posted by C230 Sport Coup
Can I get them in blue? he he he.....
Of course!! But just for you...
Old 01-26-2011, 06:25 PM
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
Ghostrider, my tire/wheel is just a few mm's from the inside of the fender(pic below). Ive had to do a lot of fender work to get it to this point and don't really want to do any more. If i install these, does it pull the bottom of the wheel in or push the top of the wheel out?
Old 01-26-2011, 09:16 PM
Xhale707's Avatar
C320 2002
Originally Posted by cpbeasley
So, do you now?
Nope its still **** i don't wanna flame anymore on something hes trying to make some money on. Just by looking at both ill save up 30 more and have a blue rod hanging out my rear end. Bushings are there for a reason.
Old 01-26-2011, 09:27 PM
ncmudbug's Avatar
2005 C230K, 2016 Honda CR-V, '74 Lotus Europa
You are so very correct in your assessment and that's why I went away from the rod ends all together.
I misunderstood your kit. I thought yours had spherical rod ends. In that case, it looks like both kits are very similar in function. I agree that bushings are probably more appropriate for the road. I don't need them for my car, but I think I would lean toward your (Ghostrider's) kit. The blue is pretty, but the stark, no-nonsense appearance of Ghost's kit appeals to me (and I like to save $$). In the end you have to make yourself happy.
How much do you drive your Lotus?
Not as much as I would like.
I've have had some teething (it's a ground up rebuild with a lot of mods) and maintenance issues that have required two people and between my work and my buddy's schedule, it doesn't get worked on as much as I'd like. I WILL get it on the road for spring!!!
Old 01-26-2011, 11:16 PM
  #32
CLK430
Now that's a good looking car!! The kit moves the top of the wheel out, but in your case it is more than capable of moving the wheel in to get the clearance you need.
Old 01-26-2011, 11:24 PM
  #33
CLK430
To each their own, everyone has a look they are going for. Feel free to flame away, it reminds me of an old busted watch I had once - it was right at least twice a day...
Old 01-26-2011, 11:31 PM
  #34
CLK430
Awesome!
I started with the spherical ends, but moved to the bushings that I'm using now. The kit is pretty, but the prices actually range from $212 - $239 on ebay.
Old 01-26-2011, 11:40 PM
  #35
CLK430
Literally we miss having it this weekend by two days, huh? That stinks, oh well, I'll at least be there the following week, thanks for the invite. I'll probably go to see my folks this Saturday now that I think about it. Using his shop to install the new projector headlamps.
Anywa, I love first watch even if they are pretty proud of their eggs and toast
I've only been to the one in Westport, where exactly it is on SMP? Perfect location for me too, 15 mins away at best.
Do you want to plan on bringing the camber kit at that time for the exchange?
It is west on SMP, a little after the Commerce Bank. Sounds like a plan, I'll see you there!!
Old 01-27-2011, 01:12 AM
  #36
fookoo303's Avatar
2003 c240
how much are the bushings? and will they fit into a tvt design camber kit?
Old 01-27-2011, 09:37 AM
  #37
phister's Avatar
06 C230 SS 6spd
Payment sent I'll take more pics of them when they come in.
Old 01-27-2011, 10:13 AM
  #38
W203E35's Avatar
2006 C350 Sport 6MT
These will be needed when a vehicle is dropped correct? Ghostrider's looks more heavy duty to me than the painted ones. If this will be needed for a drop I'll definitely get one.
Old 01-27-2011, 11:34 AM
  #39
CLK430
$75 shipped to the lower 48. They should, unless your kit has used something different than a 5/8 rod end. To be sure, I would ask TVT.
Old 01-27-2011, 11:38 AM
  #40
CLK430
Thanks Karo!! Yes, these will allow you to get the rear back into factory alignment specs once your vehicle is lowered. It should also save you some time and money if you get these installed when you are doing your springs.
Old 01-27-2011, 12:46 PM
  #41
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
How about a group buy for $150 ? 10 sets?
I been needing something like this for a while but the cost of
parts, install, and alignment.....
It's been cheaper just to let the car eat tires.
Old 01-27-2011, 01:13 PM
  #42
CLK430
To be honest, between the cost of parts and shipping, the lowest I could group buy for is $170. Which is 15% off the original price.
Old 01-27-2011, 02:04 PM
  #43
Hmm.... 170....
and that would be in blue?
Old 01-27-2011, 04:33 PM
  #44
CLK430
Hmm.... 170....
Well..... Blue would be a 'special' order.
Old 01-27-2011, 04:44 PM
  #45
cruizecontrol21's Avatar
c230K
I had the top speed installed in my car and the rear end knocked like crazy. I thought at first that I only got a defective one and had it replaced. Same thing Knocking sound, I had to take it out and return it. To be fair I had the top speed on my W202 and it worked great.
Old 01-28-2011, 12:26 PM
  #46
CLK430
New pic
Here is what the complete kit looks like now:
Yeah, it may not be flashy but it works!!
Old 01-28-2011, 12:37 PM
  #47
CLK430
Update
1. phister
2. cpbeasley
3.
4.
5.
6.
7.
8.
9.
10.
Old 01-28-2011, 02:07 PM
  #48
Midnight Koop's Avatar
CL203
+1
Old 01-28-2011, 02:27 PM
  #49
phister's Avatar
06 C230 SS 6spd
I like how the body is a hex so you can use a wrench to hold it while tightening.
Old 01-28-2011, 03:03 PM
  #50
CLK430
Exactly!! Although I tell people to make the holes 12" on center and that usually puts the wheels where they need to be.
Quick Reply: ***Rear Camber Kit Sale***
