Hi pitch noise from the front wheel
Old Feb 1, 2011 | 01:26 PM
west_m's Avatar
2005 C230
Hi,
Can anyone tell me what's that hi pitch noise? I hear it more clearly if an object is near the driver side, the noise goes faster or slower if I increase or decrease speed. I was crusing at about 20 mph in the recording, sorry for the loud road noise....
http://www.youtube.com/watch?v=8cJVVAWdwSY
West
Last edited by west_m; Feb 2, 2011 at 12:23 PM. Reason: updated new video with less road noise
Old Feb 1, 2011 | 01:42 PM
e1000's Avatar
a quarter mile at a time
Can you hear it when the car is idling and you are standing in front of the car? What year is your car?
Old Feb 1, 2011 | 02:08 PM
west_m's Avatar
2005 C230
2005 C230, only hear that noise when the car is moving. I tried to look for that noise when the car is idle but nothing. Also, it comes and goes as well.
Thanks.
Old Feb 1, 2011 | 03:04 PM
AnswerSS's Avatar
2004 C230 Kompressor Sedan 6MT
Does it stop when you brake? If so, it means your brakes are low and the indicators are scraping to let you know this.
Old Feb 1, 2011 | 03:13 PM
west_m's Avatar
2005 C230
I still hear it when I brake. BTW, all brake pads were replaced last year.
Old Feb 1, 2011 | 03:35 PM
mskembo's Avatar
2010 Mercedes-Benz E350
Bearings...
Old Feb 1, 2011 | 03:50 PM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
I don't think that MB has squealers on the pads as they have the electronic sensor that is inserted into the pad
Old Feb 1, 2011 | 03:53 PM
AnswerSS's Avatar
Never knew that. Good to know.
Old Feb 1, 2011 | 03:54 PM
Boom vang's Avatar
Originally Posted by mskembo
Bearings...
bearings usually make a howling sound especially when putting on a load while cornering
bearings that squeal when they have run dry of grease
Old Feb 1, 2011 | 04:08 PM
Xhale707's Avatar
C320 2002
Just buy some high temp grease. take ur wheels off pop off the dust cap that are covering ur bearings. I believe an Allen wrench is needed to loosen the bolt. I greased mine up last year. i took mine off though and cleaned them
Old Feb 1, 2011 | 05:58 PM
phister's Avatar
06 C230 SS 6spd
do you have the OEM wheels on the car or aftermarket? But buy some grease and grease the bearings and you can also buy some spray lube and lube up your bushings on the suspension.
Old Feb 2, 2011 | 11:55 AM
pawe's Avatar
'05 C230
Oh my I hear the same noise on my car!
Its a rotational noise coming from the passenger front wheel. I know something is scraping but nobody can find it. (I took my car to the dealership twice for this problem and they cant find it)
I dont know if we have EXACTLY the same problem but this is what happens to mine:
Sound comes on when I hit 20mph but will disappear at around 40mph. I know its not a fan or something that will go off in a certain time or temperature because the timing is inconsistent. Sometimes I wont hear it when I slow back down to 20-30 and sometimes I will.
What I haven't checked yet is my brake sensor. Do they hang out of the brake pads that they may be causing the scraping with the wheels? What else do you think will produce a rotational noise? It doesnt sound like it comes from an internal part, more like the area of the wheel itself.
I know brake sensors are installed in the front passenger wheel but im just not sure if there are any wires poking out of it.
Old Feb 2, 2011 | 12:02 PM
west_m's Avatar
2005 C230
OEM wheels. If it's the bearings, do I have to take the rotor/caliper off to lube them?
Old Feb 2, 2011 | 12:35 PM
west_m's Avatar
2005 C230
By looking at the brake sensor in this photo http://i82.photobucket.com/albums/j2...oldsensor1.jpg, it actually hangs from the outside so I'm not sure if it's the sensor causing that noise.
Can you see anything in the brake component which can caused that noise?
http://forums.mercedesclub.org.uk/showthread.php?t=69528
I have uploaded a new video with less road noise, I agreed it's a rotational noise.
