View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Old Apr 7, 2005 | 04:27 PM
  #1476
ctC230K's Avatar
excites your girlfriend
Originally Posted by molarband
wouldn't they charge more for the tire? I would think it would just be cheaper to buy a new tire.
maybe but labor would be free, they would help you install it. i guess then it wouldn't be balanced though. hmm...
Old Apr 7, 2005 | 05:31 PM
  #1477
clkcadet's Avatar
S550
Originally Posted by Buellwinkle
If you have a physical problem with your tire, like there's a bubble that's about to explode as you put it, it should be covered under the Michelin warranty. They prorate based on treadlife and I assume that's OK because the other tires are usable. Just go to a tire shop that sells Michelin like Costco and see what they say. If for example the tire is $100 and they say it has 50% tread left and they honor the clain, they'll sell you a new tire for $50.
is this for real?? i have pilot sports what if they get torn up from curbs will they warrant that? luckily no bubbles are present but my left tire/rim has been curbed and a few chunks of tires came off
Old Apr 12, 2005 | 10:38 PM
  #1478
Iceman's C230's Avatar
09' BMW M3 E90
Will a 2002 C230 Winter tires fit a 2005 C230 sedan?
Hi guy's
Do you know if my Winter tires off the 2002 c230 will fit a 2005 C230 sedan. Same bolt patterns?
Thanks,
Old Apr 12, 2005 | 10:41 PM
  #1479
09' BMW M3 E90
Forgot to mention that my 2002 c230 was a coupe and the guy who want's them have an 2005 sedan. This is with the steel rims and the tires. I think the bolt pattern should be the same unless the brakes changed on the 2005?
Old Apr 12, 2005 | 10:44 PM
  #1480
essa's Avatar
05 C230K SS and 02 C240
Does the 02 C230 have sport caliper? If it doesn't then it won't fit. It's like trying to fit wheels from C240 to 05 C230
Old Apr 12, 2005 | 10:53 PM
  #1481
09' BMW M3 E90
My 2002 c230 had 17" wheels with evo package. My winters where on a 16" steels rims.
Old Apr 12, 2005 | 11:08 PM
  #1482
essa's Avatar
Not sure about the Evo package, but 05 C230k has a big front sport break caliper. When I had a flat, I tried to fit my 02 C240 16" steel spare wheel on my 05 C230K and it didn't fit. The bolt pattern is the same but the caliper clearance isn't the same.
Old Apr 12, 2005 | 11:09 PM
  #1483
FreeStylinSurfe's Avatar
yes, it will fit. 205 55 16?
Old Apr 12, 2005 | 11:33 PM
  #1484
essa's Avatar
Your steel rims must have at least 2" space from the mounting surface to the back of the spoke for them to fit otherwise the front won't fit ...I guarantee that.
Old Apr 13, 2005 | 01:35 AM
  #1485
09' BMW M3 E90
They are 4 PILOT ALPIN 205/55R 16H. Bolt pattern 112x5 on the steel rims. I don't know what the 2005 c230 sedan have. As brake calipers go i don't know if they are the same.
Old Apr 13, 2005 | 12:58 PM
  #1486
silberrosa's Avatar
The bolt pattern is the same. However, the brakes are not. They will not fit. The brakes on the Sport Sedans as of MY04.5 forward require 17" wheels.
Old Apr 13, 2005 | 09:51 PM
  #1487
essa's Avatar
[B]They will not fit!!!
Old Apr 13, 2005 | 10:01 PM
  #1488
ctC230K's Avatar
i could have told u that
Old Apr 13, 2005 | 10:19 PM
  #1489
09' BMW M3 E90
Thanks for the info guy's.
Old Apr 14, 2005 | 07:46 PM
  #1490
hittin160s's Avatar
2005 C230 Sport Sedan, Kompressor Engine, Brilliant Silver
Yes they will, but you have to remove the brakes from the vehicle all together, then they will fit. LOL
Old Apr 14, 2005 | 11:34 PM
  #1491
essa's Avatar
Old Apr 21, 2005 | 11:59 AM
  #1492
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Tire Size Calculator
What's goin' on everybody? My cousin told me about a great website that will help you identify what tires should fit as close as possible with whichever wheel size upgrade you go with. Remember, this is only for tires, but it is a good guage for knowing what you can switch up to when upgrading:
LINK: TIRE SIZE CALCULATOR
Old Apr 21, 2005 | 12:15 PM
  #1493
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Nice tip drex, thanks....
Old Apr 21, 2005 | 12:56 PM
  #1494
PsssTkiD's Avatar
'02 c230k coupe
nice but.. how is this http://www.1010tires.com/TireSizeCalculator.asp
Old Apr 21, 2005 | 01:05 PM
  #1495
drexappeal's Avatar
Originally Posted by PsssTkiD
PsssTkiD, this is nice also! Nice find!
Old Apr 22, 2005 | 03:13 PM
  #1496
PsssTkiD's Avatar
'02 c230k coupe
thank you..... i just got them all at google
Old Apr 22, 2005 | 07:11 PM
  #1497
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Who needs a calculator for that simple math. :p
Actually there is more to this than meets the eye. Why would MB on the W203 use a staggered setup of 225 front and 245 rear? Clearly the cheat sheets posted would suggest a 255 rear. Could there be a little more insight that would shed some light on this matter. This particular calculator goes a little more in depth as to what is involved.
Tire size calculator - German Only
Old May 17, 2005 | 06:35 PM
  #1498
MBSJ's Avatar
C230, C2, C7, Leather
Tire Change
I need to get the new tires. Front tires are ready for new ones. However rear tires are still good. Where should I put the new tires (rear or front)?
Old May 17, 2005 | 10:02 PM
  #1499
essa's Avatar
Hmmm... the rear on mine worn out faster than the front. I take it you don't have staggered fitment...than it should go to the front...because they control the car direction and do most of the braking.
Old May 18, 2005 | 01:08 PM
  #1500
Moxxon's Avatar
Flint Gray E63
If the tires are not staggered, most tire companies will tell you the new tires should go on the rear axle. Read the links below for more info...
http://www.tirerack.com/tires/tirete....jsp?techid=52
http://www.autonet.ca/autonetstories...m?StoryID=3691
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
