2005 w203 with m271 HELP!
I am burning oil and it seems like alot about a qt a month, so i decided to pull codes and none came up,
so then i decided to pull the plugs and cylinder 1 and 2 had oil dripping off the plugs and are pretty dirty and 3 and 4 were dry and clean... there are no oil leaks ... would it be a valve guide ,burnt valve, valve gasket....? and is there any way to tell what it is or if its one or the other---Thanks Cbond
My car has recently been having a stumble after sitting for 8+ hours. Today, after having sat for 36 hours, I let someone else use it and decided to go out there as they left. I heard the stumble as it started and so did they. Well, as they accelerated off right after starting up there was blue smoke. Not a lot, but definitely some.
Is it possible that oil leaking into the combustion chamber via the spark plug seals could be the reason for the initial stumble? In my head this makes sense. If so, that will soon be taken care of. I have a timing chain and tensioner in hand, just waiting on the valve cover and spark plug gaskets to come in. That will be fixed then.
Matt, I would guess that the oil your car is burning is likely valve stem seals. I might be valve guides, too. Certainly your Indy can help find the actual source.
[Sorry if we were "talking past each other". I was getting confused with who had what issue!!]
