05 C230 Komp DIY fuel Injector replacement
It looks like I'm going to have to remove the airbox...of course
But after that I don't really know the process. Any help?
Thanks in advance.
- Steve
Thanks in advance.
- Steve
people have? Yeah, I know it's a 2005, but I'd check the compression.
If it's not even, I'd blow some seafoam through it to clean the carbon off.
Did you switch up the coilpacks to see if the problem moved?
The stealer told me it was probably an injector. Hopefully its not compression. That will be my next step if replacing the injector doesnt work.
I heard about this "seafoam" stuff. How do you "blow some through it"? I heard a few good things about it but then others say stay away from it....I'm torn...LOL.
Its only got 36k miles on it so Im hoping its not the compression. That would be pretty sad for a MB.
I keep getting the same statement when I talk to a stealer about how much they charge for parts/repairs..." well, IT IS a Mercedes..." OK, well my statement back is..."yea, it is, with ONLY 36k miles on it".
I probably wont get the injector until next week sometime (in Hawaii) so when I'm under the airbox I'll check that $12 hose too.
This weekend = Transmission filter/fluid change, steering fluid flush
- Steve
where do you put the Seafoam to "blow it out"? I put about 1/2 a can in the fuel tank but was wondering if putting it in somewhere else?
Thanks for all the help. I'll be taking notes/images and posting a DIY for other members in the future. I want to do the compression test but it seems in Hawaii everything cost an arm and a leg. I fear how much its gonna cost for a damn compression tester.
- Steve
I have a problem with p171. I did the same thing like others did to call the dealer to check if the $12 hose got already repair on my 2005 c230. They said it done last year. I took it to my local shop to have they check, they found out 2 breather hoses and its check valve leaked. They showed me the collapsed parts before replacing. After they got the job done, they tested drive, and called me the Mass air sensor was also bad that set the light back on. I approved $450 part. They replaced and installed the new one. I picked it up, drove home but the light set back on after 15 miles from the shop. Took it back to have they look at it again. Defective sensor got replacement. They kept the car for 2 days to test. This moring they called to let me know there must be something wrong with the computer. Since they tested its emission, its result was gross polluter with both high HC and Co. They qouted the computer from dealer $2500. I got really upset and decided to get the car back to sell as is. Drove home, the car seem very smooth. I opened the hood to check what they had lately done to my car, I found couple disconnected air hoses hanging around the exhaust side. I saw the hoses ran from the valve on top engine to ? (where I don't know). Can you give me the picture showing where the hoses go to?
Truly thanks for your great help.
As far as the hose your talking about...I bet they forgot to reattach the hose coming from the top of the engine, towards the MAF. It connects to a round fitting after the MAF. Just follow the hose down past the MAF. There is a connection that the hose just slides over. If its a rubber collapsible hose, thats the one. I almost forgot to reconnect it today when doing the injectors.
Just to let you know, Most people that I know...Have gotten the same codes as I have and it ended up being the injectors. Some changed out all the injectors and never had an issue again, well until the suspension problems started....LOL.
What codes are you getting and I could possibly help you out. Ive done everything from change out the MAF, the coils, the plugs, add seafoam, and now changed out the injector.
- Steve
Thank you for your upload pics, I saw the hoses connecting from the black switch (valve?) under the engine cover to the metal valve in the 2nd pic but not sure which hose goes to which port. Can you instruct me, please?
Nc1wynot,
Thanks for you offer to help me out. The code printed out on my invoice receipt was p0171. I don't know how to repair it myself, and have no knowledge how to pull things out and put back in order good like you. All I need is to put the hoses back in place, then I can post to sell as is. It is not worth to spend more money in this car anymore.
Well, I changed out the injector and after a week the CEL cam back on. I am at the end of the rope. The compression test came out fine. I'm not sure what else it could be. The CEL only comes on if I end up sitting at a light for to long or sit in park running for more than 5-10 minutes. I get the same code, "misfire #2 cylinder"
Not to sure what to do next. Does anyone know How/where you put that Seafoam in to clean the engine? Can that be put in the engine? I ran some through the gas tank/fuel system already. The car seems to run fine until I get that damn misfire. I clear it out, and it runs great again.
Any ideas would be greatly appreciated. Thanks in advance.
- Steve
You need to check your fuel pressure.
https://mbworld.org/forums/c-class-w...ard-start.html
I don't think thats it but I'll check with another filter. I replaced it with an OEM filter but who knows. The car starts fine. just after running for a bit, idling it starts running rough and get CEL. The funny thing is, it doesnt happen all the time.
So Frustrating!
The next thing is going to be checking the engine harness. Have you had oil leaks from the cam sensors into the harness?
I just got my hands on a Innova diagnostic tool with a little better explanation to my problem.
Here is what it says:
Parameter Description Value
DTC for which Freeze Frame was Stored P0302
Fuel System 1 Status Closed Loop - fault with at least one oxygen sensor
Fuel System 2 Status Not Supported
Calculated LOAD Value 41.18 %
Engine Coolant Temp 154.40 °F
Short Term Fuel Trim - Bank 11.56 %
Long Term Fuel Trim - Bank 10.00 %
Intake Manifold Absolute Pressure 26.35 inHg
Engine RPM 2,447.00 rpm
Vehicle Speed Sensor 20.51 mph
Absolute Throttle Position 29.41 %
My question is...obviously its saying there is an O2 sensor thats bad, right? which sensor is it? and how would I go about changing that.
If thats not it, I am clueless....LOL.
Thanks again guys!
- Steve
I changed out the injector and i got no CEL for a few weeks.
It seems it only runs rough and gets a CEL when I turn the A/c or vent fan on. I'm not sure what this could mean. It runs great until i turn the fan on...then i get rough idle, CEL and codes for thermastat & #2 cylinder misfire.
ANY IDEAS guys? Thanks again!
before you start.
