Voltage Spike to 17.5???
Old Mar 2, 2011 | 04:08 PM
bigspender101's Avatar
2003 c230k
So in the mornings when its cold out it seems that my voltage spikes from 12 to 17.5 could this be a bad VR? interior lights and radio turn off for 5 or so seconds then turn back on. And sometimes I get the ABS warnings....
Old Mar 2, 2011 | 04:59 PM
03'55AMG's Avatar
AMG
Either the vr or bcm
Old Mar 2, 2011 | 05:20 PM
2003 c230k
I forgot to add, that I just put in a new interstate battery about a month ago....
Old Mar 2, 2011 | 05:33 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Voltage regulator mounted on the alternator.
Old Mar 2, 2011 | 05:47 PM
2003 c230k
Yep I know! Are you saying thats what it is PCY?
Old Mar 2, 2011 | 06:18 PM
pcy's Avatar
pcy
Yes, I am certain replacing the Voltage Regulator will take care of the issue.
Old Mar 2, 2011 | 06:24 PM
ontmiss's Avatar
2007 C280 4matic Avantgarde
+1
Old Mar 2, 2011 | 06:28 PM
ontmiss's Avatar
Just to add, I wouldn' even start a car before fixing, could burn lots of other things.
Old Mar 2, 2011 | 10:05 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by bigspender101
So in the mornings when its cold out it seems that my voltage spikes from 12 to 17.5 ......
Voltage where? How are you reading this? Have you put a VM directly on the battery during this period to read it?
Old Mar 3, 2011 | 07:38 PM
2003 c230k
Im reading it through the display on the dash....I push the reset button 3 times and it shows me the voltage..
Old Mar 3, 2011 | 08:50 PM
mleskovar's Avatar
'17 Jaguar XF
Did you put a meter across the battery at the same time to see if the reading was accurate? Since you're getting other weird failures maybe it's not your alternator but something else. Just trying to narrow it down.
Old Mar 4, 2011 | 06:25 PM
2003 c230k
Im going to take it in this next week and have my indy take a look at it. When he put my battery in he checked the voltage and it was fine. But the car was warm when he checked though. I might leave it overnight so he can see what i see most mornings....
