Good deal on sunroof lube, 0019895051
Old Mar 3, 2011 | 02:59 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Hey guys, I just bought a tube of that expensivo
MB lube for $20.
PN 0019895051 also known as Dupont Krytox.
I made an offer of $15 and got a reply for 18 + $4 shipping.
This is a great deal, and will help you save your Pano roof from very expensive problems.
See Click here for maint. documentation for your pano.
There are 3 types of lube needed, or according to MB just the 2, but
I use 303 Protectant on the rubber vs. the Krytox, it's much cheaper and keep the rubber nice, and from sticking to the glass.
Save the Krytox for lubing the tracks, and then
there's also some grease you need that can be purchased in
small film canister of "Glietpaste" since it's like 80 for a huge container from MB.
I'd suggest offering $5 or $10 and see what happens. I think he'll come back with a lower offer than
what I got. He's got 2 sealed containers left.
A tube of this stuff from the dealer is like $50.
Old Mar 3, 2011 | 03:38 PM
Xhale707's Avatar
C320 2002
The rubber on my sunroof is start to rip its start to **** me off. You can only see it when the sunroof is tipped up. It just looks like it needs some lube to stop it from splitting anymore. Ill take a picture in like 20 mins
Old Mar 3, 2011 | 03:42 PM
sknight's Avatar
c200k
Krytox? Hahah, they're charging that much for that? LOLOL.
Old Mar 3, 2011 | 03:49 PM
Hey there's a tube from Ferrari parts dept on ebay and they want like $300.
VW uses it too, and they want like $100.
It's a very special stuff, won't wash off with water.
Hey, if it keeps you from having to spend 2 grand from your
motor or gears getting f'd in the pano, it's well worth the $20.
I paid $10 for a film canister of the special grease.
As far as the rubber tearing, you'll need to glue it back together, I think use
rubber cement.
The body shop that fixed my door, glued up my torn door weatherstripping and it's still holding fast.
Old Mar 3, 2011 | 03:51 PM
Glue it and get the 303 protectant to keep the glass from sticking.
Put it on all your rubber stripping.
Old Mar 3, 2011 | 03:54 PM
sknight's Avatar
c200k
rubber cement.
Go to a bike shop and get ripped off there for the horrific price of $8. It's not that special. Trust me.
Old Mar 3, 2011 | 04:18 PM
Xhale707's Avatar
C320 2002
Alright will do thanks
Old Mar 4, 2011 | 02:06 PM
Why doesn't someone offer $5 and see what happens?
This stuff is like gold!
Old Mar 4, 2011 | 02:25 PM
Really? Whats the name of the product?
Is it pure oxirane trifluoro (trifluoromethyl)-homopolymer ?
he he, thats what this stuff is, also known as
Krtyox GPL105.
I think the properties that make it special are,
1. It doesn't melt till like 350C, actually thickens when it gets warm, and our
black pano sunroofs get hot.
2. It's specially designed not wash off.
There's even a warning:
Caution! This product cannot be completely removed using conventional cleaning agents or solvents (or in an automatic car wash).
According to Dupont:
Extends Service Life of critical components. Reduces down time and maintenance costs.
Sunroof repairs so get expensive, and people using some off the shelf crap, it melts and leaks onto the sunshade ruining it.
amanonfire's Avatar
W203
I've got almost 9 years on my pano roof and only use spray silicon lube after cleaning the rails/hinges twice a year. The roof gets used everyday at least 6 months a year without issue.
Old Mar 4, 2011 | 02:33 PM
Ah, you are lucky.
These pages are filled with tales of Pano roof horror,
and estimates in the thousand to fix.
That being said, i haven't had a problem LATELY, but my entire roof
has been replaced twice under warranty. Hence I have the little wind buffer nub, you can see it in
my sig pic.
I just want to make sure it KEEPS working, I have 166K miles on the car.
Extra strain on the motor can strip the gear and no one sells just the gear.
But one person did come up with a fix, put some washers in, apparently theres some rubber that supports the motor, and it gets mushed down, the gear doesn't engage properly.
Well, I haven't serviced the sunroof for a while.
Need to stop by West marine and pick up some 303.
BTW that keeps it from sqeaking too.
Then I'll have everything I need for proper maint.
One would think silicon would be enough since it dries and leaves little residue etc.
That being said I would buy the silicon with Kytox in it that I posted.
C'mon, someone offer $5 and see what he says.
That would be a great deal.
Old Mar 4, 2011 | 04:31 PM
sknight's Avatar
c200k
Krtyox GPL105.
I'm a chemist.
Old Mar 4, 2011 | 05:18 PM
amanonfire's Avatar
W203
So far it has worked like a charm. Last time the dealer lubbed the roof was 5 years ago, silicon spray ever since.
I have noticed that a lot of the binding happens on the flat pieces that push the deflector up/down. I may put some lithium grease on these since they are not rubber.
Old Mar 4, 2011 | 10:36 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
MB lube for $20.
Where'd you get this stuff from (i.e. who do I make the offer to)?
Old Jun 15, 2012 | 12:25 AM
sdlopez83's Avatar
2002 C230 k
I put this silicone bike bearing stuff all over the rails 3 years ago before I delved into the forums.
I am buying all the lubes listed but wanted to know if you guys could point me in the right direction as to finding the right degreaser to take the bike stuff off. Is there somewhere i shouldn't put the degreaser?
Old Jun 15, 2012 | 03:08 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Degreasers are generally bad for painted surfaces, plastic and rubber,...
You're probably better of just wiping off the old grease. Maybe use some soap and water.
Old Jun 15, 2012 | 04:14 PM
sdlopez83's Avatar
2002 C230 k
Gotcha, also off topic but i know you can use the 303 for the rubber molding on the pano. Can you also use it for the rubber doorseal as well. What can i use to condition that to prevent cracking in the future or do I just replace when the time comes?
Old Jun 15, 2012 | 05:09 PM
I'm a Canuckle-head,.... so I'm not very familiar with 303. I've never seen 303 sold in Canada. I've heard that its like WD40,..... which I would NOT recommend using on rubber seals since WD40 has a cleaning additive that will deteriorate the rubber over time.
Use a good silicon spray lubricant to keep your rubber soft and flexible. The Krytox 105 oil would be the best product to use but it's expensive thus should be limited to sunroof lube,.... and any really troublesome noisey rubber seals. Keep in mind silicon spray will last a few months whereas Krytox 105 will last years.
Old Jun 15, 2012 | 05:30 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I swear you're always finding all the good deals out there - first oil, now lube... o_O
Old Jun 15, 2012 | 06:55 PM
sdlopez83's Avatar
2002 C230 k
Just ordered 18 bucks worth of kryo on ebay . How much oil should be applied? Generous amount?
Old Jun 16, 2012 | 12:58 AM
SEARCH for C230_Sport_Coup's Pano Roof thread,.... there's a file on MB recommended point of lubrication in there. How much lubrication should be applied at each point? We're talking basically a drop at each point!,.... Krytox 105 oil is liquid teflon,.... use too much and you're just wasting liquid gold,... it's expensive! Whatever size bottle you brought, it should last you the life of the car and all your future cars,... seriously!
Old Jun 16, 2012 | 01:04 AM
sdlopez83's Avatar
2002 C230 k
Ah, many thanks sir, i suppose i could have looked instead of asked. Thanks for the heads up man.
Old Jun 16, 2012 | 04:58 AM
The last lube you'll ever need. Man, I been wacking off for a year on jusr one drop! Call today!!
Ha...kidding of course.
My friends owns a detail shop and recommended the 303 protectant.
Seems to work well on rubber seals and keeps it from sticking to the glass, which is the main point,.
so it doesn't strain the sunroof mechanism.
Old Jun 16, 2012 | 03:52 PM
mtnman82's Avatar
FWIW I'm a fan of the 303 protectant. I won't use anything else on my interior. I know the boating community uses 303 to protect the coverings/rubber on the boats, and you know how sun-baked that stuff gets. I've also seen it recommended for use on squeeky parts, like sunroofs, becasue it keeps the rubber from sticking to things. Good stuff!
I'd still like to know where to get the other lube(s). One of these days I'l lget around to replacing the bellows on the side of the sunroof - supposedly it's not that difficult?
Old Jun 18, 2012 | 03:41 AM
Yeah 303 in my application just for the rubber seals.
This avoids stripping the gears when you go to open it after it's been sitting in the hot sun and then cools.
I use Meguiars on the interior. And Lexol on the leather.
Did anyone think I was saying to use 303 on the guides? No.
