Headlamp Adjustment Screw
Old Mar 9, 2011 | 08:45 AM
Norwichdelta06's Avatar
2007 c230
This is going to sound like a sily question but the headlamp adjustment screw.... if you want to raise the headlamps do you turn clockwise or counter?
Old Mar 9, 2011 | 10:24 AM
billbillw's Avatar
2001 E55 AMG (sold)
Um, why don't you just aim that at a wall and just turn the screw? You'll figure out which way in a matter of seconds. You shouldn't adjust them without actually seeing the results anyway.
Old Mar 9, 2011 | 10:27 AM
phister's Avatar
06 C230 SS 6spd
I believe clockwise rises and counter lowers.
Old Mar 9, 2011 | 10:55 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I'm with Phil. But if we're wrong, I bet we could tell you what the correct answer is.
Old Mar 9, 2011 | 11:52 AM
2007 c230
I did that and it somehow didnt seem to move at all!! Is it possible those adjustment screwes can be stripped?
Old Mar 9, 2011 | 12:27 PM
phister's Avatar
06 C230 SS 6spd
are you turning the correct ones? its the one further down on the headlight. The screws might not be stripped but just off the nut, sometimes if you adjust it too much it'll fall off the adjustment bracket. you'll have to take apart your headlight and put it back on.
Old Mar 9, 2011 | 12:48 PM
2007 c230
i hope that doesnt happen!! And yes its the black plastic screw design.
Old Mar 9, 2011 | 01:02 PM
phister's Avatar
06 C230 SS 6spd
sounds like its not catching the adjusting nut then.
Old Mar 9, 2011 | 03:14 PM
BF_JC230's Avatar
2005 w203 C230
Yes...the UPPER screw (should be under a black tabbed cover) IS NOT FOR USA...it is ROW, and does nothing on a USA spec light...the adjustments, for up and down, should be molded into the headlight - and are on a lower level...I use a 1/4" (if I recall) nut driver to ensure a positive engagement...
Your w203 should also be level and back 20' or so from a wall to adjust...the height and break point is extremely important if you have xenon!
Old May 29, 2011 | 12:09 AM
Dingleberry's Avatar
Marsaydees
Wrong. See here
Old May 29, 2011 | 12:38 AM
phister's Avatar
06 C230 SS 6spd
thanks for the heads up. on my previous car I had to take apart the headlight to get the leveler to connect because the screw on the leveler cracked and wouldnt screw on.
Old May 29, 2011 | 04:30 AM
Silver C's Avatar
C240
Is it depo or oem? The oem should have indicators that says --> up or <-- down.. At least my oem bosch bi-x does..
Old May 15, 2014 | 03:19 AM
RELAXERMAN's Avatar
1976 350 SL R107
HEADLAMP ADJUSTMENT
Use extreme caution here, the adjusters are very fragile on these cars you need to look and see the condition of the screws from the inside of the wing on the reverse of the headlamp. If they break you will have an awful time finding replacement screws and brackets, they raise when you turn clockwise but the most prudent action is to spray WD40 on the adjusters and put it in for an MOT, they should be already set. I have just renovated mine, these headlamps are rare and expensive. I have a 1976 350SL R107
Michael
Old Sep 12, 2014 | 08:24 PM
ta2whitey's Avatar
2007 C230 Sport
does anyone have a pic of this adjustment screw? im pretty sure I saw the one that has a tab over it and there is one lower between the headlight and the parking light?
Old Sep 14, 2014 | 04:55 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
http://www.benzworld.org/forums/atta...top-view-1.jpg
