Tore the air intake tube
Old Mar 20, 2011 | 12:57 AM
jedcred's Avatar
'04 Mars Red C230K Sport Coupe (not Coup-EH)
In the process of changing the idler pulley and replacing the thermostat, I tore the intake tube that runs from the left intake to the airbox on the right side (from the front of the car). Seeing it come apart, it looks like it's meant to come apart in a spiral pattern.
Should I be worried about this? Should I repair it with duct tape or replace it entirely? I put it back in the way it came out, and unless you were to take it out again, it's not clear that the tube has come apart. Car seems to run fine this way so far.
Old Mar 20, 2011 | 01:53 AM
03'55AMG's Avatar
AMG
Duct tape is a no no. It will not withstand the temps needed. Unless you mean the foil duct tape. That would work but would look god awful
Old Mar 20, 2011 | 01:58 AM
Xhale707's Avatar
C320 2002
Mine ripped open as well. I fixed it with little bit of super glue. & has been working for a year
Old Mar 20, 2011 | 02:02 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
if you are talking about that cloth like tube that runs from above the rad to the air box. Tape it up with black friction tape, i.e. hockey stick tape. Mine fell apart (started to unravel I taped it back together with hockey tape and 3 years later it is still intact and the repair blends in with the colour and texture of the tube
The tube is not much of a heat issue.
Old Mar 20, 2011 | 12:21 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I tore mine a few years back as well.
The replacement is not too expensive from an online wholesale dealer.
And it looks better than a duct tape repair
Old Mar 20, 2011 | 05:20 PM
samaritrey's Avatar
Super Moderator
THE C350
remember we have full plastic ones they have sort of cloth like ones.
Old Mar 20, 2011 | 05:43 PM
Xhale707's Avatar
C320 2002
Oh so many changes haha I know the newer ones are better. But i hope the others were joking Ducktape on a benz.. LOL Some more honda action!
Old Mar 21, 2011 | 12:07 AM
blkamgsl55's Avatar
2008 SLK, 2006 Cadillac SRX, 1994 Cutlass Supreme Convertible
Buy a Replacement oem part. They are not that expensive, Or go to EBay there is a ram air intake for sale that replaces that failure prone hose with a setup that looks like the factory did it.
Old Mar 21, 2011 | 06:20 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
I busted mine too a month or two ago while replacing my coolant themostat. $5 worth of Krazy Glue (get the Gel type) and it's been holding. Everything just tucks back together if you're careful, because of the "spiral spring" reinforcement. If you do it carefully and pop everything back into the correct position, you won't even be able to tell from a cosmetic perspective.
The piece is not structural at all. All it does is provide a channel of air from outside the engine. Because of the way it's constructed and supported under the hood, you probably won't need to glue it if you are so inclined. The spring will hold everything together. But this is not recommended as it will now also allow hot air from the engine inside, reducing engine performance.
RMEuropean sells it for $50 if you're really ****. Cheapest I could find so far.
Old Dec 5, 2021 | 08:58 PM
mpekmez's Avatar
2005 s55 amg
I have a cls550 m278 and I noticed mine were torn after I installed new filters yesterday, can these being torn cause a check engine light ? today the cel turned on.
Old Dec 12, 2021 | 07:59 AM
jocaho's Avatar
2007 230 sport
Bought new ones how to install?
My air tubes needed to be replaced cuz they were torn at plastic piece above radiator it’s all connected so the new ones just don’t slide in place of the others cuz the front part is part of the plastic that holds to radiator
any Help here would be appreciated
Old Dec 12, 2021 | 08:55 AM
Benzrider17's Avatar
C43 c55 C63
Add a little extra power
Old Dec 13, 2021 | 07:51 PM
jocaho's Avatar
2007 230 sport
Where you find them?
Where you get them from
