My car died again :(
Old Apr 1, 2011 | 01:02 AM
fookoo303's Avatar
2003 c240
So a couple weeks ago I was on the highway and my car just sputtered to a stop. When I step on the gas, it bogs down so it seemed I was out of gas. But I still had a quarter tank of gas. I then filled a gallon and it started right up.
For the past two weeks I made sure that I wouldn't go under half of a tank and today it did the same thing. I filled it up with a gallon and started back up.
Does this sound like a bad fuel pump or maybe a bad regulator?
Also, I replaced my fuel filter about six months ago with either a bosch or a Mann. I can't remember which one.
Old Apr 1, 2011 | 01:31 AM
Silver C's Avatar
C240
Most likely your fuel pump is failing as it is unable to suck up the gas from your tank..
Old Apr 1, 2011 | 10:04 AM
fookoo303's Avatar
2003 c240
Thanks. That's what i thought too. So does the fuel pump intermittently work before it fully fails?
Old Apr 1, 2011 | 10:41 AM
Glyn M Ruck's Avatar
Super Moderator
It is possible that the pump won't pull sufficient head if tank level is low. If the car stops again - immediately check if there is fuel pressure at the fuel rail that feeds the injectors.
Old Apr 1, 2011 | 10:57 AM
Silver C's Avatar
C240
Yes it can, there may also be time it just dies instanteneously...
Old Apr 1, 2011 | 11:24 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
+1 on all above comments.
I suggest OP to test the fuel pressure (via a fuel pressure test port at the end of the fuel rail) during no-start condition.
Old Apr 1, 2011 | 11:40 AM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
How many miles do you have on the car?
Run the car, and when you check pressure at the fuel rail, you should see a good strong stream of gas.
Old Apr 1, 2011 | 07:42 PM
d1no's Avatar
05 c230k 6spd
Check your fuel pressure and report back, check it at startup when its priming, then when its running and when you turn it off. It should be around 50 psi when running and stay there for a while after you turn it off. I had similar problems and it turned out to be a faulty fuel filter.. Maybe you got a bad one too since you replaced it 6 months ago?
Old Apr 1, 2011 | 08:31 PM
fookoo303's Avatar
2003 c240
i have 176,000 miles
How do I check it? Can i rent the tool for this?
Thanks for the replies
Old Apr 1, 2011 | 11:23 PM
Silver C's Avatar
C240
Op , its already mentioned how to check. As for the tools, I don't know if you can rent it,where I live no one rents tools..
Old Apr 2, 2011 | 01:02 AM
04mbc230's Avatar
2006 C230 Sedan
Oh no!! Perhaps we should start a tread on how much miles before we start seeing things break down. A normal wear and tear item perhaps. I am sure it would be useful for those who can keep a look out of what to expect when they get near that mileage in their cars.
So... what do you think guys/gals?
Old Apr 2, 2011 | 01:05 AM
Silver C's Avatar
C240
Not to offend you, but everyone have different circumstances, so different miles for you and different miles for me.
Old Apr 2, 2011 | 01:08 AM
04mbc230's Avatar
2006 C230 Sedan
Yes. I know. How about just a typical driving style. I notice that regardless the circumstances, usually when the car hits a certain mileage, the majority of our cars has the same problems or maintainence to work on.
Old Apr 2, 2011 | 01:22 PM
mleskovar's Avatar
'17 Jaguar XF
Maybe your tank isn't transferring gas from one side to the other? Check the tubes etc. Pull the pump mechanisms to see if there's a clog.
Old Apr 3, 2011 | 12:59 PM
nrg_mike's Avatar
2005 C320 Sport, 2010 C300 Sport
I say fuel pump. The same thing happened to me with both my C320 and C230k coupe. Happened to my C320 while still under warranty and my C230K only cost like 600 to repair.
Old Apr 5, 2011 | 03:07 PM
fookoo303's Avatar
2003 c240
Thanks everyone for the suggestions. Tomorrow I am going to test the fuel pressure off the rail and then pull the pump out to make sure there's no obstruction.
Old Apr 5, 2011 | 04:35 PM
amanonfire's Avatar
W203
Don't you need a special tool to open the gas tank? The pumps are in the tanks, so its not as easy as it sounds.
Old Apr 5, 2011 | 06:23 PM
Super Moderator
I've posted procedure on the other thread where you asked. That tool is easy to make or a rubber mallet & screwdriver does the trick.
Old Apr 5, 2011 | 07:13 PM
fookoo303's Avatar
2003 c240
Great! Thanks Glyn!
Old Apr 5, 2011 | 09:45 PM
Super Moderator
Your 240 is just nicely run in. Some minor maintenance & she will be good for the next 176K
