DTC P2088
Old Apr 11, 2011 | 09:25 PM
maxss's Avatar
2006 C230
DTC P2088
2006 C230....18,000 miles
First I want to say this is a great forum, lots of great info. I was wondering if anyone has had this problem.
Symptoms: No crank and no start sometimes when engine is hot. Will always start up every morning on first try. CEL came on and scanned code which showed P2088 A Camshaft Position Actuator Circuit Low.
I have replaced the camshaft sensor on the right intake and also replaced the magnet on the right intake but the code still appears and the no crank symptoms are still there. I would point out that my gas mileage improved after replacing the camshaft magnet.
Any help is much appreciated.
Old Apr 12, 2011 | 06:06 AM
phister's Avatar
06 C230 SS 6spd
You might have to get the codes cleared and see if it comes back on.
Old Apr 12, 2011 | 08:20 AM
maxss's Avatar
2006 C230
I have reset the code and it does come back on.
Old Apr 12, 2011 | 09:53 AM
Glyn M Ruck's Avatar
Super Moderator
On a Benz this code can also mean.
P2088 = component G3/10 (right O2 sensor,before CAT,cylinder 4-6) heating (P0135)
P2088 = Heating of component G3/3 (Left O2 sensor,before TWC[KAT])(P0155)
None tie up with no crank. If your battery is good check the starter solenoid & relay.
Old Apr 12, 2011 | 09:55 AM
W203E35's Avatar
2006 C350 Sport 6MT
This is what I'm getting
Component Y49/5 (Right camshaft intake solenoid) has a short circuit to ground.
Old Apr 12, 2011 | 10:06 AM
W203E35's Avatar
2006 C350 Sport 6MT
This is your problem
Intake top Exhaust bottom and Right and Left is pretty explanatory.
Good Luck
Old Apr 12, 2011 | 10:38 AM
maxss's Avatar
2006 C230
Thanks guys. Your input is appreciated. Karo, I think your description of the DTC is relevant. I believe the ground wire for the right camshaft intake solenoid has the same ground screw as the starter solenoid. I will check that out later this evening when I get home. If that's the case, that could solve my no crank when hot issue. I'll post my findings.
Old Apr 12, 2011 | 10:57 AM
W203E35's Avatar
2006 C350 Sport 6MT
Good Luck...keep up updated
Old Apr 12, 2011 | 12:12 PM
phister's Avatar
06 C230 SS 6spd
karo always to the rescue! Maybe at odd hours of the night but always there. When do you sleep man, from posting WIS and DAS and chasing school boys and making them wear assless chaps I dont see anytime you can sleep.
Old Apr 13, 2011 | 01:24 AM
maxss's Avatar
2006 C230
Update: I cleaned up the ground screw where the right camshaft intake solenoid is connected to but I still have the same symptoms, no crank when hot and code P2088. Tomorrow I will do further testing on the starter to see what I come up with. I will post my findings. Also, does anyone know how to check the connector on right camshaft intake solenoid with a multimeter? I believe it can be done but I'm not very familiar with the correct process.
Old Apr 13, 2011 | 04:12 AM
W203E35's Avatar
2006 C350 Sport 6MT
If I'm not mistaken that's the magnet. It's not an expensive fix it should be around 20 bucks. I would just replace it because their known to go out on our engines. You'll save yourself more headache next time.
Old Apr 13, 2011 | 04:22 AM
phister's Avatar
06 C230 SS 6spd
Yeah I just ordered some magnets for my car. No CEL yet but I'm just going to change them out for reassurance. parts.com has them for like 16 a piece. You'll need 4 if i'm not mistaken right Karo?
Old Apr 13, 2011 | 04:58 AM
W203E35's Avatar
2006 C350 Sport 6MT
Yup there are 4 but I only changed the one that was giving me a code. I should just change them all. 16 bucks not bad.
Old Apr 13, 2011 | 08:49 AM
maxss's Avatar
2006 C230
I have replaced that magnet. I only replaced that one but I will be ordering another 3 to replace the others. I did notice a slight increase in fuel mileage after replacing.
Old Apr 13, 2011 | 09:26 AM
W203E35's Avatar
2006 C350 Sport 6MT
Ohh here is an idea. Why don't you swap them and see if you're getting a check engine for the exhaust side now?? Swap the top with the bottom and see if the P2088 goes away.
Old Apr 13, 2011 | 09:32 AM
W203E35's Avatar
2006 C350 Sport 6MT
If you do swap them then if you get a P2090 which is the exhaust solenoid (under the one that's giving you a problem) then we'll know it's solenoid
Old Apr 13, 2011 | 09:34 AM
maxss's Avatar
2006 C230
That's a good idea, I will try that later today when I get home? I did notice that there was oil in and around the magnet when I replaced it, isn't that the reason they fail? Is there not supposed to be any oil at all?
Old Apr 13, 2011 | 09:37 AM
W203E35's Avatar
2006 C350 Sport 6MT
To be honest with you mine had oil but it failed so I don't really know if it's suppose to be like that. Swap them and look for the P2090 error and if you get it we're golden now we know it's a defective solenoid (magnet). Also to check the the volt it was a horrendous process. You need some kind of tool. Let me post you a screenshot.
Old Apr 13, 2011 | 09:42 AM
W203E35's Avatar
2006 C350 Sport 6MT
I don't even know what kind of tool this is but it does tell you the volts, if that helps. One more post coming.
Old Apr 13, 2011 | 09:46 AM
W203E35's Avatar
2006 C350 Sport 6MT
Voltage info
Old Apr 13, 2011 | 09:54 AM
W203E35's Avatar
2006 C350 Sport 6MT
It seems it's testing it through the ecu. You plug that tool in between the harness and ecu and I guess it reads the volts??
Old Apr 13, 2011 | 09:57 AM
maxss's Avatar
2006 C230
That's what it looks like. If I can't figure this problem out by this weekend, I'm taking the car to the dealer.
Old Apr 13, 2011 | 10:00 AM
W203E35's Avatar
2006 C350 Sport 6MT
We'll figure it out don't worry. When you get home try to swap them out. You're not in SoCal are you?
Old Apr 13, 2011 | 10:01 AM
W203E35's Avatar
2006 C350 Sport 6MT
Here are ECU codes for the future if you need them.
https://mbworld.org/forums/c-class-w...7-request.html
Old Apr 13, 2011 | 10:02 AM
Super Moderator
Just understand one thing. The cam magnets & solenoids being faulty will not prevent the vehicle from cranking. In fact it is unlikely they will prevent the vehicle from starting.
