For those who have flushed their trans!
Old Apr 21, 2011 | 03:48 AM
leeer73's Avatar
'05 c230, '09 c300, '03 Durango
I'd like to flush my trans (722.6) this weekend and I have looked at all of the info found here but I do have a few questions!
After you change your filter, and put the trans pan back on do you fill the now missing 4 or so qts of fluid through the trans dip stick tube? Or is there a filler bolt on the side of the transmission? I read on 1 diy that stated that the filler is on the back of the engine.
And while you are draining the 2-3 qts of fluid at a time using the clear hose, are you re-filling those 2 quarts through the trans dipstick tube?
And last, when you bolt the pan back on, is there a sequence for which bolts get tightened down first and do the need to be tightend with a torqe wrench?
Sorry to bother you with these questions, any help would be much appreciated!
Old Apr 21, 2011 | 06:44 AM
Glyn M Ruck's Avatar
Super Moderator
Fill through dipstick tube.
See torque order.
Attached Thumbnails For those who have flushed their trans!-trans_pan_torque.jpg
Old Apr 21, 2011 | 06:52 AM
Super Moderator
https://mbworld.org/forums/attachmen...0flush1-1-.pdf
https://mbworld.org/forums/attachmen...0flush2-1-.pdf
Old Apr 21, 2011 | 05:32 PM
leeer73's Avatar
You are the best my friend, thanks!!!
Old Apr 21, 2011 | 05:58 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Drain, or pump, then fill, repeat repeat repeat.
Not at the same time.
Fill through the dipstick hole.
Put in exactly what you take out amount wise.
Old Apr 21, 2011 | 06:01 PM
leeer73's Avatar
thank you kind sir!
Funny thing, I just brought everything home from my shop to do the flush. The Trans fluid i bought is pink/red, but when I used the tool to check my fluid level, the fluid on the stick is a clear color. The great news is that it is super clean, but I wondering if it was filled wit the wrong fluid?
Old Apr 21, 2011 | 08:38 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Does anyone know the total quantity of oil which is in the pan ? ie the amount drained + residue in pan.
I see total oil added during flush is 14 litres & total drained is 12 .Instructions state 2.5 litres in pan after draining !
What I am getting round too is that Glyns flush 1 instructions state :- If transmission oil is burnt or beading abrasion it will be necessary to flush the oil cooler lines and oil cooler to
ensure adequate cooling efficiency:
My question is if the oil is in good condition why flush ?
Just remove the pan, clean ,replace the filter & gasket & refill with the same amount of oil which was in the pan.
Doing this at regular intervals should maintain the quality of the oil ?
I have maintained ZF transmissions in the past & this was the process. ie regular draining which maintained the clean oil colour.
Looking forward to your input. John.
Old Apr 22, 2011 | 01:00 PM
Super Moderator
JC - no need to flush if fluid is good. It's just a pity that Benz removed the TC drain in 1999 from the 722.6. If you do a sump drop & filter change (no flush) your refill will be approx 4 litres. (Remember to clean the pan magnet)
Check your car for a TC drain plug. It was put back on the 722.9 in 2007. If you buy a new TC for a 722.6 now it has a drain. Your W204 diesel might??? have a drain.
Old Apr 22, 2011 | 05:03 PM
Carsy's Avatar
Thank you Glyn for the refill figure.
I have looked, no TC drain unfortunately.
