c230 05 heated seat install help!
Old 05-03-2011, 06:21 PM
skibum_1260's Avatar
300sl
Have a 05 c230k that didnt come with heated seats from the factory. Im going to install a set and want to use the factory switches(allready have the switch row) and wiring if possible. I will be using aftermarket heat pads but if anyone would have any info on the wiring harness that would be great. The local dealer wasnt much good, he just found a harness that says heated seats but he cant be sure its what i need. I guess looking for a harness and if there is anything else I need and if that should plug right in( i know ill have to wire the aftermarket pads to the factory harness)? Did a search and tried to contact the guy who's done it before but he hasnt responded yet.
Thanks in advance.
Old 05-03-2011, 10:21 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Order the Mercedes maintenance DVD. It will walk you through the heated seats retrofit. I did the retrofit a few years back. I used factory seat covers with the heated pads integrate, the heated seats wire harness, and the upper control panel with heated seat buttons. I don't know about aftermarket pads.
Old 05-04-2011, 02:51 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Don't you have to cut open the seat (some seam) to put in the pads?
Old 05-04-2011, 04:51 PM
300sl
where do i find this dvd at? and it shows everything i need to buy and how to install the factory harness and everything? installing heated seats doesnt seem like a maintenance item!
Old 05-05-2011, 01:53 AM
jtwillia2's Avatar
2005 C230K
Planning on doing this same mod sometime soon. I've read that we should get the H3 kit from here:
http://www.heatedseatkits.com/heatedseatkits/index.html
Where'd you get your switch row/panel? Can't seem to find one anywhere.
Old 05-05-2011, 11:03 AM
300sl
Ebay, i think i ended up getting it for 60 bucks or so!
Old 05-31-2011, 04:13 PM
aznmode's Avatar
2010 c300
I'm almost positive its the H3 but I can't seem to find the thread anymore. Gonna try to do this also sometime soon.
Old 05-31-2011, 04:48 PM
aznmode's Avatar
2010 c300
I may go with these carbon ones which have come down in pricing significantly when I was thinking about doing this a few years ago but never got around to it. 11x19 times 2 is a decent size and can be cut to any size without damaging it.
http://www.sportsimportsltd.com/pedecafiunhe.html
Old 04-15-2013, 02:52 PM
Alexbenz's Avatar
Sean's Sister--
any updates on this ?
Quick Reply: c230 05 heated seat install help!
