Kompressor Questions
Old May 23, 2003 | 03:50 AM
alan16828's Avatar
98 E430 & 06 C230
Cool Kompressor Questions
I have a question regarding the superchargers used in 2002 C230K Coupe and 2003 C230K Coupe. I understand that the 2002 has a 2.3L engine while the 2003 has a 1.8L engine. Who makes the supercharger that is used in the 2002 C230K? And who makes the supercharger that is used in the 2003 C230K? Is there any major difference between the two? Thanks.
Old May 23, 2003 | 08:40 AM
Outland's Avatar
2002 C230 Coupe(M111)
Re: Kompressor Questions
The 2002 uses the 2.3L M111 engine- same as the SLK230 and previous C230 sedans- It makes 192HP and 208ft-lbs of torque on 5 or 6(depends on who you ask) pounds of boost from an Eaton M45 Roots type Supercharger. One of the amazing things about the M111 is that there is decent torque just off idle, and from 2500-4800RPM, always 200 or more ft-lbs available. This makes it feel like a considerably larger engine.
The 2003 uses the all new 1.8L M271 engine- the C230K Coupe was its first application. Its also in the C230 Sedan, and the upcoming new SLK(supposedly making 200HP in the SLK). It makes 189 HP and 190ft-lbs of torque from supposedly 10 or 11 pounds of boost from a modified M45. By many accounts, that's the upper limit of boost from the M45.
Old May 24, 2003 | 05:55 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
just a minor correction: C180, and C200k both use the new 1.8 engine, so the C230k really isn't the first application. 180 being n/a and 200 with less boost from the s/c.
Old May 24, 2003 | 10:28 AM
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
I could be wrong but from where I live (Australia), all 4 cylinder W203 are using the same 1.8L engine. So 2003 C180K, C200K and C230K are all 1.8L supercharged with different level of boost/tuning.
Old May 24, 2003 | 11:56 AM
trench's Avatar
2002 C230 K
You are correct, sir. Well, for the 2003+ models, anyway.
The previous model years used motors with displacements indicated by the badging.
- BT
Old May 24, 2003 | 05:27 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
wasn't that wat i said? oops, nevermind, should've said 180k not 180...
Old May 24, 2003 | 07:08 PM
seen's Avatar
C180K
- BT
yes they use the same engine, but not only the boost but the compression ratio is different (180k, 200k, 230k)
[s]
Old May 24, 2003 | 09:01 PM
Lynn's Avatar
The ECU software is different, too
Old May 25, 2003 | 04:39 AM
gmabm's Avatar
[s]
So is it possible to fit a 1.8L C230K ECU into a 1.8L C180K and resulting 193HP?
I'm not being a cheapstake but its just that this new 1.8L C230K is not available through my country authorised MB agent.
Old May 25, 2003 | 05:11 AM
Lynn's Avatar
I'm not a cheapstake but its just that this new 1.8L C230K is not available in my country authorised MB agent.
No, that wouldn't work, because of the different boost levels and compression ratios.
Old May 25, 2003 | 08:35 AM
moomeh
Guest
Posts: n/a
[s]
sorry, this may be the dumbest question asked since i know nothing about engines. can't we just changed the compression ratio and get more power?
Old May 25, 2003 | 09:17 AM
gmabm's Avatar
The boost is controllered by the ECU, different boost levels would effect different compression ratios in the cylinders.
Therefore I believe changing of ECU is able to increase the power from engine. Moreover the displacements or rather the entire block is the same.
But I have noticed that there's another mechanical aspect which is not quite the same between the models are its gearbox ratios (or just simply a different final drive).
Old May 25, 2003 | 10:46 AM
Matt230K's Avatar
2010 C300 4matic
Nope, boost is not controlled by the ECU. It's controlled by how fast the supercharger is spinning. You can only control boost with the ECU on a turbo.
Old May 25, 2003 | 10:57 AM
Lynn's Avatar
To change the compression ratio, you have to change the pistons. To do that, the engine must be removed and disassembled.
Old May 25, 2003 | 09:01 PM
gmabm's Avatar
If that is the case, changing of pistons are not sufficient, we might also need to upgrade the crankshaft, conrod (& cam maybe?).
Old May 25, 2003 | 09:04 PM
gmabm's Avatar
What about changing the pulley, does it helps to increase boost?
But would the C180K ECU able to handle the addition fuel feed of a higher boost?? :P
Old May 25, 2003 | 09:24 PM
Matt230K's Avatar
2010 C300 4matic
Yes, changing the pulley will increase boost. Myself and many others on this forum have done that already. Unfotunately, there are not any pulleys yet for the 1.8L engine, only for the 2.0 and 2.3L engines.
As for fuel, there are different fuel settings and these can be changed by the dealer, and it changes the air:fuel ratio under certain conditions.
Old May 25, 2003 | 11:35 PM
Lynn's Avatar
No, just the pistons need to be changed. Compression ratio can be changed by changing the shape of the top of the piston.
Old May 26, 2003 | 02:14 AM
iczer34's Avatar
E60 M5 & E90 M3
Smile
Haven't been able to fully utilized the "supercharger" ... still breaking her in
Old May 26, 2003 | 08:51 AM
gmabm's Avatar
Is this controlled mechanically by regulators or electronically compensated by ECU?
Old May 26, 2003 | 08:55 AM
gmabm's Avatar
Really? That makes the conversion even more simpler now.
Old May 26, 2003 | 09:25 AM
moomeh
Guest
Posts: n/a
would it be cheap to change the compression ratio then to get more out of a car?
Old May 26, 2003 | 10:02 AM
Lynn's Avatar
To change the pistons, the engine must be removed from the car and disassembled. The oil pan must be removed to get to the rod bolts, and the intake and exhaust manifolds must be removed. The the head is removed. The pistons are pushed out their cylinders. The pistons must be separated from the con rods by removing the wrist pins. Now install new rings on the new pistons. The reassemble the pistons, wrist pins and con rods. Using a ring compressor, slide the piston and rods down the cykinders. Using new rod bolts and bearings, the rods and rod bearing caps are reassembled to the crankshaft. The oil pan, head, manifolds etc are reassembled. The engine is reinstalled in the car. This is just a brief sysopsis of the process. It is much more complicated. It will not be cheap, and I don't think higher compression pistons are readily available. They will be $$$$.
Now we are ready to use the engine, right? Wrong. The ECU might need be remapped if you are still going to use 91 or 93 octane gas. The engine will be more prone to detonate with the higher compression, so the ECU will need to retard the ignition advance. To make sure, you will need to do several tuning sessions on a dyno. On the other hand, you could use $4 to $5 per gallon racing gasoline.
Now, the engine is ready to go. Enjoy the break in period.
Old May 26, 2003 | 11:40 AM
Matt230K's Avatar
2010 C300 4matic
I'm not sure about this. I assume it's mostly electronically controlled. I think this is another question for Lynn.
Old May 26, 2003 | 06:56 PM
Lynn's Avatar
It is all electronic.
