C320 Pulls to the right even after alignment
A while back I hit a pothole that was pretty big. It bent the rim slightly and damaged the tire too. I was not happy because I just put all 4 new tires on the car the day before litterally. I replaced the bad tire and the bent wheel. My car later on about 6 months later failed inspection for a loose tie rod end on the same side. I replaced both tie rod ends and took it in for an alignment.
I have taken it to three shops with no luck on the alignment. The first two were tire type places and the third was the dealer.
The dealer tells me it is tire pull which I call bull. I swapped the tires around left side to the right and front to the back, no difference at all.
The brakes are not dragging, I have had cars in the past with dragging brakes, but not this one.
My alignment numbers are as follows.
Front
-0.5 Camber -.4
9.9 Caster 9.8
.04 Toe .04
13.4 SAI 12.8
12.9 Inc Ang 12.5
Rear
-.7 Camber -1.0
.20 Toe .29
The car has 90k miles on it.
Any ideas
SAI is the steering axis inclination, this angle is part of the included angle and really cant be adjusted. Its caused by bent parts if its off. If one side is greater than the other it will overpower and cause a pull in the weaker direction. King Pin Inclination is what this used to be called.
Should I replace both control arms on each side?
Maybe in the next couple of days I can get under there and look closely at the parts.
http://washingtondc.craigslist.org/n...452693831.html
pretty good deal... and if your tires are better than his.. you can re-use them
(i think i'm too late though)
Good luck with it.
http://www.ptuning.com/html/services.com
they specialize in custom alignments... but have all the diagnostic tools to manually evaluate what's going on with your car if you have no luck elsewhere.
btw... when did you graduate from tech?
Also thanks for the tip on PT Tuning, I know where they are, I have passed by their shop before.
I think what I am going to do is pull off the hub and inspect the spindle along with the control arms.
I do know the pothole was bad enough to bend the wheel and weaken the tie rod. I assume had an impact on the bearing on that side too. So probably something is bent as suggested earlier.
i've had to replace my control arms before and did it here:
their manager ("Hal") is a fellow hokie: http://mitchcarr.com/
goodluck with the fix
I was also able to get a better look at the control arms since I had the dust shield off. Unfortunately I couldn't find anything wrong. I suppose with the side off by only a degree or less it might be impossible to spot visually.
I am considering replacing off some parts as I am out of ideas and I really hate driving the car like this. I have one of those lever type joint separators, but I haven't tried it out, will I be able to separate the ball joints without ruining them? In my past suspension exercises I have always used a pickle fork and a mini sledge and just replaced the joints. I am hoping to avoid that right now.
I switched the tires around every which way and still the same problem exists. Also the tire pull was not there before the pothole incident.
Must be UVA people running VDot down there, LOL.
I called the dealer back about the issue.
Their position is that the numbers are within MB specs so it shouldn't be pulling unless it was a tire issue. I stated that changing the tires around didn't make any difference.
They said my only real options were to either take it to a body shop and have them put it on a frame machine or to start replacing off parts.
I can buy the entire knee assembly from online bone yards for about 200-300, I am tempted to go that route.
UVA FTW!!(our football team sux though)
