when set on auto ac turns off by itself
I leave it in auto all the time
today when i left work it was off so i pressed it it ran for 10 secs and shut off again it did this 3 times then i just turned the fan on manually ac worked fine
tried auto again turned off waited 5 mins all was well
it did this 2x about a month ago but thought nothing of it
works fine in manual but auto is hit or miss any ideas??
control unit is the analog one
When this happened on my coupe a year or so ago, I switched off all environemntal control (fan/ac), rolled the windows down and went for a nice long drive on the highway to charge the battery up.
Worked like a charm.
When left on 0 and Auto, I think it makes intermittent contact and turns the system off. Just leave it on a setting other than 0 and Auto and it should go away. We just leave it on 3 and Auto all the time and the problem doesn't happen.
Next time I have the center panel apart, I'll take that entire unit apart and figure it out. The pot probably just needs a little Deoxit spray.
Also if it worked fine yesterday, maybe the battery had time to charge up. Try charging it by driving long range with as many power consumers as possible (like AC etc) turned off. See if that fixes the issue
Symptoms are the fan stops for 1 second, or 1 minute, or 5 minutes - it's random. If the fan works fine when manually controlled on lower speeds, but cuts out when turned up to maximum speed, this is likely your problem.
A quick check is to pull off the left-hand dash endcover to expose the fuses there. Pull the 40AMP fuse and look for signs of heat damage - melting plastic and such. This is a sign the fan is pulling too much power. I had this problem in my 2004 c240 and while the fuse did not blow, it was melted and basically welded into the fuse holder. I had to get a new fuse and move it to a free spot in the fuse block.
BTW, a replacement fan and regulator run about $300 mail order, and are an easy DIY replacement.
There are a couple of threads in mbworld discussing this problem, search is your friend here.
I couldn't tell any difference between the old fan and the new fan. Given that it was getting to be summertime in Texas and I really like cold air, I ordered and replaced both the regulator and fan at once. Not willing to try just one or the other at the risk of putting up with no cold air for a few more days.
In my case after replacing the fan & regulator I was rather surprised and disappointed to find the new fan didn't blow cold.
After exercising my mechanic's vocabulary for a few minutes, I checked for power at the regulator, and there was none. So went to the fusebox and found the damage described previously.From what I can tell, this type of problem is not uncommon. Google up something like "melted fusebox" and you'll get a lot of hits, describing all kinds of cars.
