I have a 2003 C240, engine cranks but will not start.
DTR light is on in info center.
Thoughts?
Many thanks
Thoughts?
Many thanks
Super Moderator
Have you looked to see if you have fuel pressure at the rail? That is where I would start. Do you have a code reader to read the code?
Super Moderator
Quote:
Diagnostic Trouble Light. Just another name for Check Engine light.Originally Posted by LILBENZ230
What is the DTR light?
Quote:
Thanks for the tip, should have mentioned that I did have fuel pressure.Originally Posted by johnand
I went back to the car and tried to start it and it started, but I have the check engine light on.
I made it home and scanned it with my scanner and it is showing a crank position sensor malfunction. Car would not start again after I shut it off.
So I have a new sensor in hand and a crude drawing as where it should be so I will tackle it tomorrow as the engine is hot right now.
This will be the first work on a German auto, all my experieince is with domestic.
Many thanks and I am enjoying reading the threads.
Bob
Installed the new crank position sensor, cleared the code and the engine is running like a charm.
What a little tricky sensor to remove and install. Not alot of room.
Thanks all
Thanks all
Good work . Thanks for the update.
Good old CPS. I carry a spare. Of course mine has not failed - YET!
Engine won't start if it does not know where TDC is.
Explore
