Very Odd RPM's
Let's say i'm going 110 KM/H on the highway while having cruise control engaged, the rpm's act strangely going up and down. If i am at 3000 RPM we'll say, the needed would move ever so slightly but enough for me to notice. No big up's or down's, just moves like if you were waving your index finger up and down slowly...
I'm on cruise and would normally understanding hills and what not, but this just seems like it's all the time. When i start it it's not there for the first 5 min. , but after of course it comes back and almost feels sluggish when accelrating.
This of course is very annoying and I will be chaging the plugs and cleaning the TB this weekend hopefully to clear upa nything. No codes nothing. Mornings have a little rough start, but that's another page to start which i've gotten alot of information in regards to alternator/pulley's
Any help would be greatly appreciated. I turned on the car let it sit and notice the voltage is at 13.5
Dereck
But only when it's cooler it starts rough. If it's in let's say a heated garage.. no problems..
But that damn idle... nothing like i said again that jumps and would make me **** my pants lol... but still. It's annyoing and don't wanna be throwing 3k of parts at it.. One baby step at a time I guess...
Film these RPM fluctuations and post a video.
Only worry about it if it can be felt. In which case throttle actuator or TC clutches are messing around.
EDIT - it will be more noticeable when warm & the transmission fluid thins out.
As stated i'm gonna clean the TB this weekend.. And pray it's not an actuator per reading phil's thread and others. Pretty quick responses.. gotta say love this site.
1st rough start int he morning.. almost stalling it seems. but catches.. then rest of the day she's fine.. I changed spark plugs myself, maybe the kid at the parts counter gave me the wrong type, but then again, i would of noticed something the first day of swapping them out ...
Just had the rotors and pads replace, thought i'd be good.. Of course it's starting to get colder in Ottawa, ON, and colder = crappy rough start.
I seen you all over those posts today in alot of diff. posts.
Did you end up changing your alternator?
The minute you touch the throttle pedal to accelerate you are no longer at idle. You say in your original post that "The problem doesn't really occur if in P or in D stopped." That is at idle.
What you describe is that the RPM surge up and down at higher RPM than idle with constant throttle opening. Yes??? This is not idle.
Clean the throttle body & look for wear & an air leak at the throttle plate shaft in the TB.
Good luck.
I'm not as mechanically inclined as I'd like to be, but I try.I'll be doing that this weekend and re-post and see how it goes. Someone was saying to directly spray the TB cleaner inside... After reading some posts, it seems the best is scott towel or something like that and get well around it.
I did the throttle reset, it seemed to help and for the first time in history of owning the vehicle, it gave me more gas this morning, it was just a tad higher then the previous night. This car... Glitches man
This guys is very nice and took the time out of his day to call me and help me out.. again this site is the greatest
I figure maybe there is a wrong readin in the morning. I'll let you know. Also will purchase the necessary stuff for the block heater.
