Replacing spark plugs. Do I also need to replace wires/boots?
Old Sep 24, 2011 | 03:07 PM
jtwillia2's Avatar
2005 C230K
Hey everyone, my 78k is coming up where I'm supposed to change my spark plugs. Do I also need to change out the wires or boots or anything? If so, anyone got a rec of what I should get?
Thanks.
Old Sep 24, 2011 | 04:16 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
On a previous thread (https://mbworld.org/forums/c-class-w...lug-wires.html) Glyn recommended that a guy change his wires at around 100K. Your next plug change is at 91K so you might want to change them then or the time after.
Old Sep 24, 2011 | 04:21 PM
jtwillia2's Avatar
2005 C230K
Or maybe my car doesn't even have wires? It's a 2005 C230K sport sedan.
Old Sep 24, 2011 | 04:33 PM
ncmudbug's Avatar
Those plugs don't fire themselves!
Old Sep 24, 2011 | 04:36 PM
jtwillia2's Avatar
2005 C230K
I have the 271 engine so my next plug change is at 78k like I said, I figure if I need to eventually replace the wires, I might as well do the plugs and wires both at the same time, but I can't find anything concrete that talks about changing the wires.
Old Sep 24, 2011 | 04:46 PM
ncmudbug's Avatar
Glyn's recommendation is pretty concrete to me.
Old Sep 24, 2011 | 04:57 PM
jtwillia2's Avatar
2005 C230K
Any idea which ones I should buy? Can't seem to find any that claim to fit my car and the parts list doesn't have it.
Old Sep 24, 2011 | 05:20 PM
ncmudbug's Avatar
Hmmm... You got me there. Mine only has 50k on it so I haven't had to worry about them yet. I usually get parts like that from here (http://www.rmeuropean.com/) but all I could find were coils. I found something on Amazon, but that is not my primary source since I worry that they list the right parts. In the thread I sent you, vhouc said he got some. He may be your best bet. Or you could call rmeuropean for the part.
Good luck! Let us know where you get them.
Old Sep 24, 2011 | 08:39 PM
ncmudbug's Avatar
I don't know anything about these folks, but I found a set of wires for a 2005 C230K here: http://www.partsgeek.com/catalog/200..._wire_set.html
The price seems reasonable, but there isn't much of a description for them.
Old Sep 25, 2011 | 03:33 AM
jtwillia2's Avatar
2005 C230K
Saw those too, seems a bit unreliable/shady but it might be the only option. Was hoping to find something from Bosch, NGK, or MSD.
Any other input would be greatly appreciated.
Old Sep 25, 2011 | 07:47 AM
Moviela's Avatar
There are no secondary coil wires. The car has four cylinders and four spark plugs. The coil pack that generates the spark voltage sits above the plug. Integrated into the coil pack is a sliding insulator that carries the current to the plug. You pull the insulator out to a specified length and install the coil pack. The insulator collapses as you push it into position to account for different height of the installed plugs. If you don't have any codes, and cannot see any defects in the case of the coil pack like cracks, discoloration, or carbon trails, you don't need new ones.
Some other cars have twin-spark and there are two plugs per cylinder. Those cars have short wires from the coil pack to the plug.
Old Sep 25, 2011 | 03:16 PM
drho2004's Avatar
2005 C230 SS
I did my spark plugs on my 05 three weeks ago. coudlnt be any easier, like mentioned our cars do not have wires or dist cap. u will need a torx driver and thats basically it. search the forum there is a guy who did it with pictures and everything. just buy OEM bosch. i found mine for $7/each online Rockauto.com Dealer wanted $24/each. easy DIY job
