foglight swap questions
I was wondering if anyone could please give more detail instructions on how to swap my foglights into the clear lens ones for both sides?
I bought a pair from Steve but not sure how to install them.
thanks.
PS: mine is a sedan C class (I only found instructions for the Coupe one).
1. First remove the center under belly pan (6 8mm hex screws).
2. Remove the front wheel well cover (3 10mm hex screws and a few push pins on both inside and bottom). Turn the wheel facing the outside of the car first will help.
3. Remove the fog lamp assembly (2 8mm hex screws from the bottom, you may need a long extension to reach them easier).
4. Last twist out the bulb and put it into the new assembly.
1) the trim round the lens will be gray instead of chrome
2) the bulb will not be covered by a silver colored piece
3) your lightpattern will be off
Here is a picture of the OEM clear fogs and the result of non clear fogs with clear lenses:
link
Every now and then I have a set of OEM clear fogs...
greetingz,
To replace the foglights on the sedan - you're going to have to remove the bumper on the driver side. Passenger side has access per 20FHK02's instructions, but driver's side requires you to remove the bumper for access. It's a couple of screws here and there - you'll see.
