Headlights don't work!! Please Help!!
Old Oct 6, 2011 | 11:12 AM
Amanda17's Avatar
2005 Mercedes Benz C240
Hi I have a 2005 C240 had it for less than a year now and before the summer one headlight went out and last month the other one did ... I read a post saying to unplug the battery but that didn't work and I have also bought to different headlights so it must be something else any suggestions????
Old Oct 6, 2011 | 12:14 PM
glocati's Avatar
2016 GLE 350
Do your park/running lights work? How about fogs? Asking as, just trying to figure out if the actual switch has power?
Old Oct 6, 2011 | 12:24 PM
Amanda17's Avatar
Yes all the other lights seem to be working fine just the main ones don't work and the bottom license plate light is out don't know if that matters ??
Old Oct 6, 2011 | 02:20 PM
Glyn M Ruck's Avatar
Super Moderator
RU sure that the lamps are not blown?
Old Oct 6, 2011 | 02:36 PM
glocati's Avatar
2016 GLE 350
I would suspect a bulb install or contact issue. Given you have replaced both bulbs, i would re-examine the two headlight bulbs. Make sure they were inserted correctly and they are correct bulbs.
I would also unplug and re-plug the wiring harness at the headlight assembly/make sure it is securely snapped in place.
Keep us posted...
Old Oct 6, 2011 | 02:47 PM
Super Moderator
Sorry - I did not understand "I have also bought to different headlights"
Agreed!
Old Oct 6, 2011 | 03:00 PM
eesjunin's Avatar
Nowhere ...Fast
where in mass are you? if you near i can help you troubleshoot it
Old Oct 6, 2011 | 04:13 PM
Amanda17's Avatar
Sorry not headlights I meant I bought two different bulbs one pair were to strong they were like 10k and now I believe I have 5 or 6 k ones that still don't work... Thanks I'm going to try unpluging them and replugging them and see if it works I hope it does!! I'm from western Mass
Old Oct 6, 2011 | 04:33 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Are you saying your car has the bi-xenon and that the bulbs stopped working and then you bought replacement bulbs and they do not work either?
OR do you have a aftermarket HID kit?
Old Oct 6, 2011 | 04:38 PM
Amanda17's Avatar
Yes if the car came with bi-xenon lights thats what I have on their and I bought some replacement light bulbs online...
Old Oct 6, 2011 | 04:49 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I have a suggestion.
Learn how to ask a better question.
Old Oct 6, 2011 | 04:56 PM
Amanda17's Avatar
I have a suggestion as well if you don't have the answer to my question keep it moving! I didn't ask you specifically THANK YOU c230 sports coup
Old Oct 6, 2011 | 06:34 PM
Super Moderator
With BiX your ignitors have probably failed. Replacement kits are available from Benz parts providers.
Old Oct 6, 2011 | 08:18 PM
Super Moderator
Here:
https://mbworld.org/forums/attachmen...acement-1-.pdf
Good luck
Old Aug 31, 2025 | 08:34 PM
Steele7104's Avatar
2006 C280 4matic
Parking lights work
Parking lights work, fog lights are out of the car due to the accident and I was hoping to get the headlights working without the fog lights if that possible?!
