headliner in the rear is starting to droop
Hi all,
I just noticed that my headliner in the rear near my rear headrests is starting to droop and fall a bit. Does anyone know any tips on how to fix that or the cost of getting new headlining? Id like to get black suede if i can find it.
Any help would be greatly appreciated
I think that someone here paid $1500 for one in alcantara a year or two ago.
Mine is doing the same thing as yours. Sucks. The one in my Honda is fine after 22 years. Hmmm...
I've heard of people accessing the back of the headliner and spraying spray glue between the headliner and the roof. I don't know how that would be done on a Mercedes, but it would be worth a try if you can roll some rubber molding (or whatever is holding up the headliner) out of the way. If not, the upholstery shop is your next stop.
Good luck!
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
Mine in the Coupe is doing essentially the same thing. However, after looking at it closely, I am pretty sure that it is not the fabric pulling from the board, but it is actually the "board" for a lack of better term...sagging in the middle.
I have been considering the idea of a small wad of silicone right in the middle, it doesn't seem like it would take a lot to hold it in place.
I replaced mine DIY on a Peugeot for about $150 for glue & material. It just takes some planning , time & an offsider.
Interesting. I was under the impression from what I have read on here that it is fabric glued to a formed press-board which is essentially held in place by the interference fit with the other trim pieces plus a few attachement points (i.e. rear passenger light, center console up by the mirror and IMS, if so equipped). But when I read threads on IMS install I wasn't really interested in the headliner attachemnt at the time, so I may be wrong.
I pulled down the headliner and put a short bead of body mold silicone glue, then taped it up till it set. No more droop, and I'm never taking the headliner out again so I don't care.
2024 EQE Sedan (on order)
My 2001 C240 HL was also drooping badly. The formed fiber backing was okay, as was teh cloth tht you can see. Turns out that in between those elements is a thin layer of foam material. The foam eventually deteriorates - faster if it's hot and humid, I think. The deteriorated foan is still in the interface, so just regluing is not ikely to work very well.
I bought an OEM replacement headliner and installed it. MAJOR PITA. Here's what has to come off to replace the headliner (no I'm not joking):
1. A, B, and C pillar covers
2. All four grab handles
3. Front overhead cluster, with RV mirror mount, rain detector, and sun visors, including vanity lights
4. Seat belts
5. Rear seats
6. All trim on the left side of the truck (to access the electrical connectors)
7. All of the inner weatherstrips on the doors
8. The center console (shifter, cupholder, etc) has t be removed or there isn't enough space to get the new H/L (that you really do not want to crease) into the car.
9. The wiring to the sunroof, etc
I think I could do the job the second time in under 12 hours, but I sure don't want to.
4. Seat belts
5. Rear seats
