c230 Gas tank over flows
C230
So everytime i full tank the gas it always over flow. Why ? why? why?
I tried diff gas station and still doing the same thing so I know there is something wrong with my 07 C230
Please help.
Please help.
C230
thanks boss. yes that is the problem. once it cuts off, it will spill some gas. its like cutting off is late. i thought it should be a sensor from the gas pump but i tried diff gas station and its doing the same thing =(
May be you are not inserting the nozzle all the way in. If the nozzle is inserted all the way, gas shouldn't be spilling all the way out.
2005 c230 kompressor 2003 s500 94 wrangler
lol i remember thoughs days
when i first got the car i was filling the gas tank and gas literally shot out the tank cause i overfilled it..wasnt paying attention hahahaha
i learned my lesson....try filling it less and have the gas handle be on the lowest setting also
I always fill my car with the lowest setting selected and never, ever top off. That said, something is definitely wrong with your car. Even if I set it to the highest, it cuts off before it overflows. Always has.
Someone will chime in with the real answer before too long.
C230
LilBenz, thank you. this morning i stop it at 12 gallons so it wont spill. I called the dealer service and the rep will call me back. he probably going to google it. LoL.
oh I love jersey. I only pump gas when I take road trips out of state. nothing better than sitting in the nice warm car, with the seat heaters on, while some guy makin 8 bucks an hour pumps my gas for me. ahhhh. almost makes the outrageous property taxes worth it. almost.
Those guys aren't careful when inserting the nozzle; in the process they make marks on the paint in the shape of half-nozzle. They let the gas drips fall on the car body. If you don't wipe those off right-a-way, they leave stains. Whenever someone else fills my car, I stand right next to that person to make sure they don't do the above...
Super Moderator
It sounds as though one of you breathers is blocked or your carbon canister is saturated.
Do you get any EECS codes on the car. EECS = Evaporative Emissions Control System.
It is a 16.4 gallon tank and you will probably never see that much go in. The most I've ever been able to get in was 15.9 gallons and that was after driving with "Distance = 0" for a ways.
2006 C230 Sedan
I seen this in Volvos and if this has it, it would be cool.
maybe from fuel level sensor is faulty or your fuel filter is clogging
go to autozone and buy a bottle of techron concentrated plus fuel cleaner its the only one that works...even mercedes approve of it
2005 C230K Sport Sedan, 6 speed manual
Unfortunately, after all of the modifications and all of the savings, my fuel tank kept running over while I was driving down the street.
Seriously, when I fill my fuel tank, I fill it very slowly. This reduces the possibility of the fuel surging back out of the filler pipe. I do not ever use the lock on the fuel nozzle.
Note, the 2007 cars were changed to simply say "Reserve Fuel Level" at a certain point where the 2005 cars count all the way down to 0 miles remaining. I'm not sure which one of these characteristics the 2006 has.
C230
low setting still over flows
im going to try this....did full tank yesterday with the lowest settings still overflows.....
