Air intake systems?
Old Jan 4, 2012 | 04:56 PM
Harleyl7's Avatar
Air intake systems?
Hey I'm looking for an intake system to put into my 04' c230k. I was wondering if anyone had any suggestions and if someone would tell me if this would fit my car http://www.engineperformancechip.com...ake-system-p-2
Also is there any chips I can put in my car?
Old Jan 4, 2012 | 07:12 PM
MBfinatic's Avatar
e36 318i, 2004 sti
I think it would but for that money you could most likely make a custom one that has better gains..
Old Jan 4, 2012 | 07:39 PM
Harleyl7's Avatar
How would I go about making a custom one?
Old Jan 4, 2012 | 08:09 PM
MBfinatic's Avatar
e36 318i, 2004 sti
custom put the pieces the way you want it.
Old Jan 4, 2012 | 08:12 PM
Harleyl7's Avatar
What parts would I need? and what would be the best way to put it to get the best gains?
Should I buy a kit or go to pepboys and find the parts
Old Jan 5, 2012 | 04:13 AM
harrison1277's Avatar
Kompressor Sport Sedan 05 M271
im trying to make a custom intake as well
I want to make a straight shot from the right side inlet directly into the airbox
someone on here made one but i forgot where
Old Jan 5, 2012 | 10:40 AM
Hogger's Avatar
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
I made one. Still trying to tweak the fit a little.
As for a chip, do a search for "Eurocharged ECU tune"
That should point you in the right direction.
Old Jan 5, 2012 | 11:12 AM
MBfinatic's Avatar
e36 318i, 2004 sti
plus one told him the exact same thing regarding eurocharge!
Old Jan 5, 2012 | 11:15 AM
phister's Avatar
06 C230 SS 6spd
OEtuning had a sale going on for there tunes I believe.
Old Jan 5, 2012 | 11:22 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
OE's is almost over. Eurocharged is a bit cheaper, if their special is still going on.
Old Jan 5, 2012 | 11:26 AM
phister's Avatar
06 C230 SS 6spd
Yea I just had issues with eurocharged not fully testing out the remote tune before launching it. Said it would work for my car but during our session it wouldn't so I had to overnight it to them so I could have it back at the beginning of the week. Other than that the tune is good.
Old Jan 5, 2012 | 01:19 PM
how hard was it to make that?
Old Jan 5, 2012 | 09:26 PM
Hogger's Avatar
It wasn't too bad. I just had to keep trimming the two plastic end pieces to get them down to the right size, while using foam to mock up the tube area and keep it all lined up, while making sure it was still going to be able to get it in place.
Then I wrapped it in multiple layers of fiberglass, a little bondo to smooth it out, another couple layers of fiberglass. Sand and paint.
The worst part is getting it in place. Since it's rigid something else has to give to get in place. The air box is too difficult to remove, so there was a lot of prying on the front plastic air scoop piece.
It could use a little more adjusting to get it snug into the air box opening, but it's got good direct air flow. And I want to wrap it in some carbon fiber.
Old Jan 5, 2012 | 09:30 PM
that sounds pretty simple, What did you use for it to connect to the air inlet? I cant wait to do something like this! Where should I go to learn how to fiberglass lol
Old Jan 5, 2012 | 09:46 PM
Hogger's Avatar
Here it is as a rough mock up. I used the original connectors, but had to keep trimming to get the right fit.
The one vertical SC pipe was a bit of a pain to deal with. I ended up having to cut out a notch on the back of the intake, and re-glassing a small recessed channel to fit around the pipe.
Here it is getting ready to be glassed.
