Front end clunk ... ?
Old Jan 14, 2012 | 08:50 AM
mtnman82's Avatar
'16 E350, gone: '03 c230k
I was hoping it was just the tie rod ends, but not...
I'm hearing a 'clunking' like something is a little loose when I go over a slightly rough road or make a turn going thru a drainage gutter. Seems to be coming from the driver's side. I was grabbing and manhandling everything I could under the car but can't find anything loose. I replaced the tie rod ends hoping one was the culprit, but I still hear the clunking.
Any ideas on what else it could/might be?
Old Jan 14, 2012 | 09:46 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Swaybar endlinks.
Old Jan 14, 2012 | 10:34 AM
Glyn M Ruck's Avatar
Super Moderator
+1^ Greg - Sway links or castor bushes.
Old Jan 14, 2012 | 03:10 PM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Lower ball joints on the control arm will cause this as well. 02-04 C230 are notorious for front suspension ills. I have replaced every single part on the front since the car was new to stop clunking. Luckily everything was replaced under warranty other than the 2 tie rods which I did last summer.
the front suspension parts were under engineered and the majority have been superseded by a A204 XXX XX XX number rather than the original A203 XXX XX XX which only proves that this car had significant suspension issues
Jack up the front and support on jack stands and grab the tire at 12 and 6 and feel if there is any play.
Don't worry that you replaced the tie rods as they need replacement by 60,000mi or 100K km anyhow.
As Johnand said the bushings in the torque strut are also a weak item and that could be the cause
Old Jan 14, 2012 | 03:21 PM
samaritrey's Avatar
Super Moderator
THE C350
Or even a loose bolt. When I changed the lower control arms I left the bolt on the inside (engine side going through bushings) Loose and it made a horrible clunk.
Old Jan 14, 2012 | 08:51 PM
mtnman82's Avatar
Guess I was up too late then up too early as I mis-typed earlier...
I replaced the sway bar end links (NOT the tie rod ends) yesterday hoping that would take care of things, but not. Guess I'm on the hunt. I'll try manhandling the tires while jacked up and see if I can detect play that way.
So the castor bushes (bushings?) would be the next likely thing to suspect?
Also, can I assume the car is all right to drive as-is until we find the problem?
Old Jan 14, 2012 | 08:54 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Front end clunks are not typically indicative of a problem that would make the car unsafe. Could be strut mounts?
Old Jan 14, 2012 | 09:27 PM
samaritrey's Avatar
Super Moderator
THE C350
ball joints, castor bushings, sway bar end link, tire rod ends,
am I missing anything that can cause clunks?
Old Jan 15, 2012 | 08:53 AM
Boom vang's Avatar
not sure if I would agree, a very loose ball joint will make a lot of clunks going over bumps and I would say that is anything but safe.
If it is clunking, there is a problem somewhere as the engineer did not design it to be loose and noisy
Old Jan 15, 2012 | 08:57 AM
Boom vang's Avatar
worn wheel bearings with lots of play
loose wheel bolts
bad struts
broken spring
steering rack
Old Jan 15, 2012 | 10:38 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
^ No doubt each aforementioned piece of hardware can manifest untoward noises when their useful service life has been exceeded.
Seems I’ve replaced every suspension consumable (most more than once) over the course of ~102,000 miles in search of solid steering feel and/or improved performance.
IIRC, you’ve also an H&R anti-roll bar fitted up front. My bar’s bushings headed south within a year of initial installation. A horrible ‘clunk’ was the unfortunate result.
A friendly call to H&R’s U.S. importer [(888) 827-8881] netted a gratis pair shipped overnight without any proof of purchase shenanigans.
Old Jan 15, 2012 | 11:38 PM
mtnman82's Avatar
Thanks for the replies guys! Yep, I have the H&R sways front and rear, along with the Bilstien sports. I did double check the sway bar bushings and they looked good (both the mounts and the bushings themselves). I had to get the proper mounts and new bushings when I put them on about 1.5 years ago now. I put new hats/bushings/bearings in at that time too, so I could just pop out the old strut assy and pop in the new one.
It seems like the beginnings of something, as I can only feel/hear it over the small rough stuff (i.e. small roacky road surface) and not the bigger stuff. I just really hate the car not being 'right'. I should have a chance to jack it up and manhandle the wheels tomorrow.
Old Mar 29, 2012 | 05:44 PM
Benzonator's Avatar
2010 C 300 Sport
It's your front struts, most likely. I had to have both replaced on my 2010 C 300 Sport roughly three months after purchasing it new. The clunks were a dead giveaway.
