Check Engine Light
Old Jan 17, 2012 | 02:53 PM
C230Girl's Avatar
C230
Check Engine Light
I have a 2005 C230 Kompressor and a few days ago someone had put in 89 fuel instead of 93. Then yesterday the check engine light went on and the code that is showing is:
P0128 Coolant Thermostat Coolant Temp Below Thermostat Regulating Temperature
Is this a fluke thing because the fuel may have shocked the engine or how else do I fix this issue?
Old Jan 17, 2012 | 03:18 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
No it's not fuel related. The thermostat is stuck open and the car is not reaching normal operating temp. You need a new thermostat.. part is about $25-30 and labor might be $100. Don't take it to dealer.
tommy's Avatar
2004 Civic Si. FWD for the Win!
My guess would be bad thermostat, and that the bad gas has nothing to do with it.
Judging by your post, the best thing to do would be to have a MB specialist in your area look at everything and fix what needs to be fixed.
Old Jan 17, 2012 | 03:20 PM
Glyn M Ruck's Avatar
Super Moderator
Replace the thermostat!
Old Jan 17, 2012 | 04:06 PM
C230Girl's Avatar
C230
Ok thanks for the advice! The temp sits at 80 and does not over heat or rest below 80.
Old Jan 17, 2012 | 04:10 PM
LILBENZ230's Avatar
80 is too low. Should be 87-90.
Old Jan 17, 2012 | 04:42 PM
04mbc230's Avatar
2006 C230 Sedan
Hmmmz. Mine always is a little pass 80. I am guessing 83 or so.
Old Jan 17, 2012 | 04:47 PM
LILBENZ230's Avatar
A little past 80 = ~87
Old Jan 17, 2012 | 05:13 PM
C230Girl's Avatar
C230
Oh ok I didn't know that, thanks
Old Jan 17, 2012 | 11:51 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Mine started with staying ~80 when I first had this come up (and I got the CEL), then after a couple weeks it had a hard time getting over ~60. After replacing it heats up to ~85 and stays there. Cheap, easy fix - shouldn't be more than an hour in labor and $50 in parts.
Old Jan 18, 2012 | 02:30 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
All M271 engines seem to need a thermo after about 5years. I also changed a temp sensor that was throwing codes only when it was cold out side listed the error as 'Coolant' the sensor is on the exhaust side of the engine right near the plastic part (the nipple that attaches to the metal coolant pipe) that always breaks on this engine and is a 5 min job to replace the sensor and plug it in and costs about $20
Old Jan 18, 2012 | 06:56 AM
Super Moderator
Old thermostats opened between 87 & 89. New thermostats open at 90 in NA. They appear to have ceased to sell both.
Old Jan 18, 2012 | 08:47 AM
C230Girl's Avatar
C230
I'll take it in sometime next week then to have it changed out.
Old Jan 18, 2012 | 10:30 AM
LILBENZ230's Avatar
Stopped selling the thermostats altogether?
Old Jan 18, 2012 | 10:59 AM
C230Girl's Avatar
C230
I found this one...is this the right one?
http://europortparts.com/searchitem....u=473232323233
Old Jan 18, 2012 | 11:03 AM
LILBENZ230's Avatar
That's too expensive. Let me help:
http://www.rmeuropean.com/Part-Numbe..._91DEFFEE.aspx
Or even cheaper:
https://www.getmercedesparts.com/mer...***-parts.html
Old Jan 18, 2012 | 11:12 AM
TexFinn's Avatar
10 Tahoe LT, 07 Silverado Z71, 99 BMW R1100RT
50 bucks for a thremostat? No way.
Like LILBENZ230 already pointed out, low-30 buck range is where it should be. AutohausAZ has them for $33.xx. Then add $17 worth of other stuff and you'll get free shipping.
Old Jan 18, 2012 | 12:09 PM
Super Moderator
Ambiguous choice of words. They used to sell the conventional & cold climate thermostats. Now they only sell the cold climate 90 deg C one. No doubt for engine efficiency reasons.
Old Jan 18, 2012 | 12:28 PM
LILBENZ230's Avatar
Yep I see now what you meant.. lol
So it is more efficient to let it run at 90C instead?
Old Jan 18, 2012 | 02:15 PM
Tri-Star's Avatar
C320 4Matic & GLK350 4Matic
My temperature has always read 80 degrees, however I have a c320 v6 ... don't know if there should be a difference.
Old Jan 18, 2012 | 03:36 PM
Super Moderator
Yep - hotter is better within reason. Eg. VW have long tried to run bulk oil temp at 128 Deg C
Hotter engine & colder inlet air is the answer.
Old Jan 18, 2012 | 03:51 PM
C230Girl's Avatar
C230
Thanks I'll order it and hopefully the temp reads a little higher then it has been.
Old Jan 18, 2012 | 05:35 PM
nobli's Avatar
07 c230
not to hijack the thread, but would that also work on an 07 c230? and would i need to buy the housing separately ? or is it not necessary ?
Old Jan 19, 2012 | 02:00 PM
CoupeCrazy03's Avatar
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
Just got this code today Looks like ill have to replace the thermostat. . . anyone have the part number?
Old Jan 19, 2012 | 02:25 PM
LILBENZ230's Avatar
Uhhh there are links to it all in this thread.
