- Mercedes-Benz C-Class: Why is My Car Leaking Oil?
Guide to diagnose trouble and recommended solutions
Browse all: Engine Diagnostics
2005 M.Benz C240, major oil leak, finding oil on garage floor, not sure what to do...
Ant
See pdf for oil sensor replacement. Remember the 4Matic sump is a different shape to accommodate the drive shaft.
You know where to look if it is seals.
Good luck
Thanks for all your help. So, I need to change/drain the oil prior to removing the sensor? I ask that only because I just changed the oil not too long ago... Don't want to waste fresh expensive mobile 1
I saw the pdf file, not sure what it all means... where can I get the sensor? Having a hard time finding it at autozone.... Thanks
Ant
does this look like the correct sensor?
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Ant
Correction - sorry, I'm half asleep tonight - nearly 2am here. See additions above.
https://mbworld.org/forums/c-class-w...l+level+sensor
pcy is also very technically competent & if you find it is the sensor or sensor O ring maybe a PM to him would help you if he does not notice this thread. He has 4Matic experience.
also the oil level sender exit point of the block is above the oil level. so the only leaking or sweating would be caused when the oil sloshes around. as for the pilot bushing as soon as the car is on, trans fluid pumps throughout the trans. and it will leave a nice couple of drops almost immediately.
