Do Akebono EUR872 Brake Pads come with Sensors, too?
Specifically looking at the EUR872 set for the front axle of my C320 (two sensors req'd). Can someone clarify if this set includes the sensors? I understand the EUR1121 pads have sensors, but my older ride uses the EUR872. If the sensors are dependent on where you buy the pads, which seller do I go to. Thanks.
MBParts Online doesn't have a photo of the "kit" to show whether the sensors are included. On several other MB Akebonos, photos show they do...
http://www.mbpartswarehouse.com/part...akebono+brakes
I bought my pads from Tirerack and they did not come with the sensor, a quick trip to good ol Autozone and 8 or 9 bucks later I had the correct sensor. I took the old one with me so I would get the correct sensor - I had a friend of mine who went to get a sensor without bringing the old one for reference and they totally gave him the wrong part.
Good Luck!
A smart thing to do would be to order the pads, and if they don't come with the sensors, but the sensors separately.
Good Luck!
As I read more about these, I just come up with more questions, as usual... The latest... Are each of these pads drilled for the sensor? Again, my C320 has sensors on all four wheels, so I need the front pads to have the holes, and the bracket on each that clips the sensor in place.
Did your sensor go off and give you a warning?
That can be fixed if you want to.
Otherwise no brake pads I know off come with sensors. Too much hassle as it would be model specific.
Seems this thread has already covered just about every possible scenario.
Like M-bENZ, mine came with ‘sensors’ that didn’t fit.
Best get some before scheduling the installation. PN = 211 540 17 17
